jbsoar(at)gmail.com Guest
Posted: Sun Feb 07, 2016 8:20 am Post subject: Yak-List Digest: 4 Msgs - 02/06/16 |
Auto plug conversion kit?Does anyone know he origin of the red auto plug conversion kit?
The separation plates for the mags are anodized red. NGK plugs. Red wires, with no markings. No instructions are in the box.
Who made this kit? Has anyone had good luck with this product?
Thank you!
John B
On Sun, Feb 7, 2016 at 1:03 AM, Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)> wrote:
| Quote: | *
Today's complete Yak-List Digest can also be found in either of the
of the Yak-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2016-02-06&Archive=Yak
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2016-02-06&Archive=Yak
Yak-List Digest Archive
Total Messages Posted Sat 02/06/16: 4
Today's Message Index:
1. 04:33 AM - Re: Garmin G3X installation (A. Dennis Savarese)
2. 04:52 AM - Re: Garmin G3X installation (Ernest Martinez)
3. 05:12 AM - Re: Garmin G3X installation (A. Dennis Savarese)
4. 05:30 AM - Re: Garmin G3X installation (George Coy)
________________________________ Message 1 _____________________________________
Time: 04:33:17 AM PST US
From: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Subject: Re: Garmin G3X installation
If the battery voltage drops down to 22 volts or less, the starting coil ma
y not generate an adequate spark.
The starting coil is probably one of the most reliable electrical component
s on the airplane.=C2-=C2- The starting coil wire (7mm) from the starti
ng coil to the left magneto cap may be deteriorated and cracked.=C2- If t
he wire is cracked, it will arc to the braided shield (ground) when you pre
ss the start button.=C2- That would prevent the spark from going to the m
ag cap and then to the spark plug.
After you replace the batteries, open up the starting coil container and ch
eck the points for mounding.=C2- If necessary you can burnish the points
to remove any mounds with a point file.
Dennis
From: John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)>
To: Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)>
Sent: Saturday, February 6, 2016 1:14 AM
Does anyone have any idea how much voltage is required to fire the starting
vibrator?=C2- I believe the batteries in the Yak 55M are old, and low in
base voltage.=C2- It was cool today, and the airplane was difficult to s
tart.
Is there a replacement starting vibrator available?=C2- Do the originals
from Russia hold up well? =C2-
Thank you!
john b
On Wed, Feb 3, 2016 at 9:14 AM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)> wrote:
Thanks for the response.=C2- Area behind the rear seat has the two air ta
nks which require 8.2 feet separation, the aft fuselage has control cable t
hat require 3 feet clearance plus the rear landing gear assembly.=C2- Win
g tips are a possibility, but the nav lights and strobes are a problem plus
routing the wiring through the wing.=C2- Looks like I may be the first t
o put a G3X in a TW.=C2-Off line response from Sonny Schilleci at Auric A
vionics suggests using a Survey Tool to locate a low noise area.=C2-Jimmy
=C2-From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-serv ([email]owner-yak-list-serv[/email])
er(at)matronics.com (er(at)matronics.com)] On Behalf Of Roger Kemp
Sent: Tuesday, February 2, 2016 9:32 PM
Subject: Re: Garmin G3X installation=C2-Try under the turtle de
ck aft of the rear cockpit. I did that for my Dynon in the 50. Worked fine
on headings after slaving the DG. Mount it first with industrial adhesive b
acked Velcro. That way you can move it if you do not like it.=C2-Doc
On Feb 2, 2016, at 1:58 PM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)> wrote:
I=99m installing a Garmin G3X in my Yak52TW and trying to located a p
lace to install the magnetometer (GMU22).=C2- Has anyone done this instal
lation in a TW or have a suggestion on a location that meets Garmin
=99s requirements for the magnetometer?=C2-Jimmy BurkeJbyak52(at)gmail.com (BurkeJbyak52(at)gmail.com)
________________________________ Message 2 _____________________________________
Time: 04:52:22 AM PST US
From: Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)>
These engines are not easy to start in cold weather.
Ernie
On Sat, Feb 6, 2016 at 7:26 AM, A. Dennis Savarese <
> may not generate an adequate spark.
> components on the airplane. The starting coil wire (7mm) from the
> starting coil to the left magneto cap may be deteriorated and cracked. I
f
> the wire is cracked, it will arc to the braided shield (ground) when you
> press the start button. That would prevent the spark from going to the m
ag
> check the points for mounding. If necessary you can burnish the points t
o
> Dennis
> *From:* John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)>
> *To:* Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)>
> *Sent:* Saturday, February 6, 2016 1:14 AM
> *Subject:* Re: Garmin G3X installation
> starting vibrator? I believe the batteries in the Yak 55M are old, and l
ow
> in base voltage. It was cool today, and the airplane was difficult to
> start.
> Is there a replacement starting vibrator available? Do the originals fro
m
> Thank you!
> john b
> Thanks for the response. Area behind the rear seat has the two air tanks
> which require 8.2 feet separation, the aft fuselage has control cable tha
t
> require 3 feet clearance plus the rear landing gear assembly. Wing tips
> routing the wiring through the wing. Looks like I may be the first to pu
t
> a G3X in a TW.
