Redux
MikeP
PostPosted: Mon Sep 05, 2016 1:31 pm    Post subject: Redux Reply with quote
Ladies/Gents
I may need a small amount of redux for a repair on the tail wheel mounting.
Anyone have any suggestions as to where/who might have a some available?
Also the instructions on its use
Mike
spcialeffects
PostPosted: Tue Sep 06, 2016 4:55 am    Post subject: Re: Redux Reply with quote
Hey Mike. You can buy it here
https://www.silmid.com/products/re420200ml-araldite-420-epoxy-adhesive-200ml-cartr.aspx
This is the smallest amount you can buy and you will need the gun too. If your asking "How to use it" then you obviously didn't build your aircraft so i would talk to your inspector for guidance on the "problem" and he will point you in the right direction reference the repair
Regards Frank
JohnFrance
PostPosted: Wed Sep 07, 2016 2:42 am    Post subject: Re: Redux Reply with quote
Mike,
I purchased the Araldite 420 here, (but they don't show the small twin tube version at the moment, suggest you call them.)
http://www.mouldlife.net/araldite-420-ab-14kg-kit-2841-p.asp
And the data sheet is here,
http://www.mouldlife.net/ekmps/shops/mouldlife/resources/Other/420-data-sheet.pdf
I used it without the gun by pushing each cylinder individually and weighing the two components with precision scales. I didn't use the mixing nozzles as you need to mix a "certain quantity".
Regards, John
Europa mono Nr 192
