Saggy bus voltage on Cessna 182
Goto page 1, 2  Next
alec(at)alecmyers.com
PostPosted: Thu Jun 02, 2016 6:03 am    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
Hello all,
I wonder if I could get some ideas on fixing an electrical issue with my 1975 Cessna 182.
The issue is that the bus voltage sags under load. With the engine running and no electrical load the voltage is approximately 13.8V, dropping to 13.2V with daytime load (beacon, avionics, engine monitor, electrical TC, autopilot) and with night time lighting (add strobes, position lights, LED landing and taxi lights, instrument lights) it drops to 12.8V.
During flight the battery isn't fully charging and the engine start for the next flight I would describe as "reluctant". If I top off the battery from a line voltage charger for a few hours the next engine start is "enthusiastic".
I have had the alternator serviced, and I have replaced the regulator. I have put a 'scope on the bus with the engine running and I see steady dc with about 50mV pp of ripple. I have a photograph of the scope trace, not sure how best to make it visible to list readers, but the ripple looks like a rectified AC waveform with no gaps (gaps I think would indicate a failed diode).
Can anyone suggest where I could look next?
Thanks for any suggestions
Alec
ceengland7(at)gmail.com
PostPosted: Thu Jun 02, 2016 8:25 am    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
On Thu, Jun 2, 2016 at 8:08 AM, Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
--> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)>
Hello all,
Alec
Can you get voltmeter probes *directly on* the alternator B lead post & case? Not on the bolts, clamps etc, but directly on the post. Measure voltage there with the engine running & loads off, then on.
Sounds like the alternator is supplying ~the right voltage (possibly just a bit low). But if you have high resistance connections anywhere between the alternator and the loads (on the B+ side *or* the ground side paths), the loads may not be seeing the full alternator voltage. If you have an issue with high resistance connections, the voltage from alternator B terminal to case will still be at 13.8 but your bus (and battery) voltage will be lower, due to voltage drops in the high resistance connections.
Secondary possibility would be the same issue, but in the field circuit from regulator to field terminal on the alt.
Charlie
clr(at)redingaviation.com
PostPosted: Thu Jun 02, 2016 8:37 am    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
Im not an expert but I would look for corrosion around grounds. Make sure all of your grounds are good.
Craig
On Jun 2, 2016, at 9:08 AM, Alec Myers <alec(at)alecmyers.com> wrote:
Hello all,
Alec
art(at)zemon.name
PostPosted: Thu Jun 02, 2016 8:56 am    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
I hate it when that happens. It's bad enough when old pilots sag but we should be able to depend on our airplanes staying __. 😋
    -- Art Z.
Sent from my phone so please excuse typos and brevity.
kjashton(at)vnet.net
PostPosted: Thu Jun 02, 2016 9:42 am    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
To add to what Charlie said, It sounds like a battery load-test is in order. A place like Batteries Plus can do one for you. Also Skytec has a good explanation of how to check for a high resistance that results in voltage drop.
http://www.skytecair.com/troubleshooting.htm
-Kent
On Jun 2, 2016, at 11:37 AM, Charlie England <ceengland7(at)gmail.com> wrote:
On Thu, Jun 2, 2016 at 8:08 AM, Alec Myers <alec(at)alecmyers.com> wrote:
Hello all,
Alec
Charlie
PostPosted: Thu Jun 02, 2016 11:00 am    Post subject: Re: Saggy bus voltage on Cessna 182 Reply with quote
If the regulator has I A S F terminals, measure the voltage between terminal S and the regulator case with the engine running. If 14 to 14.5 volts, the regulator and alternator are working OK.
With engine running and all electrical loads turned on, measure the voltage between the positive battery terminal and the alternator "B" terminal. The voltage drop should be less than a few tenths of a volt. If more, then check all connections between alternator B terminal and battery positive. Also check all ground connections, especially regulator ground, engine ground strap and battery ground.
Joe Gores
PostPosted: Thu Jun 02, 2016 11:45 am    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
Hello all,
The factory spec set point for those regulators
is 14.2 +/- 0.2 volts . . . After engine start
and before turning on any additional loads, the
BUS voltage should be within those limits.
This observation rules out soggy battery. Given
the voltages you've reported, battery performance
sans external supports is understandable. A
battery will not accept significant energy
at bus voltages below 13.8 . . . and even at 13.8
it would take HOURS to top it off. This is why
the slightly excessive set-point is the legacy
value of 14.2 was selected for flooded lead-acid
batteries . . . 'slight' overcharge that quickly
tops off battery without serious 'damage'.