> Off line response from Sonny Schilleci at Auric Avionics suggests using a
> Jimmy
> *From:* owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:
> owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] *On Behalf Of *Roger Kemp
> *Sent:* Tuesday, February 2, 2016 9:32 PM
> *To:* yak-list(at)matronics.com (yak-list(at)matronics.com)
> Try under the turtle deck aft of the rear cockpit. I did that for my Dyno
n
> in the 50. Worked fine on headings after slaving the DG. Mount it first
> with industrial adhesive backed Velcro. That way you can move it if you d
o
> not like it.
> Doc
> Sent from my iPad
place to
> install the magnetometer (GMU22). Has anyone done this installation in a
> TW or have a suggestion on a location that meets Garmin=99s require
ments for
> the magnetometer?
> Jimmy Burke
> Jbyak52(at)gmail.com (Jbyak52(at)gmail.com)
________________________________ Message 3 _____________________________________
Time: 05:12:58 AM PST US
Absolutely agree and the cold weather just makes it more difficult.
Especially if the battery voltage is low.
Dennis
A. Dennis Savarese
[url=tel:334-546-8182]334-546-8182[/url] (mobile)
www.yak-52.com
Skype - Yakguy1
> Ernie
> <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net) <mailto:dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>> wrote:
> starting coil may not generate an adequate spark.
> cracked. If the wire is cracked, it will arc to the braided shield
> (ground) when you press the start button. That would prevent the
> spark from going to the mag cap and then to the spark plug.
> container and check the points for mounding. If necessary you can
> burnish the points to remove any mounds with a point file.
> Dennis
> *From:* John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com) <mailto:jbsoar(at)gmail.com (jbsoar(at)gmail.com)>>
> <mailto:yak-list(at)matronics.com (yak-list(at)matronics.com)>>
> old, and low in base voltage. It was cool today, and the airplane
> was difficult to start.
> originals from Russia hold up well?
> Thank you!
> john b
> two air tanks which require 8.2 feet separation, the aft
> fuselage has control cable that require 3 feet clearance plus
> the rear landing gear assembly. Wing tips are a possibility,
> but the nav lights and strobes are a problem plus routing the
> wiring through the wing. Looks like I may be the first to put
> a G3X in a TW.
> Jimmy
> *From:*owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)
> <mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)>
> [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)
> <mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)>] *On Behalf Of
> *Roger Kemp
> *To:* yak-list(at)matronics.com (yak-list(at)matronics.com) <mailto:yak-list(at)matronics.com (yak-list(at)matronics.com)>
> for my Dynon in the 50. Worked fine on headings after slaving
> the DG. Mount it first with industrial adhesive backed Velcro.
> Doc
> Sent from my iPad
> Im installing a Garmin G3X in my Yak52TW and trying to
> located a place to install the magnetometer (GMU22). Has
> anyone done this installation in a TW or have a suggestion
> on a location that meets Garmins requirements for the
> magnetometer?
> Jimmy Burke
> Jbyak52(at)gmail.com (Jbyak52(at)gmail.com) <mailto:Jbyak52(at)gmail.com (Jbyak52(at)gmail.com)>
________________________________ Message 4 _____________________________________
Time: 05:30:27 AM PST US
From: George Coy <george.coy(at)gmail.com (george.coy(at)gmail.com)>
We make a solid-state version that we run any voltage. It was aimed at the homebuilders
who want to use a 12 V system
George
> On Feb 6, 2016, at 8:09 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
wrote:
> Absolutely agree and the cold weather just makes it more difficult. Especially
> Dennis
> A. Dennis Savarese
> www.yak-52.com
> Skype - Yakguy1
>> Ernie
>> On Sat, Feb 6, 2016 at 7:26 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net) <mailto:dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>> wrote:
>> Dennis
>> Thank you!
>> john b
>> a G3X in a TW.
>> Jimmy
>> *Roger Kemp
>> Doc
>> Sent from my iPad
>> magnetometer?
>> Jimmy Burke
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
richard.goode(at)russiana Guest
Posted: Sun Feb 07, 2016 9:03 am Post subject: Yak-List Digest: 4 Msgs - 02/06/16 |
Interesting! We get our kits, of which we use many, from Doug, and we agreed a form of exclusivity for red wires, rather than the standard blue. But I'm sure this is not one of ours, since our separation plates are anodised black, and indeed we manufacture these in Hungary and then add them to the kits that we install!
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of John B
Sent: 07 February 2016 16:04
Subject: Re: Yak-List Digest: 4 Msgs - 02/06/16
Thank you!
John B
HTML Version:
Text Version:
Dennis
tart.
Thank you!
john b
Ernie
| Quote: | If the battery voltage drops down to 22 volts or less, the starting coil
f
| Quote: | the wire is cracked, it will arc to the braided shield (ground) when you
ag
| Quote: | cap and then to the spark plug.
o
| Quote: | remove any mounds with a point file.
