rv10free2fly(at)yahoo.com Guest
Posted: Fri Sep 30, 2016 10:22 pm Post subject: Undercarriage Nylok Nuts |
When I was at Oshkosh in 2015 I stopped to chat to a poor RV-10 pilot (sorry I can't remember your name, however you had an English accent, so I'm assuming you weren't American, but I digress), who had experienced overheating of his brakes while taxiing in after landing, to the point where the wheel fairing caught fire.
Suffice to say that the undercarriage as a burnt mess.
Considering the potential for overheating of the brakes, I am considering swapping all the Nylok nuts on the undercarriage and brakes with all-metal stop nuts.
Have others adopted a similar course of action as a contingency?
Is there any disadvantage of using the cadmium plated all-metal lock nuts?
Warm regards
Patrick
21.21 KB |
5299 Time(s) |
eagerlee
Posted: Mon Oct 03, 2016 5:30 am Post subject: Re: Undercarriage Nylok Nuts |
We replaced all the nylok nuts at the brake calipers with high temperature lock nuts for the very reason you stated - things could get HOT sometimes.
Paul Hahn
N82FF
Kelly McMullen
Posted: Mon Oct 03, 2016 12:29 pm Post subject: Undercarriage Nylok Nuts |
If the nylocs on the calipers get hot enough to fail, you will have already overheated the O rings and likely have brake fluid leaking.
While some have replaced the O-rings of standard MS designation with Viton for heat resistance, there is a lot of mass to dissapate heat in the calipers. Nice to add protection, but the caliper manufacturers seem to mostly use nylock and proably have a good idea the heat stress for those nuts.
-sent from the I-droid implanted in my forearm
On Mon, Oct 3, 2016 at 6:30 AM, eagerlee <eagerlee(at)comcast.net (eagerlee(at)comcast.net)> wrote:
| Quote: | --> RV10-List message posted by: "eagerlee" <eagerlee(at)comcast.net (eagerlee(at)comcast.net)>
Paul Hahn
N82FF
http://forums.matronics.com/viewtopic.php?p=460906#460906
WIKI -
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Tue Oct 04, 2016 2:57 am Post subject: Undercarriage Nylok Nuts |
Many thanks for cementing my thoughts Paul.
Warm regards
Patrick
| Quote: | On 4 Oct 2016, at 00:00, eagerlee <eagerlee(at)comcast.net> wrote:
Paul Hahn
N82FF
