RockRack Switch Wiring
billhuntersemail(at)gmail
PostPosted: Fri Apr 22, 2016 9:07 am    Post subject: RockRack Switch Wiring Reply with quote
Hi All,
I am going to install RockRack switches and these switches have LEDs that illuminate when the switch is in the on position.
Has anybody used these switches and/or are familiar with the wiring?
I am interested in learning how to setup the LED so that they are dimmable.
Any help would be greatly appreciated!!!
Bill Hunter
user9253
PostPosted: Fri Apr 22, 2016 10:20 am    Post subject: Re: RockRack Switch Wiring Reply with quote
http://www.aircraftspruce.com/catalog/pdf/RockRack-connections.pdf
Pin 7 of all of the switches can be connected together to a dimmer that is connected to ground. A PWM dimmer is most efficient, but some are noisy. If I remember right, Jim Weir had an article about LED dimmers in a recent KitPlances magazine.
Joe Gores
