Herbgh(at)nctc.com Guest
Posted: Tue Apr 12, 2016 10:50 am Post subject: Fourstar |
Wondering how many have seen this...? Called the Fourstar...one of a
kind...Bill Bronson of the St. Louis area designed and built it using
Firestar parts...
I have enough parts to build it...and the less than 2 gal an hour
consumption of my Global engine is desirable...
With my memory...may have sent this before...?? Herb
161.05 KB |
4372 Time(s) |
lcottrell
Posted: Tue Apr 12, 2016 10:59 am Post subject: Fourstar |
Does it count that it is Ugly? Larry
On Tue, Apr 12, 2016 at 12:50 PM, Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)> wrote:
Wondering how many have seen this...? Called the Fourstar...one of a kind...Bill Bronson of the St. Louis area designed and built it using Firestar parts...
I have enough parts to build it...and the less than 2 gal an hour consumption of my Global engine is desirable...
pc.king(at)comcast.net Guest
Posted: Tue Apr 12, 2016 11:03 am Post subject: Fourstar |
Why couldn't half a VW be mounted in place of a 447 instead of
re-engineering the nose?
Posted: Tue Apr 12, 2016 12:07 pm Post subject: Fourstar |
That it is...sometimes in the eyes of the beholder...but in this case...bet the decision will be unanimous...!
just something I have had on my mind for some time... sort of a disease I guess?? Not sure it can be prettied up...?? Herb
On 04/12/2016 01:58 PM, Larry Cottrell wrote:
| Quote: | Does it count that it is Ugly? Larry
Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left.
Posted: Tue Apr 12, 2016 12:17 pm Post subject: Fourstar |
That has been done already....A fellow from East Tenn....sent the engine
to the Kolb flyin one year...mounted on an early Firestar 1. The engine
was later mounted on his Firefly... The engine had dual ignition which
required that it be started with the electronic ign disabled....Poor
fellow forgot and messed hp his hand really bad...
then he crashed and the wife put her foot down..! end of story...
The half vw engine is well proven and reliable...more so in a tractor
configuration.. Mine idles smoothly at 600 rpm but had a bit of
vibration at cruise...2850 or so.. balancing the reciprocating and
rotating parts helps quite a bit... and I would do that if I follow
through with this project...Herb
patrickjladd(at)hotmail.c Guest
Posted: Wed Apr 13, 2016 1:33 am Post subject: Fourstar |
What a gruesome looking beast. Pat
