turbot
Posted: Wed May 11, 2016 8:06 am Post subject: leaking fuel selector valve |
Last fall the fuel selector valve below the panel started to leak on my model 2.
Is there a common model selector used on model 2 s ? Am wondering if its rebuildable or needs to be replaced ?
Reason I ask is that the plane is stored an hour away & would like to do a bit of research on the valve before heading out to take it out of storage.
thanks
Guy Buchanan
Posted: Wed May 11, 2016 10:13 am Post subject: leaking fuel selector valve |
Definitely no common valve. Do you have a picture of it?
Guy Buchanan
On May 11, 2016, at 9:05 AM, TURBO T <turbot(at)shaw.ca (turbot(at)shaw.ca)> wrote:
thanks
Deceased K-IV 1200
A glider pilot too. |
poasttown(at)yahoo.com Guest
Posted: Wed May 11, 2016 6:31 pm Post subject: leaking fuel selector valve |
I have a model IV and if I remember correctly my fuel valve has a small access plate at the fuel selector knob. And behind this plate is a O ring. I think I may have damaged this O ring by repeated turning the valve on and off during the build process.
Mike Chaney
1996 Kitfox IV/Jabiru 2200
On May 11, 2016, at 2:12 PM, Guy Buchanan <gebuchanan(at)cox.net (gebuchanan(at)cox.net)> wrote:
| Quote: | Definitely no common valve. Do you have a picture of it?
Guy Buchanan
thanks
| D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D x-List"">http://www.matronics.com/Navigator?Kitfox-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D wiki.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
