If anybody is bored...could you be so kind as to check my w
jluckey(at)pacbell.net
PostPosted: Wed Apr 06, 2016 8:14 pm    Post subject: If anybody is bored...could you be so kind as to check my w Reply with quote
Agree with and well-said, Joe.
The diagram in its present form requires a lot of mental gymnastics to "decode" the basic circuitry. Most electrical engineers "think" in schematics. If you want commentary on design then try to make it easy for the reviewer.
See attached for example of my electrical system. This is a schematic.  It shows the architecture, components, and circuitry but provides no information on where the components are located or what wires to run between the components. Most engineers start w/ a schematic to do the analysis & design then develop a wiring diagram for wiring in the field. This style of schematic is sometimes called a ladder diagram.
One side note, BobN has developed a style of diagram in his drawings which is a sort of hybrid schematic/wiring diagram which I find to be pretty effective in conveying both design & wiring info. (I still do it old-school, with 2 diagrams: schematic then wiring diagram)
-Jeff
On Wednesday, April 6, 2016 8:02 PM, user9253 <fransew(at)gmail.com> wrote:
Read about the difference between a wiring diagram and a schematic.
http://tinyurl.com/jgmc28e
A schematic would be much easier for others to visualize your intended electrical architecture.
Joe Gores
http://forums.matronics.com/viewtopic.php?p=454653#454653
hbsp; ========================http://www.matronics.com/Nsp; --> <a href="http://www.matronics.com/contribution" target="_bl===
PowDist01b.pdf
 Filename:  PowDist01b.pdf
 Filesize:  43.18 KB
 Downloaded:  965 Time(s)
PostPosted: Thu Apr 07, 2016 7:40 am    Post subject: Re: If anybody is bored...could you be so kind as to check Reply with quote
I Agree with Jeff.
And Jeff, is your plane flying with your electrical system wired per your schematic? If so, how do you like it?
Joe Gores
racerjerry
PostPosted: Fri Apr 08, 2016 2:31 am    Post subject: Re: If anybody is bored...could you be so kind as to check Reply with quote
Regarding the Over-Voltage module shown in the wiring diagram http://forums.matronics.com/download.php?id=42607
Does this module merely provide an INDICATION of over/under voltage, as in a OV/LV sensor? If this module is of the crowbar type, it appears to me that something is seriously wrong.
Jerry King
PostPosted: Fri Apr 08, 2016 5:44 am    Post subject: Re: If anybody is bored...could you be so kind as to check Reply with quote
The over voltage module is the crowbar type. If it shorts out due to high voltage, it trips the circuit breaker.
Joe Gores
racerjerry
PostPosted: Sat Apr 09, 2016 3:30 am    Post subject: Re: If anybody is bored...could you be so kind as to check Reply with quote
OOPS! Guess my eyes were not fully open and intravenous coffee had not yet taken effect.
Jerry King