Dennis
ow
| Quote: | in base voltage. It was cool today, and the airplane was difficult to
start.
m
| Quote: | Russia hold up well?
Thank you!
john b
t
| Quote: | require 3 feet clearance plus the rear landing gear assembly. Wing tips
t
| Quote: | in the 50. Worked fine on headings after slaving the DG. Mount it first
o
| Quote: | not like it.
Doc
place to
| Quote: | install the magnetometer (GMU22). Has anyone done this installation in a
ments for
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
| Quote: | These engines are not easy to start in cold weather.
Ernie
Dennis
Thank you!
john b
a G3X in a TW.
Jimmy
*Roger Kemp
Doc
magnetometer?
Jimmy Burke
George
| Quote: | Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
> Ernie
> Dennis
> Thank you!
> john b
> a G3X in a TW.
> Jimmy
> *Roger Kemp
> Doc
> Sent from my iPad
> magnetometer?
> Jimmy Burke
br> fts!)
believed to be clean.
Posted: Sun Feb 07, 2016 9:22 am Post subject: Yak-List Digest: 4 Msgs - 02/06/16 |
Some mistake here I think, I do not offer a plug wire kit.
Doug
On Sun, Feb 7, 2016 at 8:59 AM, Richard Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)> wrote:
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel: [url=tel:%2B44%20%280%29%201544%20340120]+44 (0) 1544 340120[/url]
Fax: [url=tel:%2B44%20%280%29%201544%20340129]+44 (0) 1544 340129[/url]
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of John B
Thank you!
John B
HTML Version:
Text Version:
Dennis
tart.
Thank you!
john b
Subject: Re: Yak-List: Garmin G3X installation=C2-Try under the turtle de
Ernie
f
ag
o
Dennis
ow
start.
m
Thank you!
john b
t
t
o
Doc
place to
ments for
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
Ernie
Dennis
Thank you!
john b
a G3X in a TW.
Jimmy
*Roger Kemp
*Subject:* Re: Yak-List: Garmin G3X installation
Doc
magnetometer?
Jimmy Burke
George
| Quote: | Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
> Ernie
> Dennis
> Thank you!
> john b
> a G3X in a TW.
> Jimmy
> *Roger Kemp
> Doc
> Sent from my iPad
> magnetometer?
> Jimmy Burke
br> fts!)
Posted: Sun Feb 07, 2016 9:26 am Post subject: Yak-List Digest: 4 Msgs - 02/06/16 |
The point of origin might be important, as I don't have any instructions for the installation of this kit of unknown origin...
On Sun, Feb 7, 2016 at 9:59 AM, Richard Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)> wrote:
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Thank you!
John B
HTML Version:
Text Version:
Dennis
tart.
Thank you!
john b
Ernie
f
ag
o
Dennis
ow
start.
m
Thank you!
john b
t
t
o
Doc
place to
ments for
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
Ernie
Dennis
Thank you!
john b
a G3X in a TW.
Jimmy
*Roger Kemp
Doc
magnetometer?
Jimmy Burke
George
| Quote: | Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
> Ernie
> Dennis
> Thank you!
> john b
> a G3X in a TW.
> Jimmy
> *Roger Kemp
> Doc
> Sent from my iPad
> magnetometer?
> Jimmy Burke
br> fts!)
Posted: Sun Feb 07, 2016 11:11 am Post subject: Yak-List Digest: 4 Msgs - 02/06/16 |
I don't sell the red wire conversion kit. My wires are blue in my kit.
I have sold over 650 kits world wide, in case your interested. You can
see it on my web site, www.yak-52.com
Dennis
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 2/7/2016 11:03 AM, John B wrote:
| Quote: | Auto plug conversion kit?
Thank you!
John B
formatted
Indexes
version
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-02-06&Archive=Yak
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 16-02-06&Archive=Yak
<mailto:dsavarese0812(at)bellsouth.net>>
starting coil ma
component
starti
cracked.=C2- If t
when you pre
to the m
container and ch
points
Dennis
From: John B <jbsoar(at)gmail.com <mailto:jbsoar(at)gmail.com>>
starting
low in
difficult to s
tart.
originals
Thank you!
john b
air ta
control cable t
assembly.=C2- Win
problem plus
first t
Auric A
area.=C2-Jimmy
<mailto:owner-yak-list-server(at)matronics.com>
[mailto:owner-yak-list-serv <mailto:owner-yak-list-serv>
er(at)matronics.com <mailto:er(at)matronics.com>] On Behalf Of Roger Kemp
turtle de
Worked fine
adhesive b
instal
BurkeJbyak52(at)gmail.com <mailto:BurkeJbyak52(at)gmail.com>
From: Ernest Martinez <erniel29(at)gmail.com <mailto:erniel29(at)gmail.com>>
Ernie
dsavarese0812(at)bellsouth.net <mailto:dsavarese0812(at)bellsouth.net>>
starting coil
cracked. I
f
when you
to the m
ag
container and
points t
o
> Dennis
> *From:* John B <jbsoar(at)gmail.com <mailto:jbsoar(at)gmail.com>>
old, and l
ow
difficult to
> start.
originals fro
m
> Thank you!
