Trike Axle Diameter?
dpark748(at)me.com
PostPosted: Sun Apr 10, 2016 6:49 am    Post subject: Trike Axle Diameter? Reply with quote
I am making a device to ease the Trike wheel removal in case of punture.
I just need the axle diameter. I am at home in workshop at moment, does anyone have a record of this dia.?
Thanks Dave G-LDVO
SPURPURA
PostPosted: Mon Apr 11, 2016 3:11 am    Post subject: Re: Trike Axle Diameter? Reply with quote
I use a 3/4" x 12" steel rod inserted into the axle to pull the wheel off.
N951EU - Tri-gear & 912ULS, N77EU- Mono & 914
I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY.
dpark748(at)icloud.com
PostPosted: Mon Apr 11, 2016 6:05 am    Post subject: Trike Axle Diameter? Reply with quote
Yes i plan using 3/4" 1/16" wall 4130 tube and a 1" thick shaped ply to support while wheel is off. Keeping light weight for touring.
Have not tried to check if tube strong enough yet.
Dave G-LDVO
http://forums.matronics.com/viewtopic.php?p=454827#454827
