west1m
Joined: 19 Apr 2014 Posts: 155 Location: Hastings, MN
Posted: Fri Apr 22, 2016 2:35 pm Post subject: Once around, It's Spring! |
Just a short video around the field to prove it's spring in Minnesota!
It was a bit windy for me to adventure any further.
https://vimeo.com/163883484 password KRNH447
_________________ West1m
Hastings, MN |
lcottrell
Posted: Fri Apr 22, 2016 2:47 pm Post subject: Once around, It's Spring! |
Thanks for the video. Send me a picture of where you have the camera mounted when you get a chance. You noticed of course that it camera settled down when you throttled back.
It looked a bit like spring there. Yesterday here is SE Oregon it was 86 degrees yesterday, today the winds were 40 MPH.
Larry
On Fri, Apr 22, 2016 at 4:35 PM, west1m <west1m(at)hotmail.com (west1m(at)hotmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: "west1m" <west1m(at)hotmail.com (west1m(at)hotmail.com)>
West1m
Hastings, MN
http://forums.matronics.com/viewtopic.php?p=455350#455350
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
The older I get, the less tolerant I am of those who are intolerant of others.
west1m
Posted: Fri Apr 22, 2016 3:04 pm Post subject: Re: Once around, It's Spring! |
I mounted it on the nose, attached on a plate above the "P" tube
| Description: |
| Filesize: |
23.86 KB |
| Viewed: |
4116 Time(s) |
| Description: |
| Filesize: |
91.4 KB |
| Viewed: |
4116 Time(s) |
Hastings, MN |
lcottrell
Posted: Fri Apr 22, 2016 3:13 pm Post subject: Once around, It's Spring! |
Thanks for the pictures, that was fast. Is it "springy"? The more solid it is the better the video. Other wise you will have to figure what RPM gives you less jumpy video. I used a 1x1/8th flat stock about 5 inches long, twisted 180 so that I could use a hole drilled in the side to secure the cradle.
Thanks again,
Larry
On Fri, Apr 22, 2016 at 5:04 PM, west1m <west1m(at)hotmail.com (west1m(at)hotmail.com)> wrote:
