Switch For Thermocouple Wires
billhuntersemail(at)gmail
PostPosted: Sun Jul 24, 2016 2:39 pm    Post subject: Switch For Thermocouple Wires Reply with quote
I do not have sufficient pins left over in my Dynon EMS for my temperature monitoring needs.
One of the items I do not need to monitor on a regular basis is the turbocharger intercooler outlet temperature (the actual temperature of the air entering the engine inlet) as I just really need to see that on a very hot day.
Since this airplane is a pusher there is no visual indication of smoke or fire like on a tractor airplane so I would really like to have an internal engine cowling temperature indication using a thermocouple. I envision setting up the Skyview to trigger a red indication and a warning if a fire develops in the engine compartment and the temperature exceeds a preset limit and then I can react faster than waiting for the really bad day to develop.
Since the engine inlet temperature is a NICE to know item and the engine cowling is a NEED to know... I was thinking about installing two thermocouples one in the inlet and one in the engine compartment and then wire each pair of wires to a DPST switch and then this switch would remain in the position to sence the NEED to know  information 99 percent of the time and then flicked to the NICE to know position when it is becomes nice to know.
Other than the usual solid connectors and quality switch requirements is there anything special to consider with thermocouple wires?
THANKS!!!
Bill Hunter
ceengland7(at)gmail.com
PostPosted: Sun Jul 24, 2016 3:51 pm    Post subject: Switch For Thermocouple Wires Reply with quote
on a very hot day.
THANKS!!!
Bill Hunter
To keep accuracy, you need to switch both leads. If you're just
switching between 2 sensors, use a DPDT switch, so that the meter sees
either both wires from one, or both wires from the other. Reason for
switching both leads is that any 'junction' (connector, switch
terminals, etc), particularly when the metal changes, like it would
going through a switch, causes errors in measurement. If both leads are
switched in the same space (meaning same temperature), then the errors
cancel each other.
(Don't forget that your alarm setting in the Dynon may cause false
alarms if there's a big difference in 'normal' temps between the two
sensors.)
Charlie
argoldman(at)aol.com
PostPosted: Sun Jul 24, 2016 4:41 pm    Post subject: Switch For Thermocouple Wires Reply with quote
If you have more probes you can use a rotary switch
Rich
On Jul 24, 2016, at 6:51 PM, Charlie England <ceengland7(at)gmail.com> wrote:
> THANKS!!!
> Bill Hunter
To keep accuracy, you need to switch both leads. If you're just switching between 2 sensors, use a DPDT switch, so that the meter sees either both wires from one, or both wires from the other. Reason for switching both leads is that any 'junction' (connector, switch terminals, etc), particularly when the metal changes, like it would going through a switch, causes errors in measurement. If both leads are switched in the same space (meaning same temperature), then the errors cancel each other.
(Don't forget that your alarm setting in the Dynon may cause false alarms if there's a big difference in 'normal' temps between the two sensors.)
Charlie
edpav8r(at)yahoo.com
PostPosted: Mon Jul 25, 2016 8:23 am    Post subject: Switch For Thermocouple Wires Reply with quote
On Jul 24, 2016, at 3:35 PM, William Hunter <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
Just a few things to add to Charlie's response.
The chromel/alumel wires used with common K-type thermocouples are practically impossible to solder with typical tin/lead, rosin core electronic solder. They require high temperature silver solder and appropriate flux. Crimped or screw-down connectors are much easier to use.
A cheap and easy source for additional chromel/alumel extension wire is to buy K-type thermocouples on eBay and cut them up. They can be had for under a dollar, delivered:
http://preview.tinyurl.com/j88uupr
The ones you see with a threaded metal sensor and spade terminals have fiberglass insulation on the wires and a braided metal outer sheath (suitable for under cowl use). The ones with a yellow connector have plastic insulation and a fiberglass sheath (smaller diameter, easier to route in the fuselage).
If you have to splice wires for length, you can use any crimped connector to join them, as long as the wires twist around each other to make electrical contact independent of the connector.
The normal color convention for positive/negative connections is reversed for thermocouples: red is negative. Swapped connections won't damage anything but the instrument will read backwards.
