BobbyPaulk(at)comcast.net Guest
Posted: Thu Mar 31, 2016 3:51 am Post subject: RG |
I was told about 10 years ago that RG 400 was a replacement for RG 58 and had better shielding and less of a line loss.
Can anyone verify? I used in my airplane and it has been flawless. I have talked to other aircraft as far away as 250 miles.
Bobby
rampil
Posted: Thu Mar 31, 2016 6:05 am Post subject: Re: RG |
Yes.
You can google coax specs to confirm
billp(at)wwpc.com Guest
Posted: Thu Mar 31, 2016 6:58 am Post subject: RG |
RG-58 is vinyl covered and when it burns it produces stuff you don't want to breath. RG-400 is Teflon inside and out so it burns at a much higher temperature. RG-58 has become a coaxial type that is more of a commodity and manufacturers seem to take the spec as a suggetion. I think when someone says "RG-58 type coaxial" in their literature they mean it's roughly 50 ohms and the standard diameter. I've seen some "RG-58" that had pretty bad construction. Very low percentage shielding. Sometimes tinned shield braid sometimes not. It's all over the map. RG-400 is a lot more consistent and is really well shielded. If you are trying to keep noise out or RF in I think the RG-400 is the way to go. My airplane is so old it has some RG-58 in it but that RG-58 was made in a time when the military spec still meant something. Now I'm using RG-400 for all the new installations.
| Quote: | Bill Putney - WB6RFW (Extra-lite)
Chief Engineer
KPTZ - Port Townsend, WA
FAA PP-SEL, A&P/IA
"...you know me to be a very smart man. Don't you think if I were wrong, I'd know it?" -Sheldon Cooper | On 3/31/16 04:50, BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net) wrote:
| Quote: | I was told about 10 years ago that RG 400 was a replacement for RG 58 and had better shielding and less of a line loss.
Bobby
Posted: Thu Mar 31, 2016 8:50 am Post subject: RG |
Bobby
Do Not Archive |
Signal loss in the legacy coax style is
not a significant factor in GA aircraft.
We just don't have long runs of coax that
tend to stack up signal losses.
RG-400/141/142 and cousins are modern insulation
much more resistant to environmental effects
and easier to solder. They're also double-shielded
which offers a TINY but insignificant improvement
in performance. These coaxes are much more expensive
but not a significant boost in final cost of the
project.
There are some lower cost coax products half
way between RG400/141/142 and RG-58 that used
lower temperature insulations but are very
good performance for our purposes . . . but
they are fussier to work with for installing
connectors.
If it were my airplane, I'd go with the more
exotic insulations in the 400/141/142 family.
Robust, easy to work with, and dozens of sources
on eBay for small quantities.
But if you have RG58 on hand or already installed
and its working . . . don't sweat it.
