Firestar cage
Richard Pike
PostPosted: Fri Jul 01, 2016 12:25 pm    Post subject: Firestar cage Reply with quote
A friend & I have just purchased a Firestar basket case, and I will be fabricating a fuselage cage from scratch. (!?!? yes, I know I am in over my head)
If anyone has pictures of their Firestar cage prior to covering, I would really appreciate it if you would send them to me; thegreybaron(at)charter.net.
Thanks!
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
williamtsullivan(at)att.n
PostPosted: Fri Jul 01, 2016 12:34 pm    Post subject: Firestar cage Reply with quote
Firestar, or Firestar II? I built the front half of an original Firestar, but I had all of the original parts (bent!) to go off of.
Bill Sullivan
On Fri, 7/1/16, Richard Pike <thegreybaron(at)charter.net> wrote:
Subject: Firestar cage
Date: Friday, July 1, 2016, 4:25 PM
"Richard Pike" <thegreybaron(at)charter.net>
Thanks!
Richard Pike
Kingsport, TN 3TN0
Would you consider yourself to be a good person?
https://www.youtube.com/watch?v=VWcDXT6pH7A
http://forums.matronics.com/viewtopic.php?p=457607#457607
Forum -
   - MATRONICS WEB FORUMS -
MATRONICS LIST WIKI -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
Richard Pike
PostPosted: Sat Jul 02, 2016 6:10 am    Post subject: Re: Firestar cage Reply with quote
Original Firestar, 5 rib wing. The only usable cage parts are the rear verticals from the 1/2" bolt cluster up to the motor mount tube, the tube including the front and rear spar carry throughs. Also have the front tube ring with the landing gear leg sockets, it is reusable. Every other tube is severely bent, but they are there, and can probably be used for measurements.
So we will be fabricating a new cage based on the rear verticals, the top tube, and the gear leg sockets. Just hoping for some photos to keep around the workshop to help visualize better what it needs to look like, and make sure nothing gets overlooked.
It's good to be retired...
Richard Pike
Kingsport, TN 3TN0
PostPosted: Sat Jul 02, 2016 6:16 am    Post subject: Firestar cage Reply with quote
Can't remember if Bryan Melborn still has the jigs for the original FS or
not.
severely bent.
Richard Pike
Kingsport, TN 3TN0
Richard Pike
PostPosted: Sat Jul 02, 2016 6:39 am    Post subject: Re: Firestar cage Reply with quote
I don't think so. I asked Travis about that over a year ago when I first got interested in this wreck, and it seems I would have had to furnish the specs for spar pickup points, as they did not have those any more.
However, looking at various pictures online this morning, it occurs to me - why not fashion the new cage after a Firefly cage? Simpler and probably lighter.
So - if anyone has any pictures of your naked Firefly cage you would like to contribute, I would be happy to have them. Failing that, I can wait until Bryan is making one, and ride up to the factory and get some there.
Richard Pike
Kingsport, TN 3TN0
PostPosted: Sat Jul 02, 2016 7:12 am    Post subject: Firestar cage Reply with quote
Firefly fuselage was based on the original FS fuselage.
lighter.
Richard Pike
Kingsport, TN 3TN0
Richard Pike
PostPosted: Sat Jul 02, 2016 7:23 am    Post subject: Re: Firestar cage Reply with quote
Good, then they ought to be compatible. And I have found a source of all the pictures I need,
http://harnerfarm.net/serenity/serenity.html
so thanks to all you guys anyway, we can suspend this thread, I am good to go here.
Richard Pike
Kingsport, TN 3TN0
Herbgh(at)nctc.com
PostPosted: Sat Jul 02, 2016 8:01 am    Post subject: Firestar cage Reply with quote
Sorry that I did not reduce the pics....!!
forgot to mention that I have a damaged nose cone ..that can be had
for free.. Herb
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=457640#457640
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny."
Aristotle
Herbgh(at)nctc.com
PostPosted: Sat Jul 02, 2016 8:25 am    Post subject: Firestar cage Reply with quote
Bro Pike
I sent the large pics directly to you....Matronics would not allow
the size and I grew tired of trying to reduce them...more lack of
patience that being tired.!! Smile
Herb
for free.. Herb
stuart(at)harnerfarm.net
PostPosted: Sat Jul 02, 2016 10:10 am    Post subject: Firestar cage Reply with quote
Richard,
Let me know if you need any dimensions from Serenity and I will get them for
you.
Since I have no place to fly from this summer she is resting comfortably in
the camper parked in the driveway.
Stuart
Richard Pike
PostPosted: Sat Jul 02, 2016 11:42 am    Post subject: Re: Firestar cage Reply with quote
Herb; thank you so much. With what we now have to work with, it suddenly looks possible that we might actually have this thing flying by fall.
Stuart; once we start to jig things up, I will likely be pestering you.
John, thanks for all your experience.
The folks on this list are great. I am thankful to be a part of this group of people.
Richard Pike
Kingsport, TN 3TN0
Herbgh(at)nctc.com
PostPosted: Sat Jul 02, 2016 12:00 pm    Post subject: Firestar cage Reply with quote
I also have a Firefly builders manual ...around here somewhere...yep
just found it....yours too....
by the way...my not have been apparent..but spar carry through is
bent... Herb
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=457656#457656
Aristotle
Richard Pike
PostPosted: Sat Jul 02, 2016 12:36 pm    Post subject: Re: Firestar cage Reply with quote
[quote="Herbgh(at)nctc.com"]<snip> by the way...may not have been apparent..but spar carry through is
bent... Herb <snip> [quote]
Beggars can't be choosers. Besides, if you get steel hot enough, it will bend back.
Richard Pike
Kingsport, TN 3TN0
west1m
PostPosted: Sun Jul 03, 2016 4:20 am    Post subject: Re: Firestar cage Reply with quote
I am a long way from TN but I also have a slightly bent cage, wings, tail feathers , nose (not too bad shape) and a 5 pound roll of blueprints.
Firestar prints
 Filesize:  129.38 KB
 Viewed:  15822 Time(s)
West1m
Hastings, MN
Richard Pike
PostPosted: Sun Jul 03, 2016 12:05 pm    Post subject: Re: Firestar cage Reply with quote
Thanks. Let me see what we have to work with after I go collect what Herb has.
Richard Pike
Kingsport, TN 3TN0
