ANL Fuse Rating
PostPosted: Wed May 18, 2016 1:09 am    Post subject: ANL Fuse Rating Reply with quote
I have a 70 amp alternator and have a D180 with the dynon shunt. I also have a ANL-60 protecting the layout....should I replace that with a ANL-80?
Don
The above was posted on VansAirforce by Don. I replied that 60 amp ANL should work fine. But decided to post it on the AeroElectric list to get more qualified opinions.
http://www.mouser.com/ds/2/87/Bus_Ele_DS_2024_ANL-348888.pdf
Joe
Joe Gores
PostPosted: Wed May 18, 2016 12:28 pm    Post subject: ANL Fuse Rating Reply with quote
No, 60A will be fine. As you can see below,
even an ANL50 would not be severely stressed by
a 70A alternator . . .
[img]cid:7.1.0.9.0.20160518152152.01ef2328(at)aeroelectric.com.0[/img]
 Filesize:  285.31 KB
 Viewed:  4596 Time(s)
PostPosted: Wed May 18, 2016 1:02 pm    Post subject: Re: ANL Fuse Rating Reply with quote
Thanks Bob
Joe Gores