Use chromel/alumel wire from the sensor to the switch *and* from the switch to the instrument. Don't change to copper wire after the switch.
The following documents might be more than you want to know, but there's a lot of interesting info about understanding and applying thermocouples:
- (Australian) AC 21-99, Aircraft Wiring & Bonding, Sec 2, Chap 16, "Thermocouple Wire Soldering & Installation":
http://preview.tinyurl.com/z5fwrzw
- A Stanford University mechanical engineering professor's advice on thermocouples:
http://preview.tinyurl.com/jl873l4
- An Acromag white paper on temperature measurement with thermocouples:
http://preview.tinyurl.com/hawrxwt
- A Maxim Integrated application note explaining cold junction compensation:
http://preview.tinyurl.com/jm2kku2
Eric
PostPosted: Tue Jul 26, 2016 4:31 pm    Post subject: Switch For Thermocouple Wires Reply with quote
Thanks Charlie,
I am somewhat interested in knowing how hot a fire is... The plan would be to install the Thermocouple on the firewall above the fuel hoses as these are arguably the likely suspects. Then I would have a temperature read out (just numerical value) displayed somewhere on the screen below the engine "guages".
The idea being the display would be white digits until the temperature indication raises above a predetermined values and then turn red.
Any recommendations on that value should be so as to avoid faulse readings?
Bill Hunter
On Jul 24, 2016 4:57 PM, "Charlie England" <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
THANKS!!!
Bill Hunter
Charlie
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
alec(at)alecmyers.com
PostPosted: Tue Jul 26, 2016 5:14 pm    Post subject: Switch For Thermocouple Wires Reply with quote
No suggestions from me about a good temperature threshold for the fire alarm except that it's just begging for some experimentation Smile
[quote] On Jul 26, 2016, at 8:29 PM, William Hunter <billhuntersemail(at)gmail.com> wrote:
Thanks Charlie,
Bill Hunter
PostPosted: Tue Jul 26, 2016 5:34 pm    Post subject: Switch For Thermocouple Wires Reply with quote
I'll light the fuse and let you know
Bill Hunter
On Jul 26, 2016 6:22 PM, "Alec Myers" <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
On Jul 26, 2016, at 8:29 PM, William Hunter <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
Thanks Charlie,
Bill Hunter
THANKS!!!
Bill Hunter
Charlie
FORUMS -
WIKI -
b Site -
PostPosted: Tue Jul 26, 2016 8:01 pm    Post subject: Switch For Thermocouple Wires Reply with quote
Sorry; no idea. What I meant was that measuring different temp ranges (inlet vs cowl), they're likely to have different normal ranges. So, setting up the alarm point in the efis would be different for each source.
Date:07/26/2016 7:29 PM (GMT-06:00)
Subject: Re: AeroElectric-List: Switch For Thermocouple Wires
Thanks Charlie,
Bill Hunter
THANKS!!!
Bill Hunter
Charlie
FORUMS -
WIKI -
b Site -
PostPosted: Tue Jul 26, 2016 9:10 pm    Post subject: Switch For Thermocouple Wires Reply with quote
Thanks…the plan would be for the selector switch to live in the COWL TEMP setting 99.3 percent of the time (watching for an engine fire) so the cowl temp predetermined trigger point is really all that I am interested in…I guess I can just SWAG 500F as the trigger point for the white to red digits in Dynon and after watching the digits during some normal very hot day operations I can see what the usual engine cowl internal temps will be (and the rate of increase) and then adjust accordingly.  I wonder if I can teach the nice Dynon girl to say “Warning” or … “Engine Fire” or something…a calm British accent would be really cool?!?!?
The engine turbo intercooler exhaust is simply a Gee Wizz indication for the remainder 0.7 percent so no real concern for the trigger, colors, or British babe voice.
Cheers!!!
Bill  Hunter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England
Sent: Tuesday, July 26, 2016 8:59 PM
Subject: Re: Switch For Thermocouple Wires
Thanks Charlie,
Bill Hunter
THANKS!!!
