yellowbird1
Posted: Wed Feb 17, 2016 9:01 pm Post subject: Tire Replacement |
I’m try to replace my tires on my Xtra but so far I am unable to remove them from the Matco split rims. It seems that the beed sealer is being uncooperative (I’m thinking it’s really epoxy or perhaps someone has found a new method to vulcanize rubber to metal). I haven’t found any tire shop that will work on that size of wheel. Any suggestions would be greatly appreciated.
Thanks in advance,
Brad Nation
_________________ Brad Nation,
Albuquerque, NM
MK3 Xtra |
ceengland7(at)gmail.com Guest
Posted: Wed Feb 17, 2016 9:25 pm Post subject: Tire Replacement |
Golf cart dealer? Some tire distributors that have a retail dept might do it, as well. Or, a small tire shop in a smaller community will often sell atv/utv tires.
-------- Original message --------
Date:02/17/2016 11:01 PM (GMT-06:00)
To: Kolb-list
Subject: Kolb-List: Tire Replacement
--> Kolb-List message posted by: Bradley Nation <nationcap(at)comcast.net>
Thanks in advance,
Brad Nation
_-============================================================
_-=
_-= -- Please Support Your Lists This Month --
_-= (And Get Some AWESOME FREE Gifts!)
_-=
_-= November is the Annual List Fund Raiser. Click on
_-= the Contribution link below to find out more about
_-= this year's Terrific Free Incentive Gifts provided
_-= by:
_-=
_-= * The Builder's Bookstore www.buildersbooks.com
_-=
_-= List Contribution Web Site:
_-=
_-= --> http://www.matronics.com/contribution
_-=
_-= Thank you for your generous support!
_-=
_-= -Matt Dralle, List Admin.
_-=
_-= - The Kolb-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Kolb-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - List Contribution Web Site -
Posted: Thu Feb 18, 2016 5:08 am Post subject: Tire Replacement |
Try a fork lift dealer. They work on small diameter stuff. Maybe somebody used a petroleum based product to put them on. Raises hell trying to get them off. Petroleum will dissolve rubber.
On Thu, 2/18/16, Bradley Nation <nationcap(at)comcast.net> wrote:
Subject: Tire Replacement
To: "Kolb-list" <kolb-list(at)matronics.com>
Date: Thursday, February 18, 2016, 12:01 AM
any tire shop that will work on that size of wheel.Â
Thanks in advance,
Brad Nation
Lists This Month --
Raiser. Click on
more about
Gifts provided
       -Matt
Dralle, List Admin.
Forum -
       -Matt
Dralle, List Admin.
Herbgh(at)nctc.com Guest
Posted: Thu Feb 18, 2016 6:20 am Post subject: Tire Replacement |
I break tires loose by laying a board on the tire next to the rim and
running a wheel of an auto on the board.. Herb
On 02/18/2016 07:08 AM, william sullivan wrote:
Thanks in advance,
Brad Nation
Lists This Month --
Raiser. Click on
more about
Gifts provided
-Matt
Dralle, List Admin.
Forum -
-Matt
Dralle, List Admin.
Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left.
Posted: Thu Feb 18, 2016 6:28 am Post subject: Tire Replacement |
Never used tire sealer on wheels, but had a couple Armstrong tires that refused to release from the beads on either the FS or MKIII wheels. The tire beads were tougher than the light aluminum wheels.
Eventually used a die grinder and cut off wheel to cut the wire bead so I could cut them off.
Don't know anything about golf carts. Do they use a one piece or a split rim? I have ATV and SXS one piece wheels and tires mounted and dismounted at regular tire shops, but they would not touch one of these aluminum split rims. A small "shade tree" shop somewhere might tackle the job.
I had a flat tire when I landed at Fort Nelson, British Columbia, in 2004. A motorcycle gang was using a hanger to build bikes. They tackled the job for me, took me all the way to town to get some patches. Could have never gotten the job done by myself.
I think aircraft tires come off much easier than the golf cart type tires.
_________________ John Hauck
Titus, Alabama |
Posted: Thu Feb 18, 2016 7:39 am Post subject: Tire Replacement |
Golf cart wheels are one piece; similar in concept to automotive wheels.
The reason I mentioned them is that they will have a bead breaker usable
on small diameter wheels. Leave the wheel assembled, & let them break
the bead on both sides. I'd assume that once the bead is broken free, he
can handle the rest of the job himself.
Posted: Thu Feb 18, 2016 7:42 am Post subject: Tire Replacement |
I like it. I'll file that one away in my (computer) memory banks for
future use.
On 2/18/2016 8:19 AM, Herb wrote:
> <williamtsullivan(at)att.net>
> Thanks in advance,
> Brad Nation
> Lists This Month --
> Raiser. Click on
> more about
> Gifts provided
> -Matt
> Dralle, List Admin.
> Forum -
> -Matt
> Dralle, List Admin.
Posted: Thu Feb 18, 2016 7:59 am Post subject: Tire Replacement |
Problem with breaking tough beads on UL type aluminum wheels is the tire bead is tougher than the aluminum wheel. Very easy to ruin a wheel in the process. The reason I cut the bead with a die grinder was to sacrifice the "off road" tire before I sacrificed the wheel. I'd have second thoughts about butchering an aircraft tire.
Titus, Alabama |
lcottrell
lcottrell
Posted: Thu Feb 18, 2016 7:53 pm Post subject: Tire Replacement |
Is seems like only yesterday that several people were telling me to use bead sealer rather than screws to keep my tires from slipping at low pressure. I think I will stick with the screws.
