Drain hole 'dancer'
ceengland7(at)gmail.com
PostPosted: Wed Apr 13, 2016 1:28 pm    Post subject: Drain hole 'dancer' Reply with quote
Quick & dirty pic of the drain hole 'dancer' I was trying to describe. Made it in about a minute using needle nose pliers & safety wire pliers. Spiral it into the drain hole; won't come out until you remove it.
Charlie
 Filesize:  216.63 KB
 Viewed:  1484 Time(s)