> john b
air tanks
cable tha
t
Wing tips
first to pu
t
> a G3X in a TW.
suggests using a
> Jimmy
<mailto:owner-yak-list-server(at)matronics.com> [mailto:
<mailto:owner-yak-list-server(at)matronics.com>] *On Behalf Of *Roger
Kemp
> *To:* yak-list(at)matronics.com <mailto:yak-list(at)matronics.com>
for my Dyno
n
it first
if you d
o
> not like it.
> Doc
> Sent from my iPad
place to
installation in a
ments for
> the magnetometer?
> Jimmy Burke
> Jbyak52(at)gmail.com <mailto:Jbyak52(at)gmail.com>
Dennis
A. Dennis Savarese
334-546-8182 <tel:334-546-8182> (mobile)
www.yak-52.com <http://www.yak-52.com>
Skype - Yakguy1
> Ernie
electrical
from the
shield
prevent the
you can
> Dennis
<mailto:jbsoar(at)gmail.com <mailto:jbsoar(at)gmail.com>>>
> <mailto:yak-list(at)matronics.com <mailto:yak-list(at)matronics.com>>>
fire the
airplane
> Thank you!
> john b
plus
possibility,
routing the
to put
> a G3X in a TW.
> Jimmy
<mailto:owner-yak-list-server(at)matronics.com>>
<mailto:owner-yak-list-server(at)matronics.com>>] *On Behalf Of
> *Roger Kemp
<mailto:yak-list(at)matronics.com> <mailto:yak-list(at)matronics.com
that
slaving
Velcro.
> Doc
> Sent from my iPad
(GMU22). Has
suggestion
> magnetometer?
> Jimmy Burke
<mailto:Jbyak52(at)gmail.com <mailto:Jbyak52(at)gmail.com>>
From: George Coy <george.coy(at)gmail.com <mailto:george.coy(at)gmail.com>>
George
<dsavarese0812(at)bellsouth.net <mailto:dsavarese0812(at)bellsouth.net>>
> Dennis
> A. Dennis Savarese
> Skype - Yakguy1
>> Ernie
electrical
from the
shield
prevent the
you can
>> Dennis
fire the
airplane
>> Thank you!
>> john b
plus
possibility,
routing the
to put
>> a G3X in a TW.
>> Jimmy
>> *Roger Kemp
that
slaving
Velcro.
>> Doc
>> Sent from my iPad
(GMU22). Has
suggestion
>> magnetometer?
>> Jimmy Burke
br> fts!)
Posted: Sun Feb 07, 2016 11:13 am Post subject: Yak-List Digest: 4 Msgs - 02/06/16 |
Rickard,
The red wires were offered using a different brand of wires and 8.5 mm
with gray plug boots. The boots are not made of silicone as mine are.
You still have exclusivity on the red wires.
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
On 2/7/2016 11:59 AM, Richard Goode wrote:
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
[mailto:owner-yak-list-server(at)matronics.com] *On Behalf Of *John B
*Sent:* 07 February 2016 16:04
*Subject:* Re: Yak-List Digest: 4 Msgs - 02/06/16
Thank you!
John B
HTML Version:
Text Version:
coil ma
component
you pre
and ch
Dennis
starting
tart.
Thank you!
john b
cable t
plus
adhesive b
Ernie
dsavarese0812(at)bellsouth.net <mailto:dsavarese0812(at)bellsouth.net>> wrote:
cracked. I
f
the m
ag
points t
o
> Dennis
and l
ow
> start.
m
> Thank you!
> john b
tanks
cable tha
t
to pu
t
> a G3X in a TW.
using a
> Jimmy
<mailto:owner-yak-list-server(at)matronics.com>] *On Behalf Of *Roger Kemp
Dyno
n
you d
o
> not like it.
> Doc
> Sent from my iPad
place to
in a
ments for
> the magnetometer?
> Jimmy Burke
Dennis
A. Dennis Savarese
Skype - Yakguy1
> Ernie
> Dennis
> Thank you!
> john b
> a G3X in a TW.
> Jimmy
> *Roger Kemp
> Doc
> Sent from my iPad
> magnetometer?
> Jimmy Burke
the homebuilders
George
Especially
> Dennis
> A. Dennis Savarese
> Skype - Yakguy1
>> Ernie
>> Dennis
>> Thank you!
>> john b
>> a G3X in a TW.
>> Jimmy
>> *Roger Kemp
>> Doc
>> Sent from my iPad
>> magnetometer?
>> Jimmy Burke
br> fts!)
target="_blank">www.buildersbooks.com <http://www.buildersbooks.com>
dangerous content by *MailScanner* <http://www.mailscanner.info/>, and is
Posted: Sun Feb 07, 2016 11:14 am Post subject: Yak-List Digest: 4 Msgs - 02/06/16 |
I believe most of those kits with the 8.5mm red wires with gray boots
were sold and/or installed by Bill Blackwell in Arizona.
