kenryan
Posted: Mon Mar 28, 2016 2:14 pm Post subject: another switch question |
I am curious about the function of the pictured "Engine Start" switch. It is a push button switch with four terminals on the back. Two of the terminals are normally open, two are normally closed. I can see how the normally open terminals could be used to drive a starter motor relay, but what would the typical use be for the normally closed terminals on an engine start switch? See attached pic.
111.14 KB |
12497 Time(s) |
rene(at)felker.com Guest
Posted: Mon Mar 28, 2016 3:38 pm Post subject: another switch question |
Just a guess……ground out one of the mags?
Rene'
801-721-6080
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Ryan
Sent: Monday, March 28, 2016 4:13 PM
Subject: another switch question
lyleapgmc
Posted: Mon Mar 28, 2016 3:51 pm Post subject: another switch question |
To remove power from anything not needed while cranking the engine.
JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Mon Mar 28, 2016 4:53 pm Post subject: Re: another switch question |
This looks like the 'Steinair' switch they sell, (which I'm keen on using on our -9a build) the connectors look like 1/8inch wide, are 'fast-on' PIDG connectors available, or should one solder.
John
ashleysc(at)broadstripe.n Guest
Posted: Mon Mar 28, 2016 6:55 pm Post subject: another switch question |
Hi Ken;
That's a mighty rugged looking switch! I think the normally closed contacts would normally be used to turn off (temporarily) anything you didn't want running while engaging the starter.
Cheers! Stu.
Sent: Monday, March 28, 2016 3:12:39 PM
Posted: Mon Mar 28, 2016 7:00 pm Post subject: another switch question |
Hi Ken;
I would like the mfg. and model number of that switch, please.
Cheers! Stu.
kenryan
Posted: Mon Mar 28, 2016 8:17 pm Post subject: another switch question |
It's made by Elewind. Here's a link:
http://www.aliexpress.com/store/product/ELEWIND-22mm-1NO1NC-Momentary-push-button-With-ENGINE-START-symbol-PM221F-11-S-With-ENGINE-START/737142_1719523504.html
On Mon, Mar 28, 2016 at 6:59 PM, <ashleysc(at)broadstripe.net (ashleysc(at)broadstripe.net)> wrote:
| Quote: | Hi Ken;
Cheers! Stu.
JOHN TIPTON
Posted: Mon Mar 28, 2016 11:25 pm Post subject: another switch question |
I don't know if the manufacturer would have anything to add, this is obviously an automotive based switch so what the NC contacts would be used for in a modern car is anyone's guess - and the advert states the contacts are rated 2-5 amps
John
----x--O--x----
On 29 Mar 2016, at 03:59 am, ashleysc(at)broadstripe.net (ashleysc(at)broadstripe.net) wrote:
| Quote: | Hi Ken;
Cheers! Stu.
From: "Ken Ryan" <keninalaska(at)gmail.com (keninalaska(at)gmail.com)>
JOHN TIPTON
http://www.steinair.com/storedetail.cfm?productid=668
----x--O--x----
| Quote: | Hi Ken;
Cheers! Stu.
ARGOLDMAN(at)aol.com Guest
Posted: Tue Mar 29, 2016 5:01 am Post subject: another switch question |
My guess is that it is a somewhat standard pushbutton switch back to which the manufacturer attaches a "start" placarded front.
Just ignore the nc part. If you really want you can use the NC part to disable other electronics during your start, however you add one more point of failure to a switch of possible questionable reliability.-- With this switch, if it fails, so you can't start your craft (you are probably on the ground at this point) whereas if it fails you may not have use of the electronics that it defeats.
It is not unusual to not use parts of a switch or IC
Rich
Rich
In a message dated 3/28/2016 7:57:10 P.M. Pacific Daylight Time, ashleysc(at)broadstripe.net writes:
| Quote: | Hi Ken;
Cheers! Stu.
Posted: Tue Mar 29, 2016 7:11 am Post subject: another switch question |
At 05:12 PM 3/28/2016, you wrote:
| Quote: | I am curious about the function of the pictured "Engine Start" switch. It is a push button switch with four terminals on the back. Two of the terminals are normally open, two are normally closed. I can see how the normally open terminals could be used to drive a starter motor relay, but what would the typical use be for the normally closed terminals on an engine start switch? See attached pic.
