Yak 50 tailwheel fork upper bushings
fishmouth500
PostPosted: Mon Jul 11, 2016 6:05 pm    Post subject: Yak 50 tailwheel fork upper bushings Reply with quote
Your Yak 50 tailwheel fork have excessive play ?
Locally-made Yak 50 tailwheel fork upper bushings available.
2 pcs shown. More available. Ships anywhere from CA 92020
Bushing OD going into the tube is a press fit. You will have about .001" interference to remove off the ID with a hone to achieve the desired fit onto the fork.
Please contact me off list or 619 933-2571.
John
 Filesize:  362.79 KB
 Viewed:  2113 Time(s)
 Filesize:  401.05 KB