You can download the installation instructionsfor my kit from my web site.
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
On 2/7/2016 12:22 PM, John B wrote:
| Quote: | The point of origin might be important, as I don't have any
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel: +44 (0) 1544 340120 <tel:%2B44%20%280%29%201544%20340120>
Fax: +44 (0) 1544 340129 <tel:%2B44%20%280%29%201544%20340129>
www.russianaeros.com <http://www.russianaeros.com>
<mailto:owner-yak-list-server(at)matronics.com>] *On Behalf Of *John B
Thank you!
John B
formatted
Indexes
version
HTML Version:
Text Version:
starting coil ma
component
starti
cracked.=C2- If t
when you pre
to the m
container and ch
points
Dennis
starting
low in
difficult to s
tart.
originals
Thank you!
john b
air ta
control cable t
assembly.=C2- Win
problem plus
first t
Auric A
area.=C2-Jimmy
turtle de
Worked fine
adhesive b
instal
Ernie
starting coil
cracked. I
f
when you
to the m
ag
container and
points t
o
> Dennis
old, and l
ow
difficult to
> start.
originals fro
m
> Thank you!
> john b
air tanks
cable tha
t
Wing tips
first to pu
t
> a G3X in a TW.
suggests using a
> Jimmy
Kemp
for my Dyno
n
it first
if you d
o
> not like it.
> Doc
> Sent from my iPad
place to
installation in a
ments for
> the magnetometer?
> Jimmy Burke
Dennis
A. Dennis Savarese
Skype - Yakguy1
> Ernie
electrical
from the
shield
prevent the
you can
> Dennis
fire the
airplane
> Thank you!
> john b
plus
routing the
to put
> a G3X in a TW.
> Jimmy
> *Roger Kemp
that
slaving
Velcro.
> Doc
> Sent from my iPad
(GMU22). Has
suggestion
> magnetometer?
> Jimmy Burke
George
> Dennis
> A. Dennis Savarese
> Skype - Yakguy1
>> Ernie
electrical
from the
shield
prevent the
you can
>> Dennis
fire the
airplane
>> Thank you!
>> john b
plus
possibility,
routing the
to put
>> a G3X in a TW.
>> Jimmy
>> *Roger Kemp
that
slaving
Velcro.
>> Doc
>> Sent from my iPad
(GMU22). Has
suggestion
>> magnetometer?
>> Jimmy Burke
br> fts!)
r> > w.buildersbooks.com <http://w.buildersbooks.com>"
and is
kregg(at)balancemyprop.co Guest
Posted: Sun Feb 07, 2016 3:29 pm Post subject: Yak-List Digest: 4 Msgs - 02/06/16 |
A good place to get the Spark Plug wiring harness is from Kingston wire in the San Diego, CA area. I think the wiring set is about $80. Then just get the mag plates and plugs
Victory Aero
2502 John Montgomery Dr.
San Jose, CA 95148
408-836-5122
www.victoryhangar.com
www.balancemyprop.com
Sent: Sunday, February 07, 2016 8:04 AM
Thank you!
John B
HTML Version:
Text Version:
Dennis
tart.
Thank you!
john b
Ernie
f
ag
o
Dennis
ow
start.
m
Thank you!
john b
t
t
o
Doc
place to
ments for
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
Ernie
Dennis
Thank you!
john b
a G3X in a TW.
Jimmy
*Roger Kemp
Doc
magnetometer?
Jimmy Burke
George
| Quote: | Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
> Ernie
> Dennis
> Thank you!
> john b
> a G3X in a TW.
> Jimmy
> *Roger Kemp
> Doc
> Sent from my iPad
> magnetometer?
> Jimmy Burke
br> fts!)
Posted: Sun Feb 07, 2016 3:53 pm Post subject: Yak-List Digest: 4 Msgs - 02/06/16 |
I've got the wire, I just don't have any instructions.
On Feb 7, 2016, at 4:26 PM, Kregg Victory <kregg(at)balancemyprop.com (kregg(at)balancemyprop.com)> wrote:
| Quote: | <![endif]--> <![endif]-->
Victory Aero
San Jose, CA 95148
408-836-5122
Thank you!
John B
HTML Version:
Text Version:
Dennis
tart.
Thank you!
john b
Ernie
f
ag
o
Dennis
ow
start.
m
Thank you!
john b
t
t
o
Doc
place to
ments for
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
Ernie
Dennis
Thank you!
john b
a G3X in a TW.
Jimmy
*Roger Kemp
Doc
magnetometer?
Jimmy Burke
George
| Quote: | Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
> Ernie
> Dennis
> Thank you!
> john b
> a G3X in a TW.
> Jimmy
> *Roger Kemp
> Doc
> Sent from my iPad
> magnetometer?
> Jimmy Burke
br> fts!)
rsdie_1(at)yahoo.com Guest
Posted: Sun Feb 07, 2016 9:08 pm Post subject: Yak-List Digest: 4 Msgs - 02/06/16 |
John B,
That kit sounds like the ones Bill Blackwell in AZ was selling about 10 years ago, I bought two, and they worked just great!
