Use iridium spark plugs was what oil??
DBforfun
PostPosted: Mon May 23, 2016 4:56 pm    Post subject: Use iridium spark plugs was what oil?? Reply with quote
I switched to iridium spark plugs in my Rotax 447 and noticed a significant difference in a smoother running engine with less mis-fires.
The powered paraglider guys were saying that they have virtually eliminated spark plug fowling by switching to iridium plugs.
One thing on oil that is important if you buy Pennzoil is make sure you get 2 stroke AIR COOLED engine oil and not 2 stroke oil for your outboard motor. Water cooled outboards run cooler than air cooled engines.
In a message dated 5/23/2016 2:16:25 P.M. Pacific Daylight Time, stuart(at)harnerfarm.net writes:
--> Kolb-List message posted by: "Stuart Harner" <stuart(at)harnerfarm.net>
Mine is a 447 with electronic single ignition.
Amzoil Super Saber Professional 100:1 mix ratio. Recommended by the shop
foreman at LEAF in Wisconsin.
Phil Lockwood (Lockwood Aviation) recommends Pennzoil 2 stroke air cooled
oil. Go figure.
They both recommend using Stabil fuel stabilizer to help keep the gas fresh
longer. I use this too.
Only 20 hours on mine so far. All OK. Carbon buildup is minimal. Just
replaced the plugs coming out of storage for the winter. Looked good but why
put them in for a lousy 5 hours before the recommended replacement?
I would look into upgrading the ignition system if at all possible.
Your engine must have some years on it. Hope it was stored properly.
-----Original Message-----
[mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of flywithme
Sent: Monday, May 23, 2016 4:04 PM
Subject: what oil??
--> Kolb-List message posted by: "flywithme" <constrjh(at)pldi.net>
I am new to the Rotax engine. I have a 447 points ignition engine on my
Firefly. what oil do you fellow Kolbers use in your Engines? why?
http://forums.matronics.com/viewtopic.php?p=456511#456511================================================ the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - NEW MATRONICS LIST WIKI -_-= - List Contribution Web Site sp;   ===================================================
