Jim Butcher
spcialeffects
PostPosted: Fri Apr 22, 2016 6:53 am    Post subject: Jim Butcher Reply with quote
I am wanting to contact a mr Jim Butcher regarding his development and/or sales of the second alternator which fits and runs off the rear of the rotax engine. If someone could post his current email address that would be great or better still if he's reading this please contact me.
Many thanks Frank X, classic kit #165
h&jeuropa
PostPosted: Fri Apr 22, 2016 12:40 pm    Post subject: Re: Jim Butcher Reply with quote
Frank,
Here I am.
I removed the second alt a few years ago. The coupling eventually failed. By being careful about power requirements, I use only about 10 amps in flight.
My Europa is IFR with Garmin 430, Garmin 327, Garmin 340, two GRT Sport EFIS. I have LED position and strobe lights. No autopilot. No pitot heat.
If you want, I have drawings and details about mounting alternator to rear of engine but I don't think it is necessary.
Jim Butcher
jan_de_jong(at)casema.nl
PostPosted: Fri Apr 22, 2016 1:01 pm    Post subject: Jim Butcher Reply with quote
There's this too:
http://www.flygas.info/en/kit-double-alternator-for-rotax.html
No idea about pros and cons. But not cheap.
Jan de Jong
On 4/22/2016 10:40 PM, h&jeuropa wrote:
Frank,
Here I am.
Jim Butcher
http://forums.matronics.com/viewtopic.php?p=455345#455345
rampil
PostPosted: Sat Apr 30, 2016 3:47 am    Post subject: Re: Jim Butcher Reply with quote
I have been using a second alternator on the accessory takeoff for more
than 12 years with out a problem. The alternator is from a Geo Metro
3 cyl. Back in the day, Flightcrafters had someone local in the Tampa
area who milled the face plate to mate to the back of the gear box takeoff.
Perhaps Bud retains the source's contact info.
I found the 2nd alt to be very useful for piece of
Mind since I have an entirely glass panel and did
Night ops frequently.
Ira N224XS
spcialeffects
PostPosted: Sat Apr 30, 2016 11:43 am    Post subject: Re: Jim Butcher Reply with quote
Rampil, what is the output (amps) of your second alternator?