Scott Dierolf
| Quote: | On Feb 7, 2016, at 23:49, John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)> wrote:
I've got the wire, I just don't have any instructions.Sent from my iPhone
Victory Aero
San Jose, CA 95148
408-836-5122
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of John BSent: Sunday, February 07, 2016 8:04 AMTo: Yak-List Digest ServerSubject: Re: Yak-List Digest: 4 Msgs - 02/06/16
Thank you!
John B
* ========================= Online Versions of Today's List Digest Archive =========================Today's complete Yak-List Digest can also be found in either of thetwo Web Links listed below. The .html file includes the Digest formattedin HTML for viewing with a web browser and features Hyperlinked Indexesand Message Navigation. The .txt file includes the plain ASCII versionof the Yak-List Digest and can be viewed with a generic text editorsuch as Notepad or with a web browser.HTML Version: dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>Subject: Re: Garmin G3X installationIf the battery voltage drops down to 22 volts or less, the starting coil may not generate an adequate spark.The starting coil is probably one of the most reliable electrical components on the airplane.=C2-=C2- The starting coil wire (7mm) from the starting coil to the left magneto cap may be deteriorated and cracked.=C2- If the wire is cracked, it will arc to the braided shield (ground) when you press the start button.=C2- That would prevent the spark from going to the mag cap and then to the spark plug.After you replace the batteries, open up the starting coil container and check the points for mounding.=C2- If necessary you can burnish the pointsto remove any mounds with a point file.Dennis From: John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)> To: Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)> Sent: Saturday, February 6, 2016 1:14 AM Subject: Re: Garmin G3X installationDoes anyone have any idea how much voltage is required to fire the starting vibrator?=C2- I believe the batteries in the Yak 55M are old, and low in base voltage.=C2- It was cool today, and the airplane was difficult to start.Is there a replacement starting vibrator available?=C2- Do the originalsfrom Russia hold up well? =C2-Thank you!john bOn Wed, Feb 3, 2016 at 9:14 AM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)> wrote:Thanks for the response.=C2- Area behind the rear seat has the two air tanks which require 8.2 feet separation, the aft fuselage has control cable that require 3 feet clearance plus the rear landing gear assembly.=C2- Wing tips are a possibility, but the nav lights and strobes are a problem plus routing the wiring through the wing.=C2- Looks like I may be the first to put a G3X in a TW.=C2-Off line response from Sonny Schilleci at Auric Avionics suggests using a Survey Tool to locate a low noise area.=C2-Jimmy=C2-From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-serv ([email]owner-yak-list-serv[/email])er(at)matronics.com (er(at)matronics.com)] On Behalf Of Roger KempSent: Tuesday, February 2, 2016 9:32 PMSubject: Re: Garmin G3X installation=C2-Try under the turtle deck aft of the rear cockpit. I did that for my Dynon in the 50. Worked fineon headings after slaving the DG. Mount it first with industrial adhesive backed Velcro. That way you can move it if you do not like it.=C2-DocSent from my iPadOn Feb 2, 2016, at 1:58 PM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)> wrote:I=99m installing a Garmin G3X in my Yak52TW and trying to located a place to install the magnetometer (GMU22).=C2- Has anyone done this installation in a TW or have a suggestion on a location that meets Garmin=99s requirements for the magnetometer?=C2-Jimmy BurkeJbyak52(at)gmail.com (BurkeJbyak52(at)gmail.com)________________________________ Message 2 _____________________________________Time: 04:52:22 AM PST USSubject: Re: Garmin G3X installationFrom: Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)>These engines are not easy to start in cold weather.ErnieOn Sat, Feb 6, 2016 at 7:26 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:> If the battery voltage drops down to 22 volts or less, the starting coil> may not generate an adequate spark.>> The starting coil is probably one of the most reliable electrical> components on the airplane. The starting coil wire (7mm) from the> starting coil to the left magneto cap may be deteriorated and cracked. If> the wire is cracked, it will arc to the braided shield (ground) when you> press the start button. That would prevent the spark from going to the mag> cap and then to the spark plug.>> After you replace the batteries, open up the starting coil container and> check the points for mounding. If necessary you can burnish the points to> remove any mounds with a point file.>> Dennis>>> ------------------------------> *From:* John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)>> *To:* Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)>> *Sent:* Saturday, February 6, 2016 1:14 AM> *Subject:* Re: Garmin G3X installation>> Does anyone have any idea how much voltage is required to fire the> starting vibrator? I believe the batteries in the Yak 55M are old, and low> in base voltage. It was cool today, and the airplane was difficult to> start.>> Is there a replacement starting vibrator available? Do the originals from> Russia hold up well?>> Thank you!