Content-Type: image/jpeg; name="engine-start-switch.jpg"
Content-Disposition: attachment; filename="engine-start-switch.jpg"
X-Attachment-Id: f_imcjusoz0
I would guess that the n.c. side disconnects
accessories not intended to be on the bus
during cranking. I think all my cars drop
the accessory bus during cranking.
kenryan
Posted: Tue Mar 29, 2016 7:39 am Post subject: another switch question |
Thanks guys. I can't see any reason to utilize the NC side in my installation.
jonlaury
Posted: Tue Mar 29, 2016 10:17 am Post subject: Re: another switch question |
I have not bought switches from the Elewind company, but I've been using Chinese SS/illuminated switches for years in a product I make. Aside from the robust, functional 'look', there's a huge difference in quality control, mfr to mfr with failure rates of some, over time, as high as 80%. If the aesthetics of the switch are irresistible, then vet the switch company by asking for references for large volume purchasers in the USA for your specific part #. Ask the USA company for switch application and quality control reports for your specific part #. I found a Chinese 'company' with a reasonable failure rate this way. I accept that there will be occasional failures in my non-critical application as a trade-off for pleasing aesthetics, price and feature set. I definitely would not use a Chinese sourced switch in any sort of critical application, and really feel that they have no place in an airplane, if you believe that catastrophes result from a series of bad decisions or small things going wrong.
It seems that there are a ton of switch 'companies' in Yueqing all offering the same switches. I suspect that there are a few manufacturers. As this style of switch is offered by US companies (E-Switch, Digikey, Mouser) at 5-8x (or more) the Chinese price, I suspect that large US distributors can demand and get better quality control, but it comes at a price. I can't imagine Digikey tolerating the failure rate that I've seen in some Chinese sources, or even the one that I use, which is pretty low.
YMMV
John
JOHN TIPTON
Posted: Tue Mar 29, 2016 10:30 am Post subject: another switch question |
His would you quantify 'Chinese' compared with US quality (control)
----x--O--x----
| Quote: | On 29 Mar 2016, at 07:17 pm, "jonlaury" <jonlaury(at)impulse.net> wrote:
> http://www.aliexpress.com/store/product/ELEWIND-22mm-1NO1NC-Momentary-push-button-With-ENGINE-START-symbol-PM221F-11-S-With-ENGINE-START/737142_1719523504.html (http://www.aliexpress.com/store/product/ELEWIND-22mm-1NO1NC-Momentary-push-button-With-ENGINE-START-symbol-PM221F-11-S-With-ENGINE-START/737142_1719523504.html)
>> On Mon, Mar 28, 2016 at 6:59 PM, wrote:
>> Hi Ken;
>> Cheers! Stu.
I have not bought switches from the Elewind company, but I've been using Chinese SS/illuminated switches for years in a product I make. Aside from the robust, functional 'look', there's a huge difference in quality control, mfr to mfr with failure rates of some, over time, as high as 80%. If the aesthetics of the switch are irresistible, then vet the switch company by asking for references for large volume purchasers in the USA for your specific part #. Ask the USA company for switch application and quality control reports for your specific part #. I found a Chinese 'company' with a reasonable failure rate this way. I accept that there will be occasional failures in my non-critical application as a trade-off for pleasing aesthetics, price and feature set. I definitely would not use a Chinese sourced switch in any sort of critical application, and really feel that they have no place in an airplane, if you believe that catastrophes result from a series of bad decisions or sm!
YMMV
John
http://forums.matronics.com/viewtopic.php?p=454329#454329
JOHN TIPTON
Posted: Tue Mar 29, 2016 10:38 am Post subject: another switch question |
Hi Bob
Looking at this switch, it's a double pole changeover style: if used as a simple (on)-off (ie: momentary push on - to power the starter contactor) is it a good idea to connect the terminals together, or is one pole OK for a standard starter contactor
John
----x--O--x----
On 29 Mar 2016, at 04:01 pm, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
JOHN TIPTON
Posted: Tue Apr 12, 2016 11:27 pm Post subject: Re: another switch question |
Hi a Guys
Anyone ordered this switch from China, and if so anyone had difficulty actually placing the order.
John
