art(at)zemon.name Guest
Posted: Mon Sep 26, 2016 6:10 pm Post subject: Connecting Shielded Cable to DB-25 |
Folks,
I need to connect a shielded cable to my DB-25 connector and I need some advice about how to physically construct this. Here is the wiring diagram
strobe position lights.pdf
I am concerned with the construction of wires LIGHTS-1-C and LIGHTS-1-D at the wing root. Specifically, the center conductor of the cable is to be connected to a pin in the DB-25. The shield is to be connected to a local ground. This connector (when operating) will be inside the tubular spar of my Bede BD-4C, so the whole assembly will be well shielded; I'm not worried about how many unshielded inches I have near the DB-25.
This is what I think will work: Strip the outer insulation of the shielded cable back several inches, so that I can separate the shield from the center conductor outside the DB-25 housing. Solder a sufficient amount of wire to the shield so that I can work with it and attach it to the local ground. Run the center conductor to the DB-25 and connect it to a pin just like any other wire.
Your thoughts?
Thank you,
-- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
ceengland7(at)gmail.com Guest
Posted: Mon Sep 26, 2016 6:35 pm Post subject: Connecting Shielded Cable to DB-25 |
On 9/26/2016 9:05 PM, Art Zemon wrote:
| Quote: | Folks,
Your thoughts?
Thank you,
-- Art Z.
https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
| Art,
I believe Bob has a 'cookbook' page showing that technique for handling shields at sub-d connectors. You should be fine.
cluros(at)gmail.com Guest
Posted: Tue Sep 27, 2016 12:21 am Post subject: Connecting Shielded Cable to DB-25 |
I would connect the shield to ground at the wing tip end Art, not at the wing root end.
Sebastien
On Sep 27, 2016, at 03:05, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
| Quote: | Folks,
Your thoughts?
Thank you,
-- Art Z.
Posted: Tue Sep 27, 2016 12:25 am Post subject: Connecting Shielded Cable to DB-25 |
Whoops, disregard last message, I see you are talking about the wire from the cabin. Any reason you can't just ground it at the switch?
Sebastien
| Quote: | Folks,
Your thoughts?
Thank you,
-- Art Z.
Posted: Tue Sep 27, 2016 4:12 am Post subject: Connecting Shielded Cable to DB-25 |
On Mon, Sep 26, 2016 at 9:32 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
| Quote: | On 9/26/2016 9:05 PM, Art Zemon wrote:
| Quote: | Folks,
I need to connect a shielded cable to my DB-25 connector and I need some advice about how to physically construct this....
| Art,
I found it: Shield Termination Techniques
I can adapt that nicely. Thank you, Charlie.
-- Art Z.