> john b>> On Wed, Feb 3, 2016 at 9:14 AM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)> wrote:>> Thanks for the response. Area behind the rear seat has the two air tanks> which require 8.2 feet separation, the aft fuselage has control cable that> require 3 feet clearance plus the rear landing gear assembly. Wing tips> are a possibility, but the nav lights and strobes are a problem plus> routing the wiring through the wing. Looks like I may be the first to put> a G3X in a TW.>> Off line response from Sonny Schilleci at Auric Avionics suggests using a> Survey Tool to locate a low noise area.>> Jimmy>> *From:* owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:> owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] *On Behalf Of *Roger Kemp> *Sent:* Tuesday, February 2, 2016 9:32 PM> *To:* yak-list(at)matronics.com (yak-list(at)matronics.com)> *Subject:* Re: Garmin G3X installation>> Try under the turtle deck aft of the rear cockpit. I did that for my Dynon> in the 50. Worked fine on headings after slaving the DG. Mount it first> with industrial adhesive backed Velcro. That way you can move it if you do> not like it.> Doc>> Sent from my iPad>> On Feb 2, 2016, at 1:58 PM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)> wrote:>> I=99m installing a Garmin G3X in my Yak52TW and trying to located a place to> install the magnetometer (GMU22). Has anyone done this installation in a> TW or have a suggestion on a location that meets Garmin=99s requirements for> the magnetometer?>> Jimmy Burke> Jbyak52(at)gmail.com (Jbyak52(at)gmail.com)>>________________________________ Message 3 _____________________________________Time: 05:12:58 AM PST USSubject: Re: Garmin G3X installationFrom: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>Absolutely agree and the cold weather just makes it more difficult.Especially if the battery voltage is low.DennisA. Dennis Savaresedsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net) <mailto:dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>> wrote:>> If the battery voltage drops down to 22 volts or less, the> starting coil may not generate an adequate spark.>> The starting coil is probably one of the most reliable electrical> components on the airplane. The starting coil wire (7mm) from the> starting coil to the left magneto cap may be deteriorated and> cracked. If the wire is cracked, it will arc to the braided shield> (ground) when you press the start button. That would prevent the> spark from going to the mag cap and then to the spark plug.>> After you replace the batteries, open up the starting coil> container and check the points for mounding. If necessary you can> burnish the points to remove any mounds with a point file.>> Dennis>>> ------------------------------------------------------------------------> *From:* John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com) <mailto:jbsoar(at)gmail.com (jbsoar(at)gmail.com)>>> *To:* Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)> <mailto:yak-list(at)matronics.com (yak-list(at)matronics.com)>>> *Sent:* Saturday, February 6, 2016 1:14 AM> *Subject:* Re: Garmin G3X installation>> Does anyone have any idea how much voltage is required to fire the> starting vibrator? I believe the batteries in the Yak 55M are> old, and low in base voltage. It was cool today, and the airplane> was difficult to start.>> Is there a replacement starting vibrator available? Do the> originals from Russia hold up well?>> Thank you!> john b>> On Wed, Feb 3, 2016 at 9:14 AM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)> <mailto:jbyak52(at)gmail.com (jbyak52(at)gmail.com)>> wrote:>> Thanks for the response. Area behind the rear seat has the> two air tanks which require 8.2 feet separation, the aft> fuselage has control cable that require 3 feet clearance plus> the rear landing gear assembly. Wing tips are a possibility,> but the nav lights and strobes are a problem plus routing the> wiring through the wing. Looks like I may be the first to put> a G3X in a TW.> Off line response from Sonny Schilleci at Auric Avionics> suggests using a Survey Tool to locate a low noise area.> Jimmy> *From:*owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)> <mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)>> [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)> <mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)>] *On Behalf Of> *Roger Kemp> *Sent:* Tuesday, February 2, 2016 9:32 PM> *To:* yak-list(at)matronics.com (yak-list(at)matronics.com) <mailto:yak-list(at)matronics.com (yak-list(at)matronics.com)>> *Subject:* Re: Garmin G3X installation> Try under the turtle deck aft of the rear cockpit. I did that> for my Dynon in the 50. Worked fine on headings after slaving> the DG. Mount it first with industrial adhesive backed Velcro.> That way you can move it if you do not like it.> Doc>> Sent from my iPad>> On Feb 2, 2016, at 1:58 PM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)> <mailto:jbyak52(at)gmail.com (jbyak52(at)gmail.com)>> wrote:>> Im installing a Garmin G3X in my Yak52TW and trying to> located a place to install the magnetometer (GMU22). Has> anyone done this installation in a TW or have a suggestion> on a location that meets Garmins requirements for the> magnetometer?> Jimmy Burke> Jbyak52(at)gmail.com (Jbyak52(at)gmail.com) <mailto:Jbyak52(at)gmail.com (Jbyak52(at)gmail.com)>>>________________________________ Message 4 _____________________________________Time: 05:30:27 AM PST USSubject: Re: Garmin G3X installationFrom: George Coy <george.coy(at)gmail.com (george.coy(at)gmail.com)>We make a solid-state version that we run any voltage. It was aimed at the homebuilderswho want to use a 12 V systemGeorgeSent from my iPad> On Feb 6, 2016, at 8:09 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>wrote:>>> Absolutely agree and the cold weather just makes it more difficult. Especiallyif the battery voltage is low.