Bill Hunter
Charlie
FORUMS -
WIKI -
b Site -
PostPosted: Tue Jul 26, 2016 9:32 pm    Post subject: Switch For Thermocouple Wires Reply with quote
On Jul 26, 2016, at 5:29 PM, William Hunter <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
For gasoline, ignition temp is 232°C and flame temp varies from ~945°C to 1,950°C depending on conditions.
Eric
PostPosted: Wed Jul 27, 2016 3:52 am    Post subject: Switch For Thermocouple Wires Reply with quote
At 12:31 AM 7/27/2016, you wrote:
On Jul 26, 2016, at 5:29 PM, William Hunter < billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
Eric
It's been about 30 years since I fiddled with
fire detection techniques. We looked at them as
a potential product for Electro-Mech about 1980.
No software back then . . . all discrete jelly
beans. There were two techniques that showed
promise. One involved temperature sensors at
ram air inlet and cooling outlet ports and
circuitry that watched for (1) outlet to
exceed xx degrees along with (2) a rate
of rise in the differential between the
two.
The other technique, and the one most popular
with our customers involved routing a kind
of linear thermistor around the engine's
potential hot spots during a fire. The
'thermistor' looked for all the world like
a piece of semi-rigid coax cable. Thin
metal jacket (stainless I think). Center
conductor of solid metal. A 'dielectric'
of thermistor material.
Looking into the end of the 'coax' one
would see an infinite number of thermistors
all tied in parallel. But should any portion
of the 'coax' be exposed to flame, the thermistor
material in that area would present a sharp
drop in resistance which was detected by
the electronics.
We never did pursue the opportunity beyond
the gee-what-if stage. I went off to work
the servoed pitch trim controller for the
Lears . . . Dean did an APU controller for
Duncan Aviation.
The long, temperature sensitive 'coax' was
kinda cool. You could route it as needed in
the engine space but it was a specialty
product that was custom-manufactured to
the design. Breathtaking start-up costs.
With software one could place one or more
temperature sensors about the engine spaces
and write scanning/interpretation routines
to identify abnormal temperature profiles.
For an OBAM aviation project, I can see
a kind of universal fire detection system
that is first installed in a 'learn' mode
and flown for xx hours. Once 'normal'
temperatures are identified and cataloged,
a 'operate' mode would raise a flag if
conditions markedly outside the normal
parameters was detected.
It's an interesting design study that
was very low on Electro-Mech's totem pole
of market opportunities. Under the cowl
fires just don't figure into a significant
percentage of bad-days-in-the-cockpit.
PostPosted: Wed Jul 27, 2016 5:08 am    Post subject: Switch For Thermocouple Wires Reply with quote
On Wed, Jul 27, 2016 at 6:49 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Eric
  two.
  the electronics.
  Duncan Aviation.
A number of years ago, there were a few guys playing with optical flame sensors (triggered by the light spectrum of actual flame, instead of heat). Idea was quicker & more discriminating detection of actual fire, vs just high temps. Conversation kinda faded away, so I don't know if they ever got it implemented. IIRC, the detectors were a bit pricey, so given the rather low odds of fire, I never pursued it for myself. William may have more motivation, flying a pusher.
Charlie
sportav8r(at)gmail.com
PostPosted: Wed Jul 27, 2016 5:27 am    Post subject: Switch For Thermocouple Wires Reply with quote
I'm thinking extreme analog/tinker-toy technology, here, but why not a cotton string across the cowl outlet that holds open a spring-loaded N.O. switch.  Fire would presumably burn it through quickly.  A cross-check with a cowl air temp indicator would help confirm actual fire vs. "the old string finally rotted-through between annuals."
Since we now fly in the digital age, the obvious modern solution is a belly cam to show the flames licking out of the cowl exit.
-Stormy
On Wed, Jul 27, 2016 at 7:49 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Eric
  two.
  the electronics.
  Duncan Aviation.
