Yak-List:
jbsoar(at)gmail.com
PostPosted: Sat Jun 25, 2016 6:21 pm    Post subject: Yak-List: Reply with quote
The little one fits the 55, right?If someone just wants the big one, I might be interested in the little one, assuming it fits.
The wheel/brake installation was just finished!
Any progress on the tailwheel project?
Thank you!
john b
On Sat, Jun 25, 2016 at 6:33 PM, John Warwick <john.warwick1(at)gmail.com (john.warwick1(at)gmail.com)> wrote:
Yak 52 Air Bottles.
Fresh Hydro Good through May 2021.
Tested by Compressed Gas Systems in Los Angeles.
Paperwork included, see third picture.
Technician reported internal surfaces were both above average.
Removed from a Yak 52 that has stood unpressurised since 2002
Tanks sold as a pair. Please contact me off list.
L29delfin(at)yahoo.com
PostPosted: Fri Jul 08, 2016 7:47 am    Post subject: Yak-List: Reply with quote
Can someone provide the lenght and size in metric for the screws used to attach the upper gap seals between wing and fuselage yak 52. Also the orignal part number. These are small steel slot head screws. Thanks
dsavarese0812(at)bellsout
PostPosted: Fri Jul 08, 2016 8:27 am    Post subject: Yak-List: Reply with quote
I don't have the part number. We replace these screws with4mm x 12mm or
13mm metric Philips Truss Head screws. I'm sure you can find the same
size slot head screws in steel instead of stainless.
//A. Dennis Savarese //
//334-546-8182 (mobile)//
//www.yak-52.com //
//Skype - Yakguy1//
pa3arw(at)ziggo.nl
PostPosted: Fri Jul 08, 2016 9:33 am    Post subject: Yak-List: Reply with quote
And I have changed them into stainless torx because these are stronger and
better suited for electric screwdrivers....
Hans O.
PH-YAK
Op 08-07-16 18:27, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> schreef:
//www.yak-52.com //
//Skype - Yakguy1//
yaknorway52(at)gmail.com
PostPosted: Fri Jul 08, 2016 10:22 am    Post subject: Yak-List: Reply with quote
Hans,
Do you have link to supplier you use for Torx screws?
Br
Havard
Sendt fra min iPhone
Den 8. jul. 2016 kl. 19.32 skrev Hans Oortman <pa3arw(at)ziggo.nl>:
Hans O.
PH-YAK
> //www.yak-52.com //
> //Skype - Yakguy1//
dougsappllc(at)gmail.com
PostPosted: Fri Jul 08, 2016 10:30 am    Post subject: Yak-List: Reply with quote
I do not carry the SS torx, but do have the SS low profile phillips 4 and 5 mm screws in stock.
Doug
On Fri, Jul 8, 2016 at 11:21 AM, Håvard Dale <yaknorway52(at)gmail.com (yaknorway52(at)gmail.com)> wrote:
--> Yak-List message posted by: =?utf-8?Q?H=C3=A5vard_Dale?= <yaknorway52(at)gmail.com (yaknorway52(at)gmail.com)>
Hans,
Br
Havard
> Den 8. jul. 2016 kl. 19.32 skrev Hans Oortman <pa3arw(at)ziggo.nl (pa3arw(at)ziggo.nl)>:
> --> Yak-List message posted by: Hans Oortman <pa3arw(at)ziggo.nl (pa3arw(at)ziggo.nl)>
> Hans O.
> PH-YAK
> Op 08-07-16 18:27, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> schreef:
>> --> Yak-List message posted by: "A. Dennis Savarese"
>> //[url=tel:334-546-8182]334-546-8182[/url] (mobile)//
>> //www.yak-52.com //
>> //Skype - Yakguy1//
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
pa3arw(at)ziggo.nl
PostPosted: Fri Jul 08, 2016 11:52 am    Post subject: Yak-List: Reply with quote
Here it is:
http://www.borenco.nl/c/1_208_7295/bevestigingsmaterialen/torx-schroeven/laa
gbolkopschroeven-torx-iso-7380f-a2/
Hans O.
Hans,
Br
Havard
> Hans O.
> PH-YAK
>> //www.yak-52.com //
>> //Skype - Yakguy1//
Dawg
PostPosted: Fri Jul 08, 2016 4:12 pm    Post subject: Yak-List: Reply with quote
Makes perfect sense to me???
On Jul 8, 2016, at 13:52, Hans Oortman <pa3arw(at)ziggo.nl> wrote:
Here it is:
Hans O.
> Hans,
> Br
> Havard
>> Hans O.
>> PH-YAK
>>> //www.yak-52.com //
>>> //Skype - Yakguy1//
Dawg
