SHT3x Digital/Analog Humidity Sensors - Sensirion | DigiKey
stuart(at)stuarthutchison
PostPosted: Tue Apr 26, 2016 4:21 am    Post subject: SHT3x Digital/Analog Humidity Sensors - Sensirion | DigiKey Reply with quote
G’day Bob,
Do you reckon it would be easy to build a circuit accommodating these new humidity sensors (digital and analogue options) for an engine dehumidifier that automatically switches between an aquarium pump and an incandescent heat bulb dry out the silica desicant?
http://www.digikey.com.au/en/product-highlight/s/sensirion/sht3x-digital-and-analog-humidity-sensors?WT.v_sub=6908894&WT.mc_id=em_NPA1604B.AU.Send&WT.z_email=6249_NPA1604BI0AU_supplier6image--1649-Sensirion&mkt_tok=eyJpIjoiTmprME9HVXlaR0pqWVRjeiIsInQiOiJlSGlHNGpRbzFVMVwvbmJHMFppZmNUSG9INmphQnJWZjRlWWRHZ09uWGNONWxPcVlGaStzRFpGVGZSMTdBZ1FpVVFNQUxhZHRYU0UwVjBQME41Wng2VFwvZEg5ajI3YWZoNk9BdlJLZk5oNTJzPSJ9
Cheers, Stu
kjashton(at)vnet.net
PostPosted: Tue Apr 26, 2016 5:42 am    Post subject: SHT3x Digital/Analog Humidity Sensors - Sensirion | DigiKey Reply with quote
Pardon me for sidestepping your question but it might be simpler to make a dehydrator with an ammo can, the aquarium pump you mention, and use a light timer for a few hours a day. The silica will work for months and can be dried in the oven fairly quickly and reused. Pics below. I have had to replace a low-time cam and lifters due to rust. When I come back from flying, I blow the moisture out of the engine with a small air-mattress pump and hook up the dehydrator. I wrapped the pump in screen wire and put it in a bag to breath; cover it with the silica gel. 500g silica packs are pretty cheap on ebay.-Kent
On Apr 26, 2016, at 8:20 AM, Stuart Hutchison <stuart(at)stuarthutchison.com.au (stuart(at)stuarthutchison.com.au)> wrote:G’day Bob,Do you reckon it would be easy to build a circuit accommodating these new humidity sensors[img]cid:DC3BC08E-1E8E-450A-99E8-FBB1A405390E[/img][img]cid:FB6E7894-7C0E-451A-BBE1-33B98040AC75[/img]
 Filesize:  69.73 KB
 Viewed:  1940 Time(s)
 Filesize:  58.29 KB
