rowlandcarson(at)gmail.co Guest
Posted: Sat Oct 01, 2016 8:14 am Post subject: rotax 912 fuel banjo angle |
I posted this query last month but have had no response so I’m trying again.
In Appendix A (final inspection checklist) of the Rotax 912S installation manual for the Europa XS, one of the items is puzzling me. It says:
"Check that fuel inlet banjos are correctly orientated."
However, I can find nowhere in the document indicating what the correct angle might be. I’d like to be sure mine are correctly orientated before I start connecting fuel lines.
Here is a link to pictures of the carbs on my engine as-supplied:
http://www.rowlandcarson.org.uk/aviation/europa_435/carb_inlets.pdf
and I wonder if anyone can tell me if they are at the correct angle.
in friendship
Rowland
Burrilla
Posted: Sat Oct 01, 2016 8:48 am Post subject: rotax 912 fuel banjo angle |
I'm not aware of any particular angel.
My only suggestion is that it might refer to making sure the banjo is orientated so that the fuel lines do not impede the carb controls and are clear of any heat sources.
The only other thought is that with the fuel lines arriving from below then any vapour locks forming are more likely to be expunged through the carb than sitting in the pipes at a high spot above the carb.
All IMHO
Alan
G-OBJT
| Quote: | On 1 Oct 2016, at 17:13, Rowland Carson <rowlandcarson(at)gmail.com> wrote:
in friendship
Rowland
JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Mon Oct 03, 2016 8:19 am Post subject: Re: rotax 912 fuel banjo angle |
I agree with Alan. Those banjos can be angled any way that suits your installation.
