kenryan
Posted: Sun Mar 20, 2016 2:15 pm Post subject: info on this terminal |
Are the terminals on this switch solder only or is there a push on connector that matches?[img]cid:ii_1539616375b04dcb[/img]
57.64 KB |
3530 Time(s) |
Bob McC
Posted: Sun Mar 20, 2016 3:01 pm Post subject: info on this terminal |
Solder !
You may find a narrow female tab which “sort of” fits but it is not an intended application and is not recommended.
Bob McC
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Ryan
Sent: Sunday, March 20, 2016 6:13 PM
Subject: info on this terminal
Are the terminals on this switch solder only or is there a push on connector that matches?[img]cid:image002.jpg(at)01D182DA.A86ECC50[/img]
8.59 KB |
3528 Time(s) |
_________________ Bob McC
Falco #908
(just starting) |
chaskuss(at)yahoo.com Guest
Posted: Sun Mar 20, 2016 3:06 pm Post subject: info on this terminal |
Soldering a wire onto this sensor would risk ruining the sensor. I believe the intended connection method is to use a matching ring terminal on the wire. Fasten the wire to the terminal using the appropriate screw, 2 flat washers and a Nyloc nut. Certainly not my favorite type of terminal on a sensor exposed to engine vibration. A sensor like this would best be used on a transducer manifold block, mounted to the firewall. Vans aircraft sells such a manifold block. It's listed on the bottom of page 30 of their catalog. You can download the catalog here.
http://www.vansaircraft.com/public/download/2015-2016_Catalog.pdf
Charlie
To: "aeroelectric-list(at)matronics.com" <aeroelectric-list(at)matronics.com>
Date: Sunday, March 20, 2016, 6:12 PM
matches?
kenryan
Posted: Sun Mar 20, 2016 5:00 pm Post subject: info on this terminal |
Thank you Bob and Lyle.
On Sun, Mar 20, 2016 at 3:35 PM, Lyle Peterson <lyleap(at)centurylink.net (lyleap(at)centurylink.net)> wrote:
| Quote: | I think it is intended for soldering. I don't see how you would get a slip on terminal to stay on/
You may be able to put an alligator clip or similar as a heat sink on the terminal below the solder area. It should only take a very few seconds to get a good solder joint.
On 3/20/2016 5:12 PM, Ken Ryan wrote:
| Quote: | Are the terminals on this switch solder only or is there a push on connector that matches?