The sealed vented lead-acid (SLVA) likes to be
charged more aggressively . . . excerpts from
the Hawker data says:
[img]cid:.0[/img][/b]
This fact drives the B&C policy decision to factory
set their regulators to 14.6 volts.
Yes . . . and it is simple . . . just not easy. You need
to get a voltmeter reading at the "S" and "F" terminals
of your regulator with the engine running. "VS" should
be the 14.2 +/- 0.2 volt value (or what ever is presently
presented on the regulator's name-plate) and "VF" should
be substantially larger than zero but NOT pegged against
the bus . . . if it is pegged, then increase RPM to see
if the voltage comes off the peg.
This reading is WAAaayyy low. It should be on the order
of 1.5 volts pk-pk. 3 phase rectified DC is predicted
to have an RMS ripple voltage on the order of 4% of the DC
output. Hence 14 X 0.04 = 560 mVrms and approx 3x that
pk-pk.
If the bus voltage is that 'clean' then I think you're going
to find that the field voltage is essentially zero. Depending
on what you fine for "VS", there's probably a wiring disconnect
somewhere along the path from Bus through the alternator switch
to the OV sensor, out to the regulator and on to the alternator
"F" terminal.
Having the voltage measurements I suggested will 'divide' the
enemy in the battle toward submission.
Finally, once the stock regulator is working, you may want
to consider a more modern ADJUSTABLE device that can be
set to accommodate the special needs of SVLA batteries.
 Filesize:  483.48 KB
 Viewed:  16809 Time(s)
PostPosted: Fri Jun 03, 2016 6:22 am    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
I started by looking at the voltage at the regulator terminals, which is a thousand times easier to reach than the alternator. I took four measurements, at idle RPM and 1600RPM, lights off and lights on.
idle (lights off/lights on)
V_bus 13.6 / 13.2
V_F 5.56 / 9.09
V_S 12.87 / 12.34
V_A 13.89 / 13.79
1600RPM (lights off/lights on)
V_bus  13.6 / 13.2
V_F 4.02 / 7.72
V_S 12.77 / 12.38
V_A 13.99 / 13.78
It's a 14v regulator.
Note: the bus voltage is displayed on the engine monitor, the others are measured with my Fluke.
Does this shed any light?
On Jun 2, 2016, at 15:43, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Hello all,
<ea42f08.jpg>
pk-pk.
"F" terminal.
PostPosted: Fri Jun 03, 2016 8:16 am    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
V_bus 13.6 / 13.2
V_F 5.56 / 9.09
V_S 12.87 / 12.34
V_A 13.89 / 13.79
V_bus 13.6 / 13.2
V_F 4.02 / 7.72
V_S 12.77 / 12.38
V_A 13.99 / 13.78
Interesting . . .
Okay, the fact that your field voltages are responding
to load changes and not 'stuck on a rail' says the
regulator is actively controlling alternator behavior.
Voltage behaviors for loads-off/on suggest that the
alternator is shouldering the loads albeit at magnitudes
less than ideal.
If I recall correctly, Vs comes through the ov
protection module which explains the approx
1 volt lower value than Va which comes directly from
the bus.
Va and Bus voltages should be closer together,
You might get a reading of bus voltage with
the Fluke to compare with what's displayed
on the engine monitor . . . but the difference
doesn't explain the chief complaint.
The fact that your Va value (bus sense to
the regulator) is so close to 14.0 (lower limit
of spec) suggests that this regulator may
have passed acceptance testing at the factory
but given that it IS low yet actively controlling
the alternator suggests that it's simply set
too low . . . but not as low as bus volts reading
on your engine monitor suggests.
Do you have the service manual for this airplane
hence, access to the applicable alternator wiring
diagram? My recollections are 40+ years old
and may indeed be in error. If you don't have
the applicable wiring diagram, I can call my
'mole' at Textron and get the drawing. It would
also be useful to get the part number off the
regulator.
I'm puzzled by the 'scope readings you cited but
again, given the values you collected above,
the ripple numbers are not germane to the
chief complaint either.
Given that this is a new regulator, I'm not
ready to jump on the defective regulator diagnosis
quite yet but the numbers sure do point in
that direction . . .
