jareds(at)verizon.net Guest
Posted: Mon Feb 08, 2016 2:07 pm Post subject: 582 firewall fwd for sale |
| Quote: | firewall forward from kitfox model 4
582 grey zero time other than i did break in.
Carbs rebuilt when engine purchased.
c gearbox
3 blade wharp drive adjustable
From ROTAX-RECREATIONAL-ENGINES-LLC
Basically engine / prop / radiator (if you need it) / Carbs / Oil
Reservoirs )if you need them) / Exhaust / pump (new if you want to use
it) / spinner /
An engine mount if you want it that would fit a kitfox model 4 but could
be rewelded to accomodate whatever you are using it in.
I'd have some other goodies to prob throw in when i have a chance to go
through boxes etc... depending on what you might need.
postin pics / video on schottranch.com
Jared
