Once around, It's Spring!
west1m
PostPosted: Fri Apr 22, 2016 2:35 pm    Post subject: Once around, It's Spring! Reply with quote
Just a short video around the field to prove it's spring in Minnesota!
It was a bit windy for me to adventure any further.
https://vimeo.com/163883484 password KRNH447
West1m
Hastings, MN
lcottrell
PostPosted: Fri Apr 22, 2016 2:47 pm    Post subject: Once around, It's Spring! Reply with quote
Thanks for the video. Send me a picture of where you have the camera mounted when you get a chance. You noticed of course that it camera settled down when you throttled back.
It looked a bit like spring there. Yesterday here is SE Oregon it was 86 degrees yesterday, today the winds were 40 MPH.
Larry
On Fri, Apr 22, 2016 at 4:35 PM, west1m <west1m(at)hotmail.com (west1m(at)hotmail.com)> wrote:
--> Kolb-List message posted by: "west1m" <west1m(at)hotmail.com (west1m(at)hotmail.com)>
West1m
Hastings, MN
http://forums.matronics.com/viewtopic.php?p=455350#455350
WIKI -
west1m
PostPosted: Fri Apr 22, 2016 3:04 pm    Post subject: Re: Once around, It's Spring! Reply with quote
I mounted it on the nose, attached on a plate above the "P" tube
 Filesize:  23.86 KB
 Viewed:  4112 Time(s)
 Filesize:  91.4 KB
West1m
Hastings, MN
lcottrell
PostPosted: Fri Apr 22, 2016 3:13 pm    Post subject: Once around, It's Spring! Reply with quote
Thanks for the pictures, that was fast. Is it "springy"? The more solid it is the better the video. Other wise you will have to figure what RPM gives you less jumpy video.  I used a 1x1/8th flat stock about 5 inches long, twisted 180 so that I could use a hole drilled in the side to secure the cradle.
Thanks again,
Larry
On Fri, Apr 22, 2016 at 5:04 PM, west1m <west1m(at)hotmail.com (west1m(at)hotmail.com)> wrote:
West1m
Hastings, MN
http://forums.matronics.com/viewtopic.php?p=455352#455352
http://forums.matronics.com//files/ffly2_124.jpg
http://forums.matronics.com//files/ffly1_569.jpg
WIKI -