How old is your battery and what type . . .
flooded or RG? What is the s/n of the
airplane?
PostPosted: Fri Jun 03, 2016 11:30 am    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
I'm going to look for a high impedance connection between the A terminal of the alternator and the bus: the regulator is seeing 13.8V at A, but with the load current flowing from A to the bus the bus voltage is 0.6v lower, at the other end of a thick cable and 60A breaker.
On Jun 3, 2016, at 12:13, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
V_bus 13.6 / 13.2
V_F 5.56 / 9.09
V_S 12.87 / 12.34
V_A 13.89 / 13.79
V_bus 13.6 / 13.2
V_F 4.02 / 7.72
V_S 12.77 / 12.38
V_A 13.99 / 13.78
Interesting . . .
less than ideal.
the bus.
regulator.
airplane?
PostPosted: Fri Jun 03, 2016 6:35 pm    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
I worked through the wiring from the B lead post on the alternator. The wiring goes from the alternator post, to some kind of filter bolted to the engine side of the firewall (which doesn't appear in the Cessna service manual wiring diagrams) then to the 60 amp alternator CB, then to the bus.
The voltage on the alternator B lead post is the same 13.9V (13.8V with heavier load) that I see on the A terminal of the regulator.
I looked at the voltage drop along the B current path: it's about 100mV per terminal - there doesn't appear to be one connection that's any worse than the others.
There's also about 150-200mV drop across the 60 amp CB, when the bus is loaded up. The terminal screw also gets hot - nearly too hot to touch. Is this expected? It's a thermal-type breaker but I don't know how warm they are intended to get, outside an overload condition.
I'm stumped on two questions:
Why, although the regulator field terminal voltage is well within normal operating range (4-7v), the regulated voltage is low at 13.8 to 13.9V. This is the case with two different regulators.
Secondly why I'm losing 0.6V, distributed equally across four crimp terminals and a CB. I'm going to estimate the current at 20 amps, including LED landing and taxi lights, halogen position and beacon lights, strobes, pitot heat and full avionics bus, and recharging the battery soon after cranking. Is this to be expected?
Charlie
millner(at)me.com
PostPosted: Fri Jun 03, 2016 7:36 pm    Post subject: saggy bus voltage on Cessna 182 Reply with quote
Cessna only installed that filter on airplanes that had the "avionics"
package... so the filter is found in the "Avionics" manual for your year
range of airplane. The Avionics manuals were typically for the entire
100 series (150/152, 172, 177/RG and 182). Some manuals covered two or
three model years. There are free scans online, include lots of little
details you won't find elsewhere.
Nope... sure sign of resistance there. You can start by breaking both
connections to the breaker, cleaning them up to shiny, and reassembling
them wetted with ACF50 or CorrosionX. But the breaker itself may be
developing high resistance, and needs replacement. There's a series of
service bulletins on that breaker... it was a problem. Aircraft Spruce
and others have aftermarket breakers for that service.
Paul
PostPosted: Sat Jun 04, 2016 4:25 am    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
Yea, that seems excessive. An easy experiment
to run is install a simple, 4AWG welding cable
jumper from alternator b-lead to the hot side
of the starter or battery contactors (I believe
your battery is up front in that a/c?). Bypass
the normal ships wiring and see what the effects
are.
PostPosted: Sat Jun 04, 2016 4:44 am    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
At 09:30 PM 6/3/2016, you wrote:
--> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com>
b-lead filters were marginally effective
in suppressing some noises in the ADF.
The capacitors on most wiring diagrams
of that era were flagged as part of the
ADF installation kit and often did not
show on the production line as-manufactured
documents.
At the current levels you're running during
ground tests, that breaker shouldn't warm up
to the touch. Those were the least expensive
breaker Cessna could put their hands on and
with all due respect, the one in your airplane
has probably delivered fair value.
If this were my airpalne, I'd do a 337 mod
to take the b-lead to the starter contactor
through an ANL60 current limiter per common,
modern practice. Dump the filter . . . even
if there IS some observable noise in your ADF,
it's unlikely to be a performance issue for
its utility.
That would reduce the number of joints and
greatly reduce the voltage drop from b-lead
to bus.
I'm with you. Are these 'original' electro-mechanical
regulators or an aftermarket, electronic replacement?
No . . . that's a lot more than factory new.
Recall that the 'galloping ammeter' phenomenon
common to those aircraft has root cause in
the build up of resistance in the bus to regulator
"A" terminal that eventually forces a negative
resistance in the dynamics of the voltage regulator
loop. This is common on older airplanes where
voltage sense -AND- field supply current share
the same feed wire.
Many mechanics replace something . . . often
the split rocker switch . . . and the problem
goes away. The customer is momentarily satisfied
that the ammeter stops hopping around. But the
fix is temporary in that the fix reduces the loop
resistance just below the point of instability.
The problem will return. The elegant fix is to
renew every metallic joint in that loop from
bus bar to "A" terminal. THEN the problem is
held off for another 30-40 years.
I suspect your 60A breaker is demonstrating
effects of age with increased resistance that
promotes the heating you've observed.
The REAL fix is to install an after market
regulator with separate Field Supply and
Bus Sense leads.
If your old and new regulators are electro-mechanical,
there may be a case for long term storage
drift of set point in a downward direction.
I've never had occasion to study the effects
of long term storage on new old-stock components.
The real acid test would be to run the regulator
on a test stand independent of all effects
of aged wiring in the a/c. But it IS a
vexing puzzle.
PostPosted: Sat Jun 04, 2016 6:01 am    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
Alas, Canadian airplane so no 337 type process available...
Both old and new regulators are Lamarr, solid state.
With "lights on", I used the service manual electrical loads table to calculate the current draw on the alternator at close to 50amps (vice my previous estimate at 20): pitot heat, strobes, position lights, beacon and avionics all use more current than I thought.
Paul Milner kindly pointed me to the Cessna service kit to replace the 60 amp CB, which involves shortening the bus bar so the replacement breaker will fit. I think the approved breaker is $400 or thereabouts, so if it does need replacing, does anyone know a PMA alternative?
On Jun 4, 2016, at 08:42, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
documents.
its utility.
to bus.
the same feed wire.
Bus Sense leads.
vexing puzzle.
millner(at)me.com
PostPosted: Sun Jun 05, 2016 3:22 pm    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
- Paul Millner kindly pointed me to the Cessna service kit to replace the 60 amp CB, which involves shortening the bus bar so the replacement breaker will fit. I think the approved breaker is $400 or thereabouts, so if it does need replacing, does anyone know a PMA alternative?
Nowadays, we consider breakers standard electrical parts, and under the advisory circular guidance, they don't require special approvals. I understand Transport Canada may not have gotten to that point yet. That said, Aircraft Spruce (even the Canadian flavour of same) have several attractive offerings... You don't have to buy your wire and PIDG terminals from Cessna with PMA do you?
BTW, at least one of the service bulletins is: SE76-15-Replacement of Alternator Circuit Breakers (S1596-60L)
Paul
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman",serif;} <![endif]-->
PostPosted: Wed Jun 08, 2016 7:07 pm    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
Fooey . . .
Aha! Are they not adjustable?
Hmmmm . . . your most economical route
would be to 'refurbish' . . . replace
as much of the parts with made-up, metal
to metal joints from the bus to the b-terminal.
PostPosted: Wed Jun 08, 2016 7:43 pm    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
There is an adjustment inside the regulator. The newer regulator has the lid riveted on, but the older one (same part code) has the lid secured by screws, so the trim pot can be reached. Set to maximum, I now get a bus voltage of 14.2V under no load, and 13.8 with everything energized. Which is a big improvement.
I have sourced a new breaker - as you pointed out, it's a standard electrical part - I'll let you know what the results are when it's installed.
On Jun 4, 2016,:00, Robert L. Nuckolls, III e <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Fooey . . .
PostPosted: Thu Jun 09, 2016 6:34 pm    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
But still too low . . . it shouldn't sag
that much under load.
PostPosted: Thu Jun 09, 2016 6:57 pm    Post subject: Saggy bus voltage on Cessna 182 Reply with quote
Tyco quote a resistance of 20mOhms for their 50A breaker. I just put the new 60A (not Tyco) breaker on the bench for a four terminal resistance check, and measure about 30mOhms - at 50A that's a 0.15 volt drop (and 7 watts of heat, which should warm it up). I'm seeing not much more than that on the existing installed original breaker, so I'm not sure how much better the new breaker will be.
On Jun 9, 2016, at 22:32, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Goto page 1, 2  Next
Page 1 of 2
