civengpe
Posted: Tue Jun 14, 2016 6:02 am Post subject: Oil temps |
The other thread talking about cowl flaps got me rethinking another kind of cooling issue that I am having. I can't get my oil temps to climb above 140. It doesn't matter how hot it is outside or how long I climb, they top out right at 140. Could this be caused by me having a plenum and having too much air flow through the oil cooler? The probe registers ambient temperature correctly when not running, so it seems to be accurate in that regard. Can a faulty vernatherm cause this?
Any ideas?
Shannon
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Tue Jun 14, 2016 6:27 am Post subject: Oil temps |
I wouldn't believe the 140.
Sent via the Samsung Galaxy S® 6, an AT&T 4G LTE smartphone
-------- Original message --------
Date: 6/14/16 7:02 AM (GMT-07:00)
Subject: RV10-List: Oil temps
Any ideas?
Shannon
_________________ Don A. McDonald
40636 |
Posted: Tue Jun 14, 2016 6:32 am Post subject: Oil temps |
Run it into a pot of boiling water and see what it reads. First thing is to verify the probe is working correctly.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
| Quote: | On Jun 14, 2016, at 10:02 AM, Shannon Hicks <civeng123(at)gmail.com> wrote:
Any ideas?
Shannon
Posted: Tue Jun 14, 2016 7:41 am Post subject: Oil temps |
In non-summer conditions I had the same problem - just couldn't get the
oil temp up to the minimum.
It seems that the combination of running less oil (6-7 quarts) and
blocking some of the airflow to the cooler with a plate installed in the
engine shroud fixed it. I don't recall ever changing the oil temp probe.
No change is required for NC/FL summers but I do reduce the size of the
blocking if I remember and run another quart of oil in summer.
Bill "found the stock setup to run very cool except for the tunnel" Watson
On 6/14/2016 10:02 AM, Shannon Hicks wrote:
| Quote: | The other thread talking about cowl flaps got me rethinking another
Any ideas?
Shannon
Albert Gardner
Posted: Tue Jun 14, 2016 12:39 pm Post subject: Oil temps |
I added another opening on each side to improve oil cooling. I also have an additional oil cooler. Seems to be good enough now for Yuma's hot, hot weather.
Albert Gardner
RV-10 N991RV
Yuma, AZ
23.15 KB |
4786 Time(s) |
RV-10 N991RV |
