cpayne(at)joimail.com Guest
Posted: Mon Mar 07, 2016 4:41 am Post subject: Auto wiring issues |
In my experience, problems with auto wire conversions can be traced to installation errors or not properly gaping the auto plugs. Anything more than .020" gap will cause excessive resistance and load on magneto coils, especially at altitude. This leads to misfiring, arcing in the distributor cap and mag coil damage.
Craig Payne
Posted: Mon Mar 07, 2016 5:24 am Post subject: Auto wiring issues |
Excellent points Craig. I'd like to add to the "arcing in the distributor cap" statement. An an improperly positioned rotor will and does cause much more arcing in the distributor cap.
Dennis
To: yak-list <yak-list(at)matronics.com>
Sent: Monday, March 7, 2016 7:17 AM
Subject: Auto wiring issues
--> Yak-List message posted by: Cpayne <cpayne(at)joimail.com (cpayne(at)joimail.com)>
Craig Payne[b]http://www.matronics.com/Navigator?Yak-Li> http://foru - List Contribution Web Site -http://www.matronic====================
crobin(at)skyvantage.com Guest
Posted: Mon Mar 07, 2016 10:35 am Post subject: Auto wiring issues |
I can attest, that the auto plug conversion, if installed properly, is a very worthwhile UPGRADE.
1. Use proper plugs (Resistor type)
2. Is it worth the money for iridium? (I don't know, some say it's not, but I run them)
3. check and double check with meter all wires all the way into the cap
4. Enjoy a much better and smoother running engine.
Cory
wilgabeast.com
yaknorway52(at)gmail.com Guest
Posted: Mon Mar 07, 2016 10:53 am Post subject: Auto wiring issues |
Most likely its in perfect condition so if anyone wants it? I sell it cheap.
Trade for a kit with new original spark plugs Could be a Good offer:-)
Br
Havard
[img]cid:60A7D533-FF8F-451C-BF78-6ED6FCF20CAD[/img]
Sendt fra min iPhone
Den 7. mar. 2016 kl. 19.34 skrev Cory Robin <crobin(at)skyvantage.com (crobin(at)skyvantage.com)>:
| Quote: | I can attest, that the auto plug conversion, if installed properly, is a very worthwhile UPGRADE.
Cory
wilgabeast.com
1.91 MB |
12858 Time(s) |
Epistaxis
Joined: 19 Dec 2010 Posts: 13 Location: Nebraska, USA
Posted: Thu Apr 21, 2016 7:42 pm Post subject: Re: Auto wiring issues |
Do you still have the Auto sparkplug/ wiring kit up for sale? Please respond off site, I will check my spares kit for a set of Russian sparkplugs.
Thanks Shawn
Lancer
Joined: 21 Apr 2016 Posts: 30 Location: Cairns, Australia
Posted: Wed Apr 27, 2016 12:22 am Post subject: Re: Auto wiring issues |
I have been flying a Nanchang for 13 years and never had to change 1 plug in all that time so I can't see the advantage. Can anyone say what the motivation was to change theirs and what changes they noticed with the auto plugs and leads.
_________________ You can run but you can't hide |
crichka(at)gmail.com Guest
Posted: Wed Apr 27, 2016 3:45 am Post subject: Auto wiring issues |
You absolutely right. The Russian excellent engineering. I did install auto plugs and wires, and no additional benefits except more radio noise. Yak driver 52cy
On Wed, Apr 27, 2016 at 4:22 AM, Lancer <lrob4783(at)bigpond.net.au (lrob4783(at)bigpond.net.au)> wrote:
| Quote: | --> Yak-List message posted by: "Lancer" <lrob4783(at)bigpond.net.au (lrob4783(at)bigpond.net.au)>
http://forums.matronics.com/viewtopic.php?p=455526#455526
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
The problem was never the plugs. It was the wiring harness. The original rubber plug wire rubber deteriorates inside the braided shields. Once the deterioration starts the plug wire arcs to the braided shield (ground) and you know what that does. A misfire. If one wants to retain the original harness configuration, the only way to fix that problem is to pull a new wire through the wiring harness. If you've never done that before, I can tell you its not a fun job especially if the new wire separates from the old wire while pulling it through the harness. Been there, done that, got the T-shirt.
