LANDING GEAR
mike(at)vision499.com
PostPosted: Sun Apr 10, 2016 7:07 am    Post subject: LANDING GEAR Reply with quote
I have attached a photo of my landing gear bolt attachment reinforcement.
It is an aluminum washer that is cut at the same angle as the support pad for the landing gear so that the bolts will 90 degrees.
I drilled holes ihe bottom of the washer
Mike
 Filesize:  333.81 KB
 Viewed:  1534 Time(s)
