wdaniell.longport(at)gmai Guest
Posted: Tue May 10, 2016 4:11 am Post subject: Do engine bay wires need to be protected from heat? |
I am installing a dynon and the EGT wires come protected with steel braid.
Do the CHT, Oil temp and Oil press etc need to be protected in some way? If so how?
All is tefzel wire.
Many thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
Burrilla
Posted: Tue May 10, 2016 4:46 am Post subject: Do engine bay wires need to be protected from heat? |
I have all my cables grouped and held by spiral wrap and routed away from the exhaust. Apart from that I have no other protection in place.
The only wiring problem I had in the engine bay was a worn through inner wire of an EGT probe which shorted to the outer braid.
Alan
G-OBJT
On 10 May 2016, at 13:10, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
| Quote: | Do engine bay wires need to be protected from heat?
All is tefzel wire.
Many thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
Posted: Tue May 10, 2016 5:52 am Post subject: Do engine bay wires need to be protected from heat? |
Alan
Will On May 10, 2016 7:49 AM, "Alan Burrill" <alanb(at)dpy01.co.uk (alanb(at)dpy01.co.uk)> wrote: | Quote: | I have all my cables grouped and held by spiral wrap and routed away from the exhaust. Apart from that I have no other protection in place.
Alan
G-OBJT
All is tefzel wire.
Many thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
rlborger(at)mac.com Guest
Posted: Tue May 10, 2016 6:18 am Post subject: Do engine bay wires need to be protected from heat? |
William,
Like Alan I have grouped my wiring and run it in the coolest area possible (above the engine). But, rather than spiral wrap, I have used cable ties to bundle it and tie it down. So far, so good.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On May 10, 2016, at 7:10 AM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
All is tefzel wire.
Many thanks
Will
William Daniell
LONGPORT+57 310 295 0744