PostPosted: Wed Jul 27, 2016 5:31 am    Post subject: Switch For Thermocouple Wires Reply with quote
-There's something that looks a lot like this run in a circle around the wheel wells of various jet transport aircraft I've see, presumably to detect brake/tire fires when the undercarriage is retracted.
enginerdy(at)gmail.com
PostPosted: Wed Jul 27, 2016 6:54 am    Post subject: Switch For Thermocouple Wires Reply with quote
That’s an interesting idea…
If you’re just looking at an ‘extreme rise’ temperature, you could put a bunch of NTCs* in parallel down a length of wire, and when the impedance drops somewhere, you would get an indication. Electrically it’s pretty similar to the thermistor snake.
Probably a good bit of fab work, but just the cost of some wire, heatshrink, and a handful of NTCs!**
*Negative thermal coefficient thermistors
On Jul 27, 2016, at 6:49 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
The other technique, and the one most popular with our customers involved routing a kind of linear thermistor around the engine's potential hot spots during a fire.
PostPosted: Wed Jul 27, 2016 9:34 am    Post subject: Switch For Thermocouple Wires Reply with quote
Good information and great ideas (I especially like the string idea)!!!
I think my strategy will be to install a thermocouple at the top of the
firewall on a "L" bracket with the thermocouple sensor end pointing down and
I will cover the wires in Aeroquip fire sleeve from the probe all the way to
the firewall penetration pass through.
I will then place the cowling temperature digital readout on the Skyview
screen in a location under the CHT readouts. The digital readout will
just look like "COWL 285F" in white text. I will monitor the readout for a
few flights and if the temp routinely gets to 300F but no higher I will then
set the Skyview system to change the digits from white to yellow at 400F and
then to red at 500F as a wake up.
If I am ever flying along fat, dumb, and happy and I see the digits rapidly
change from white to yellow to red as the indication shoots up to the 4
digits.and then.the digits begin to display "XXXX" then I guess the day has
become bad and I am still fat.and dumb.but no longer happy.
THANKS AGAIN for your advice!!!
ARGOLDMAN(at)aol.com
PostPosted: Wed Jul 27, 2016 1:03 pm    Post subject: Switch For Thermocouple Wires Reply with quote
Of course you could always use the technique that Burt Rutan used in the SS1 engine.. I think that he wrapped a copper (or other low fusing wire around the engine, ran a small current through it and if there were a breach in the containment vessel, the wire would burn through and open the circuit.
Alternately use an EGT probe in the area of question.
Rich
In a message dated 7/27/2016 1:23:55 P.M. Pacific Daylight Time, sportav8r(at)gmail.com writes:
-Stormy
Eric
two.
the electronics.
Duncan Aviation.
PostPosted: Wed Jul 27, 2016 1:14 pm    Post subject: Switch For Thermocouple Wires Reply with quote
On Jul 27, 2016, at 4:49 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
The other technique, and the one most popular with our customers involved routing a kind of linear thermistor around the engine's potential hot spots during a fire. The 'thermistor' looked for all the world like a piece of semi-rigid coax cable. Thin metal jacket (stainless I think). Center conductor of solid metal. A 'dielectric' of thermistor material.
Looking into the end of the 'coax' one would see an infinite number of thermistors all tied in parallel. But should any portion of the 'coax' be exposed to flame, the thermistor material in that area would present a sharp drop in resistance which was detected by the electronics.
That's the technique that Bombardier uses in their products (at least the ones I flew). The thermistor loops are installed around the hot section and pylon of each engine, along the anti-ice bleed air ducts, inside the APU enclosure and on the ceiling of the main wheel wells. Unfortunately I no longer have access to the electronic manuals and my hard copy is in a box somewhere, so I can't post the technical description.
Boeing took a different route; one that, to my mind, seems a bit more fiddly and less robust. The following is an excerpt from the B-737NG systems manual. I'm not sure if this system is a relic of the original 1960's design, or a later revision.
Each engine contains two overheat/fire detector loops. Each loop provides both fire and overheat detection. When the temperature reaches the Overheat Set Point, the gas in the detector loop expands, closing the Overheat Pressure Switch. This decreases the resistance of the detector. The Engine and APU Fire Detection Module uses the decrease in resistance to set the overheat condition. As temperature increases to the Fire Set Point, the gas continues to expand and closes the Fire Pressure Switch, further decreasing the resistance. The Engine and APU Fire Detection Module uses the decrease in resistance to set the fire condition.
Eric