Larry
On Wed, Feb 17, 2016 at 10:01 PM, Bradley Nation <nationcap(at)comcast.net (nationcap(at)comcast.net)> wrote:
| Quote: | --> Kolb-List message posted by: Bradley Nation <nationcap(at)comcast.net (nationcap(at)comcast.net)>
Thanks in advance,
Brad Nation
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
The older I get, the less tolerant I am of those who are intolerant.
Watkinsdw
Joined: 15 Mar 2009 Posts: 138 Location: Deerfield Beach, FL
Posted: Fri Feb 19, 2016 4:55 am Post subject: Re: Tire Replacement |
I bought this mini tire changer six years ago at Northern Tool. It has worked well for me. They no longer carry it, but Harbor Freight is advertising it.
Hope that helps!
Dave Watkins
MkIII Classic
Pompano Beach, FL (KPMP)
771.83 KB |
21475 Time(s) |
Watkinsdw
Posted: Fri Feb 19, 2016 4:58 am Post subject: Re: Tire Replacement |
Wow! That turned out way bigger than I intended! Sorry!
Dave
neilsenrm(at)gmail.com Guest
Posted: Fri Feb 19, 2016 7:40 am Post subject: Tire Replacement |
I have struggled in the past to break the bead on my Matco wheels. Created a few tools with limited success. The last time I needed to change a tube was at Airventure. Landed on the grass on the UL strip with a totally flat tire, no brakes needed. Taxi speed was slow and lumby. John Williamson followed my in, grumbled later he almost landed on top of me.
Took the wheel/tire to the EAA repair shop with a newly purchased tube. I used their small wheel bead breaker. The bead separated very easy with no deformation of the wheel. The tire changer that has been indicated looks like it could stress the wheel when trying to break the bead. Once these tires seat they really bond themselves to the wheel. HF also sells a small wheel bead breaker that I have been telling myself I will buy next time I change my tires. Getting close little/no tread left.
Rick Neilsen
Redrive VW Powered MKIIIC
On Fri, Feb 19, 2016 at 7:55 AM, Watkinsdw <david.watkins0(at)gmail.com (david.watkins0(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Watkinsdw" <david.watkins0(at)gmail.com (david.watkins0(at)gmail.com)>
Hope that helps!
Dave Watkins
MkIII Classic
http://forums.matronics.com/viewtopic.php?p=452995#452995
http://forums.matronics.com//files/image_547.png
br> fts!)
yellowbird1
Posted: Fri Feb 19, 2016 12:21 pm Post subject: Tire Replacement |
All I can say is that the tires are not slipping, that's for sure.
From: "Larry Cottrell" <lcottrell1020(at)gmail.com>
To: "kolb-list" <kolb-list(at)matronics.com>
Sent: Thursday, February 18, 2016 8:52:17 PM
Subject: Re: Tire Replacement
Larry
Thanks in advance,
Brad Nation
br> fts!)
Albuquerque, NM
MK3 Xtra |
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Sat Feb 20, 2016 5:29 am Post subject: Re: Tire Replacement |
A regular tire bead breaker should work. You just need to concentrate the force in one spot using a 2 x 3. Apply and hold force then heat area with a heat gun or hair dryer to soften the glue. Once you get it started, the bead should tear loose easily.
I use something like this, together with plywood to protect the wheel on the backside:
http://www.harborfreight.com/bead-breaker-92961.html
As John H. cautioned, be darned careful not to distort the wheel.
If you still have a problem, rig up something to apply concentrated force that you can let sit overnight. Puddle some solvent around the tire bead to help soften the glue.
_________________ Jerry King |
Posted: Sat Feb 20, 2016 10:25 am Post subject: Tire Replacement |
My solution:
http://jackbhart.com/firefly/firefly107.html
Jack B Hart FF004
Winchester, IN
At 09:19 AM 2/18/2016, you wrote:
tire next to the rim and running a wheel of an auto on the board.. Herb
>sullivan <williamtsullivan(at)att.net>
> Thanks in advance,
> Brad Nation
> Lists This Month --
> Raiser. Click on
> more about
> Gifts provided
> -Matt
> Dralle, List Admin.
> Forum -
> -Matt
> Dralle, List Admin.
yellowbird1
Posted: Sun Feb 21, 2016 6:21 pm Post subject: Tire Replacement |
Thanks for all the suggestions and help. I finally got the tires off with the help of a Harbor Freight mini tire changer. It took a bit but worked like a charm.One question though, there was a busted O-Ring inside one of the tires between the wheel halfs but not the other and I couldn’t tell where it went. Any comments or suggestions?
Brad
Albuquerque, NM
MK3 Xtra |
Posted: Sun Feb 21, 2016 6:28 pm Post subject: Tire Replacement |
I run tubes in my MKIII. Don't need the o rings in MATCOs with tubes.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Brad Nation
Sent: Sunday, February 21, 2016 8:21 PM
To: Kolb-list
Subject: Re: Re: Tire Replacement
Brad
Titus, Alabama |
zeprep251(at)aol.com Guest
Posted: Sun Feb 21, 2016 6:30 pm Post subject: Tire Replacement |
Think the o ring makes it tubeless
On Feb 21, 2016, at 9:21 PM, Brad Nation <nationcap(at)comcast.net (nationcap(at)comcast.net)> wrote:
| Quote: | Thanks for all the suggestions and help. I finally got the tires off with the help of a Harbor Freight mini tire changer. It took a bit but worked like a charm.One question though, there was a busted O-Ring inside one of the tires between the wheel halfs but not the other and I couldn’t tell where it went. Any comments or suggestions?
Brad
yellowbird1
Posted: Sun Feb 21, 2016 6:38 pm Post subject: Tire Replacement |
I’m using tubs as well. So perhaps the O-ring was left over from the previous owner.
Brad Nation
MKIII Xtra
Albuquerque, NM
Albuquerque, NM
MK3 Xtra |
