vernon.franklin(at)gmail. Guest
Posted: Wed Jun 15, 2016 11:10 am Post subject: Attaching the Wings |
I am attaching the wings here in a week or so. Are there any tips, tricks, advice you guys can give on getting everything lined up just right? Anything I should look out for?
How many people should I recruit to pull this off?
I am assuming when I get the first wing attached, I will have to support that side while attaching the other side, so the plane doesn't tip over. Or does it stay on all 3?
Vernon Franklin
Lew Gallagher
Joined: 04 Jan 2008 Posts: 402 Location: Greenville , SC
Posted: Wed Jun 15, 2016 11:26 am Post subject: Attaching the Wings |
Hey Vernon,
Short answer: two people, doesn’t tip over, expect the bolts to be very tight (for trial fit use regular bolts). We balanced the wing on a support so that one guy on the end could easily lift or lower the tip, while the other guided bolts in. You’ll get lots of ideas about final bolts on dry ice to easier insert, etc. We found that on ours, there was a tiny misalignment of the outer layer of the main spar that prevented the final bolts going in smoothly. Not really a big deal – have at it!
Later, – Lew
From: Vernon Franklin (vernon.franklin(at)gmail.com)
Sent: Wednesday, June 15, 2016 3:09 PM
Subject: Attaching the Wings
Vernon Franklin
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
jeff(at)westcottpress.com Guest
Posted: Wed Jun 15, 2016 11:30 am Post subject: Attaching the Wings |
Other than getting help putting the wings up on to saw horses I was able to do it myself. Just take your time and be sure to make and use the drift pins that are mentioned in the plans.
Jeff Carpenter
40304
Fly-off
On Jun 15, 2016, at 12:09 PM, Vernon Franklin wrote:
| Quote: | I am attaching the wings here in a week or so. Are there any tips, tricks, advice you guys can give on getting everything lined up just right? Anything I should look out for?
Vernon Franklin
Westcott Press
1121 Isabel Street
Burbank, CA 91506
818-861-7300
85.32 KB |
6263 Time(s) |
83.2 KB |
6263 Time(s) |
Posted: Wed Jun 15, 2016 11:41 am Post subject: Attaching the Wings |
I like doing it with 4 people, one to hold the wingtip, one on the trailing edge, one on the leading edge and one to put the bolts in. The guy on the wingtip will need to move up, down, forward and aft to get the holes lined up. The guy on he trailing edge will need to spread the rear spar attach points to get the rear spar in (don't pin the rear spar until the main spar bolts are in). It will sit on the wheels with one wing on. No support needed as long as there is no fuel in it.
If you can find some old bolts the right size for the larger or smaller main holes, cut off the head and make a bullet out of it and drive that through and follow it with the bolt with the shaft greased.
Be careful with the outboard bolts where they can hit the fuel tank fittings.
Two bolts (one top and one bottom) will hold the wing so you can move to the other side and cut your helpers loose.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
| Quote: | On Jun 15, 2016, at 3:09 PM, Vernon Franklin <vernon.franklin(at)gmail.com> wrote:
Vernon Franklin
Kelly McMullen
Posted: Wed Jun 15, 2016 12:35 pm Post subject: Attaching the Wings |
I used saw horses that I could move back and forth to align. Moveable cart might have been easier. I had misalignment of spar web, thanks to quick build, I guess. Had to talk to Vans on how to correct without affecting the hole in main spar. Used ordinary bolts with threads ground off for pilot alignment. Used plenty of LPS 3 to make things go together. Installed the close tolerance bolts after soak in dry ice, and lube. Still snug.
-sent from the microchip implanted in my forearm
On Wed, Jun 15, 2016 at 12:25 PM, <lewgall(at)charter.net (lewgall(at)charter.net)> wrote:
| Quote: | Hey Vernon,
Later, – Lew
Vernon Franklin
A&P/IA, EAA Tech Counselor
KCHD |
stef601(at)att.net Guest
Posted: Wed Jun 15, 2016 6:47 pm Post subject: Attaching the Wings |
Take the fuel tanks off, and dry ice the bolts for 6 hrs.
On Jun 15, 2016, at 12:25 PM, <lewgall(at)charter.net (lewgall(at)charter.net)> <lewgall(at)charter.net (lewgall(at)charter.net)> wrote:
Later, – Lew
Vernon Franklin
=================================== ://www.matronics.com/Navigator?RV10-List =================================== cs.com =================================== om =================================== matronics.com/contribution ===================================
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Wed Jun 15, 2016 7:09 pm Post subject: Re: Attaching the Wings |
Not sure why you would take the fuel tanks off. "Follow the directions" is the best advice I have seen on this forum.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
