Perspex sliding direct view panels
graeme bird
PostPosted: Mon Sep 05, 2016 11:21 pm    Post subject: Perspex sliding direct view panels Reply with quote
Frustrated with reflections in my ariel photos I am looking again at a sliding window in the cockpit Perspex. I'd be interested to know if it's practical to stick a lens out at 130knts and whether it would be just too alarming/ noisy/ blowy. Re the window, the mecaplex one is around 500£, so not cheap for a punt, and I have concerns about small splits/ cracks appearing. Any comments from anyone who uses one would be appreciated. I already have three NCA air inlets so it's not SO much about ventilation. I recall Pete Jeffers offering a jig a while back.
An alternative might be a non reflective glass window lower down I suppose, in the body where there is less light bouncing about. Or perhaps I should just experiment more with black tubes/ foam around the camera lens.
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
graeme.hart(at)onecoolkat
PostPosted: Tue Sep 06, 2016 12:43 am    Post subject: Perspex sliding direct view panels Reply with quote
A large rubber lens hood works quite well to stop reflections, you can get
a reasonably light proof seal with this.
I know this is not answering your question and you've probably already
tried this but I couldn't let it go unmentioned.
A removable panel in the bottom of the cockpit might work, you could also
drop bombs thought it. Smile
spcialeffects
PostPosted: Tue Sep 06, 2016 4:43 am    Post subject: Re: Perspex sliding direct view panels Reply with quote
What about the direct vision panel? The mod was by Peter Kember if i remember correctly?
InkrGod
PostPosted: Tue May 12, 2020 10:20 pm    Post subject: Re: Perspex sliding direct view panels Reply with quote
Yeah, your logic is working well, so you’re right. I think you should get it fixed somewhere. Those indicators are not supposed to be like that. Something is clearly going wrong. I’ve had a similar problem, but I got it quickly fixed with the help from the guys at Ongill Electric. I recommend you take it to a place like that, where professionals can repair it and you won’t have to pay much. Or just change it, maybe that will be easier to do rather than looking for a place where to fix it. Good luck with that.