I'll let the people who have the automotive conversion kit comment on what they found advantageous.
Dennis
To: yak-list(at)matronics.com
Sent: Wednesday, April 27, 2016 4:22 AM
Subject: Re: Auto wiring issues
<br; <a href="http://www.matronics.com/Navigator?Yak-List" target="_blank"= --> <a href="http://www.matronics.com/contribution" target=====
grabstein(at)gmail.com Guest
Posted: Wed Apr 27, 2016 4:00 am Post subject: Auto wiring issues |
Just had the auto wiring installed in my CJ just a few months ago. Easier starts, smoother running, slight improvement in fuel efficiency (that one may be in my head, but I appear to have dropped from 14 to 13 gph)
Kurt Howerton
916-282-9231
http://cj6.scitechsys.com
| Quote: | On Apr 27, 2016, at 4:22 AM, Lancer <lrob4783(at)bigpond.net.au> wrote:
Posted: Wed Apr 27, 2016 4:07 am Post subject: Auto wiring issues |
What radio do you have in your airplane? Could it be a Becker? The 57mm round model 4201?
Dennis
Sent: Wednesday, April 27, 2016 7:42 AM
Subject: Re: Re: Auto wiring issues
WIKI -
bwade154(at)yahoo.com Guest
Posted: Wed Apr 27, 2016 5:11 am Post subject: Auto wiring issues |
Mr Lancer that falls under if it ain't broke don't fix it !!! You will now when to fix it, when you have Hot run-ups and your motor runs ruff on one mag kind of like a fouled plug or your flying along and the engine starts backfiring and losing power till then fly on my friend fly on.
Bill Wade N4450Y Yak 52
Subject: Yak-List: Re: Auto wiring issues
http://forums.matronics.com/viewtopmatronics.com/Navigator?Yak-List" target="_blank">http://www.matronics.co= - MATRONICS WEB FORUMS  href="http://www.matronics.com/contribution" target="_blank">http://www=======================
cjpilot710(at)aol.com Guest
Posted: Wed Apr 27, 2016 5:45 am Post subject: Auto wiring issues |
Sent via the Samsung GALAXY S® 5, an AT&T 4G LTE smartphone
-------- Original message --------
From: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net>
Date: 4/27/2016 5:40 AM (GMT-07:00)
Subject: Re: Yak-List: Re: Auto wiring issues
Dennis
Posted: Wed Apr 27, 2016 1:08 pm Post subject: Auto wiring issues |
Russian radio. did not have noise with original harness
On Wed, Apr 27, 2016 at 8:06 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
| Quote: | What radio do you have in your airplane? Could it be a Becker? The 57mm round model 4201?
Dennis
From: Chanock Richka <crichka(at)gmail.com (crichka(at)gmail.com)>
pfstelwagon(at)earthlink. Guest
Posted: Thu Apr 28, 2016 7:06 pm Post subject: Auto wiring issues |
Carefully check the P lead from the noisy mag all the way to the mag switch. Make sure the shield is complete all the way and grounded at both ends. The most likely place for trouble is at the mag since the P lead has been removed at least once.
Frank
jan.mevis(at)informavia.b Guest
Posted: Thu Apr 28, 2016 9:49 pm Post subject: Auto wiring issues |
The noise issue on these planes is a very difficult one.
We recently replaced a Becker 4201 on a Yak 52 with a brandnew Trig.
The Becker worked well enough, but it¹s only 25 kHz separated, so we decided
to go for a new 8.33 kHz model (legislation in Europe will impose this).
Since then, there¹s intermittent noise.
I am pretty certain that it does not come via the power supply (tested with
different kinds of filters, and ultimately with a separate battery).
So maybe from the P-leads, the tach-generator, bad contacts, Š.
Nothing to do with the wiring harness though, which was replaced years ago.
Jan
From: <owner-yak-list-server(at)matronics.com> on behalf of Frank Stelwagon
<pfstelwagon(at)earthlink.net>
Reply-To: "yak-list(at)matronics.com" <yak-list(at)matronics.com>
Date: Friday 29 April 2016 at 05:05
Lancer
