Fast-on tabs or screw terminals for ground?
haribole
PostPosted: Wed Mar 23, 2016 6:48 am    Post subject: Fast-on tabs or screw terminals for ground? Reply with quote
Hello Group
Intuitively screwed down ground terminals seem so much more reliable is there a reason the fast-on tabs are more popular?
Hari
jbsoar(at)gmail.com
PostPosted: Wed Mar 23, 2016 7:58 am    Post subject: Fast-on tabs or screw terminals for ground? Reply with quote
Fast-on Tabs are more reliable, and probably lighter.  Automobiles don't use screws to wires together, generally.  The ground straps on automobiles are often screwed or bolted, and they are often the weak points in the electrical system...
On Wed, Mar 23, 2016 at 7:44 AM, Hariharan Gopalan <rdu.hari(at)gmail.com (rdu.hari(at)gmail.com)> wrote:
Hello Group
Hari
yellowduckduo(at)gmail.co
PostPosted: Wed Mar 23, 2016 8:25 am    Post subject: Fast-on tabs or screw terminals for ground? Reply with quote
I like that when fumbling behind and under the panel there is no screw
to drop or threads to strip.
I suppose screw terminals generally require an extra joint when
building. Crimping the ring terminal then the screw connection.
Ken
On 23/03/2016 10:44 AM, Hariharan Gopalan wrote:
Hello Group
Hari
Robert Reed
PostPosted: Wed Mar 23, 2016 8:26 am    Post subject: Fast-on tabs or screw terminals for ground? Reply with quote
Considering the fact that reliability of the Fast-on Tabs seems to be equal to the screw on terminals it comes down to accessibility. It seems that most of the electrical connections are always in a hard to access location and getting a screwdriver into those locations is always a chore that gets considerably worse with age, I will go with the fast-on tabs every time.
Bob
Sent: Wednesday, March 23, 2016 9:44 AM
Subject: Fast-on tabs or screw terminals for ground?
Hello Group
Hari
haribole
PostPosted: Wed Mar 23, 2016 10:02 am    Post subject: Fast-on tabs or screw terminals for ground? Reply with quote
Seems like intuition can be wrong, like in flying.
Thanks everyone.
On Wed, Mar 23, 2016 at 12:14 PM, Robert Reed <robertr237(at)att.net (robertr237(at)att.net)> wrote:
Bob
From: Hariharan Gopalan <rdu.hari(at)gmail.com (rdu.hari(at)gmail.com)>
Subject: AeroElectric-List: Fast-on tabs or screw terminals for ground?
Hello Group
Hari
bobnoffs
PostPosted: Thu Mar 24, 2016 2:45 am    Post subject: Fast-on tabs or screw terminals for ground? Reply with quote
downside to fat ons is you really do need needle nose to remove them and it gets to the point you wonder if you are damaging the tab or its attachment so much force is needed
 bob noffs
On Wed, Mar 23, 2016 at 12:59 PM, Hariharan Gopalan <rdu.hari(at)gmail.com (rdu.hari(at)gmail.com)> wrote:
Thanks everyone.
Bob
Hello Group
Hari
donjohnston
PostPosted: Thu Mar 24, 2016 4:01 pm    Post subject: Re: Fast-on tabs or screw terminals for ground? Reply with quote
How can Fast-on Tabs be more reliable? They are held on with just friction. A ring terminal with a locknut would seem to be more secure.
I am NOT saying Fast-on's are unreliable. Just trying to understand the statement.
stein(at)steinair.com
PostPosted: Thu Mar 24, 2016 4:43 pm    Post subject: Fast-on tabs or screw terminals for ground? Reply with quote
Ever tried to get a "fast on" terminal (PIDG type) off of a good spade with
your bare fingers? Almost impossible....yet screws and locknuts (without
locktite that is) can and do often work themselves loose, especially during
the first 40 hrs of flight as things "settle in".
We many thousands upon thousands of both per year, and I'm a bit ambivalent
to either being superior, but I do know that if you use high quality
terminals those things are VERY good.
Just my 2 cents as usual.
Stein
donjohnston
PostPosted: Fri Mar 25, 2016 4:45 am    Post subject: Re: Fast-on tabs or screw terminals for ground? Reply with quote
Well, to be fair, your 2 cents are worth about $2 compared to others. Wink
And I will continue providing you funds so you can offer your 2 cents here.
Thanks for all that you do!
Stein
