art(at)zemon.name Guest
Posted: Fri Aug 26, 2016 10:48 am Post subject: Wire Clamps |
Folks,
In poking around the aeroelectric.com website, I ran across this photo:
In the top, right is a nylon bracket holding a zip-tie which holds the wires. I thought that pretty much the only acceptable clamp for wires in an airplane is Ye Ole MS21919 cushion clamp. Please educate me.
  -- Art Z.
http://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
ngeorge(at)cmg.aero Guest
Posted: Fri Aug 26, 2016 11:14 am Post subject: Wire Clamps |
Art –
Using zip-ties on wire bundles is not a problem. The problem is using zip-ties to secure wire bundles (or anything else) to critical structure, like engine mount tubing. Dirt and oil collect under the nylon and makes a pretty good saw. It is nearly impossible to tighten a zip-tie to the point that relative movement is eliminated. Over time, vibration of the parts working the grit can cut thru the structure.
Nylon saddles and stand-offs similar to those shown in the photo can be found in many certificated aircraft, but they are usually screwed, bolted, riveted or clipped to sheet metal components.
neal
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Art Zemon
Sent: Friday, August 26, 2016 1:47 PM
Subject: AeroElectric-List: Wire Clamps
Folks,
-- Art Z.
rene(at)felker.com Guest
Posted: Fri Aug 26, 2016 11:48 am Post subject: Wire Clamps |
When I want to connect something and I am worried about wear or fit, I use F-4 Tape.  For example, a couple of wraps around the motor mount and you can just zip tie away. The zip tie will embed in the rubber and never move again. Easily removed if need be since there is no adhesive. There are a lot of uses for this stuff…..
If you have never used a fusion tape before…..caution, you will quickly become addicted to its use. It is fun to play with also.
Not cheap………but a little goes a long way.
Another use for me is for strain relief for connectors. I wrap it around the wires and then clamp the back shell around the bundle. Great for when you have only couple of wires going into a DB-25 connector.
http://www.f4tape.com/?gclid=CIrJ6ffp384CFQUJaQodXN0PTA
You can purchase it on Amazon.
Rene'
801-721-6080
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Neal George
Sent: Friday, August 26, 2016 1:10 PM
Subject: RE: Wire Clamps
Art –
neal
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Art Zemon
Subject: Wire Clamps
Folks,
-- Art Z.
Posted: Mon Aug 29, 2016 4:50 pm Post subject: Wire Clamps |
Rene',
Do you know how F4 tape compares to Harbor Freight silicon tape (at) $3.99 for 10 feet? Or various other brands such as Super Glue, Nashua,and Loctite, all available for well under $10?
  -- Art Z.
On Fri, Aug 26, 2016 at 2:46 PM, Rene <rene(at)felker.com (rene(at)felker.com)> wrote:
Â
Â
Â
Â
Posted: Mon Aug 29, 2016 5:50 pm Post subject: Wire Clamps |
Not really. I bought some black tape from ?????? and it works fine also. The F4 does seem to fuse better and I think it has more heat resistence.
But have never compared.
Sent: Monday, August 29, 2016 6:40 PM
Subject: Re: Wire Clamps
Rene',
-- Art Z.
Posted: Tue Aug 30, 2016 5:56 am Post subject: Wire Clamps |
At 07:44 PM 8/29/2016, you wrote:
| Quote: | | That's a very clever idea. Thank you, Kent. I'll keep that one in mind. Given the way that the interior of the BD-4C is built, I am more likely to rivet a little piece of scrap to a an aluminum angle that is part of the frame than to use epoxy. But you have given me food for thought. |
Adhesives in structural or semi-structural
applications are worthy of thought . . . and
testing.
Adhesive science is as much art as it is
physics. You can delve into the subject
on the 'net where you will discover discussions
on levels of energy inherent in the surfaces
of the various materials. The ability of an
adhesive to grip any given surface is a
function of surface textures and energy
levels diluted with the effects of shock,
moisture, contamination, temperature, etc. etc.
I would not discourage anyone from trying
any combination of glued joints using
materials from their past experiences
but if joint failure in your airplane
generates an uncomfortable level of
risk . . . well . . . think it through
and TEST.
At Beech, we had folks in the materials
lab who were dedicated to the study and
application of the various uckum-yuckies
that were offered up as the next great
glue. They could tell you some pretty
amazing stories . . . and as long as the
studies were confined to the lab, some were
funny too.
A few years ago I produce this article
for the 'Connection . . .
http://tinyurl.com/j2gxbqy
. . . and later, refined it for Kit Planes
http://tinyurl.com/hxczu3r
The article speaks to the use of glued-on
mountings for low-risk structural applications.
Securing wire bundles and small electro-whizzies
to the airplane are generally low risk
situations.
About the time I was selling the bond studs,
I researched a number of adhesives for their
suitability to task. No doubt there are many
but the material E6000 and "ShoGoo" proved
to be useful. The stuff needs 24 hour cure
but it's tenacious, robust, inexpensive
and available about everywhere.
Posted: Tue Aug 30, 2016 1:06 pm Post subject: Wire Clamps |
More good ideas. Thank you, Bob.
Everybody: This is hugely helpful. I won't use all of these ideas but just seeing the photos is giving me ideas that I can build on. Some of the places that I want to secure wires would have been a PITA with cushion clamps.
  -- Art Z.
On Tue, Aug 30, 2016 at 8:54 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
 testing.
 and TEST.
 funny too.
 situations.
