Trim Damper Bolt Length
graeme.hart(at)onecoolkat
PostPosted: Sun Oct 02, 2016 1:43 am    Post subject: Trim Damper Bolt Length Reply with quote
Hi All
I am attempting to assemble the Trim Damper system but the M5x60 bolt appears too long and is hitting the bracket TS02.
I have used an FL14 spacer and AN960-416L washer on both sides of the bellcrank bearing.
Have I done something wrong or am I supposed to trim the M5x60 bolt to a suitable length?
Thanks for any advice.
Graeme
h&jeuropa
PostPosted: Sun Oct 02, 2016 3:55 am    Post subject: Re: Trim Damper Bolt Length Reply with quote
Graeme,
You should not have to trim the M5 bolt.
TS03 bellcrank is supported by AN4-15A bolt with two FL14 spacers.
The friction assembly attaches to the bellcrank in the hole aft of the bellcrank bearing. Fig 2 page 19-2 shows how the friction assembly is made. The M5 bolt is secured by M5 nyloc and check nuts.
Hope this helps.
Jim & Heather
PostPosted: Sun Oct 02, 2016 11:48 am    Post subject: Trim Damper Bolt Length Reply with quote
Thanks Jim and/or Heather
I realise my mistake now.  I was trying to install the M5 bolt like a normal bolt with the head up against the nut end of the TS04A shaft.
Looking at figure 6 on page 4 I realise that there is a gap between the head of the nut and the end of the shaft.
Now I just need to order some replacement TS04B friction washers (due to me getting some nickel anti seize compound on them).
Thanks again
Graeme
On Mon, Oct 3, 2016 at 12:55 AM, h&amp;jeuropa <butcher43(at)att.net (butcher43(at)att.net)> wrote:
--> Europa-List message posted by: "h&amp;jeuropa" <butcher43(at)att.net (butcher43(at)att.net)>
Graeme,
Hope this helps.
Jim & Heather
http://forums.matronics.com/viewtopic.php?p=460884#460884
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
