[Non-DoD Source] M-14P for sale
mark.bitterlich(at)navy.m
PostPosted: Mon Jun 27, 2016 8:30 am    Post subject: [Non-DoD Source] M-14P for sale Reply with quote
An oil leak from where exactly please?
Mark
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.44 KB
 Downloaded:  565 Time(s)
oaa(at)airadvantage.no
PostPosted: Mon Jun 27, 2016 11:11 am    Post subject: [Non-DoD Source] M-14P for sale Reply with quote
Nice
[quote] On 27 Jun 2016, at 18:28, Bitterlich, Mark G CIV NAVAIR, WD <mark.bitterlich(at)navy.mil> wrote:
Mark
PostPosted: Mon Jun 27, 2016 11:42 am    Post subject: [Non-DoD Source] M-14P for sale Reply with quote
Yeah, like: "Well the big hole in the side of the engine case where the piston rod hit it after it broke".
Our minds think alike, which means you should be concerned! Smile
Mark
PostPosted: Mon Jun 27, 2016 11:43 am    Post subject: [Non-DoD Source] M-14P for sale Reply with quote
Gosh, once again it dawned on me that someone might take me seriously.
It was meant as a joke, sorry if anyone thinks otherwise.
Mark
Curt_B
PostPosted: Thu Jun 30, 2016 2:46 pm    Post subject: Re: [Non-DoD Source] M-14P for sale Reply with quote
The leak is between the blower and the power section. A couple of studs wouldn't take torque. Pulled the engine to replace the studs and found a zero time one in the meantime. Our metallurgist said the studs failed in fatigue. This is a good engine, regardless of what the clowns on this site misrepresent.
Viperdoc
PostPosted: Thu Jun 30, 2016 8:41 pm    Post subject: [Non-DoD Source] M-14P for sale Reply with quote
Fatigue or over torqued?
Yes, it is an outstanding engine.
Doc
On Jun 30, 2016, at 5:46 PM, Curt_B <cbbur(at)earthlink.net> wrote:
The leak is between the blower and the power section. A couple of studs wouldn't take torque. Pulled the engine to replace the studs and found a zero time one in the meantime. Our metallurgist said the studs failed in fatigue. This is a good engine, regardless of what the clowns on this sight misrepresent.
http://forums.matronics.com/viewtopic.php?p=457568#457568
Viperdoc
Curt_B
PostPosted: Thu Jun 30, 2016 9:45 pm    Post subject: Re: [Non-DoD Source] M-14P for sale Reply with quote
Fatigued. The metallurgist showed the striation propagation, crack growth, typical of fatigue. The stud elongation caused it to lose torque. When I went to re-torque to stop the oil leak, the remaining 5-10 percent of the intact cross sectional area failed. Looked at the break, didn't see the tattletale 45 deg fracture typical of torsion failure and asked the metallurgist. He said the fatigue occurred over a significant amount of time. Thanks.
Curt_B
PostPosted: Fri Jul 01, 2016 5:46 am    Post subject: Re: [Non-DoD Source] M-14P for sale Reply with quote
This is not my ad and these are fantastic engines. Please refer to
http://forums.matronics.com/viewtopic.php?t=16762702
for discussion and replies and ignore this thread that should be deleted. Thanks.