> Dennis>> A. Dennis Savarese> dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net) <mailto:dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>> wrote:>>>> If the battery voltage drops down to 22 volts or less, the>> starting coil may not generate an adequate spark.>>>> The starting coil is probably one of the most reliable electrical>> components on the airplane. The starting coil wire (7mm) from the>> starting coil to the left magneto cap may be deteriorated and>> cracked. If the wire is cracked, it will arc to the braided shield>> (ground) when you press the start button. That would prevent the>> spark from going to the mag cap and then to the spark plug.>>>> After you replace the batteries, open up the starting coil>> container and check the points for mounding. If necessary you can>> burnish the points to remove any mounds with a point file.>>>> Dennis>>>>>> ------------------------------------------------------------------------>> *From:* John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com) <mailto:jbsoar(at)gmail.com (jbsoar(at)gmail.com)>>>> *To:* Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)>> <mailto:yak-list(at)matronics.com (yak-list(at)matronics.com)>>>> *Sent:* Saturday, February 6, 2016 1:14 AM>> *Subject:* Re: Garmin G3X installation>>>> Does anyone have any idea how much voltage is required to fire the>> starting vibrator? I believe the batteries in the Yak 55M are>> old, and low in base voltage. It was cool today, and the airplane>> was difficult to start.>>>> Is there a replacement starting vibrator available? Do the>> originals from Russia hold up well?>>>> Thank you!>> john b>>>> On Wed, Feb 3, 2016 at 9:14 AM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)>> <mailto:jbyak52(at)gmail.com (jbyak52(at)gmail.com)>> wrote:>>>> Thanks for the response. Area behind the rear seat has the>> two air tanks which require 8.2 feet separation, the aft>> fuselage has control cable that require 3 feet clearance plus>> the rear landing gear assembly. Wing tips are a possibility,>> but the nav lights and strobes are a problem plus routing the>> wiring through the wing. Looks like I may be the first to put>> a G3X in a TW.>> Off line response from Sonny Schilleci at Auric Avionics>> suggests using a Survey Tool to locate a low noise area.>> Jimmy>> *From:*owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)>> <mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)>>> [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)>> <mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)>] *On Behalf Of>> *Roger Kemp>> *Sent:* Tuesday, February 2, 2016 9:32 PM>> *To:* yak-list(at)matronics.com (yak-list(at)matronics.com) <mailto:yak-list(at)matronics.com (yak-list(at)matronics.com)>>> *Subject:* Re: Garmin G3X installation>> Try under the turtle deck aft of the rear cockpit. I did that>> for my Dynon in the 50. Worked fine on headings after slaving>> the DG. Mount it first with industrial adhesive backed Velcro.>> That way you can move it if you do not like it.>> Doc>>>> Sent from my iPad>>>> On Feb 2, 2016, at 1:58 PM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)>> <mailto:jbyak52(at)gmail.com (jbyak52(at)gmail.com)>> wrote:>>>> Im installing a Garmin G3X in my Yak52TW and trying to>> located a place to install the magnetometer (GMU22). Has>> anyone done this installation in a TW or have a suggestion>> on a location that meets Garmins requirements for the>> magnetometer?>> Jimmy Burke>> Jbyak52(at)gmail.com (Jbyak52(at)gmail.com) <mailto:Jbyak52(at)gmail.com (Jbyak52(at)gmail.com)>>>>>>===========br> fts!)r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.comrel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin.===========List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List===========FORUMS -eferrer" target="_blank">http://forums.matronics.com===========b Site - -Matt Dralle, List Admin.rel="noreferrer" target="_blank">http://www.matronics.com/contribution===========
Posted: Sun Feb 07, 2016 11:26 pm Post subject: Yak-List Digest: 4 Msgs - 02/06/16 |
Doug – my apologies; of course our kits come from Dennis!
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of doug sapp
Sent: 07 February 2016 17:19
To: yak-list(at)matronics.com
Subject: Re: Re: Yak-List Digest: 4 Msgs - 02/06/16
Doug
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Thank you!
John B
HTML Version:
Text Version:
Dennis
tart.
Thank you!
john b
Ernie
f
ag
o
Dennis
ow
start.
m
Thank you!
john b
t
t
o
Doc
place to
ments for
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
Ernie
Dennis
Thank you!
john b
a G3X in a TW.
Jimmy
*Roger Kemp
Doc
magnetometer?
Jimmy Burke
George
| Quote: | Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
> Ernie
> Dennis
> Thank you!
> john b
> a G3X in a TW.
> Jimmy
> *Roger Kemp
> Doc
> Sent from my iPad
> magnetometer?
> Jimmy Burke
br> fts!)
Posted: Sun Feb 07, 2016 11:44 pm Post subject: Yak-List Digest: 4 Msgs - 02/06/16 |
Fair enough. Would Doug be willing to share the installation instructions
with me? Red separation plates for the mags. Red wires, which are
unmarked, and NGK plugs. This new kit may have been on the shelf for years
