Collie Hat Switches
glastar(at)gmx.net
PostPosted: Tue Feb 02, 2016 1:28 am    Post subject: Collie Hat Switches Reply with quote
I would like to pull the lists wisdom and knowledge.
My dad creates the stick grips out of cherry wood (I have already a pair in my Glastar (don't put the mic key on top!)),
[img]cid:part1.05080802.08060807(at)gmx.net[/img]
 now for the RV10 you have 2 electric trims, one version would be two switches in the panel, but I like to sit in flying position to trim, so a collie hat would be the ideal scenario for me.
What is the list experience (this will be low amps as no direct drive) with that kind of switches? Any sources for it (found some from Digikey).
Many thanks for your ideas, hints, tips coming....
Cheers Werner
 Filesize:  452.51 KB
 Viewed:  2618 Time(s)
trigo(at)mail.telepac.pt
PostPosted: Tue Feb 02, 2016 3:19 am    Post subject: Collie Hat Switches Reply with quote
Werner
I suppose that the guy who sells the Infinity Stick grip also sells the components, including the Hat switch.
Try  http://infinityaerospace.com
Cheers
Carlos
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Werner Schneider
Sent: terça-feira, 2 de Fevereiro de 2016 09:27
Subject: Collie Hat Switches
Cheers Werner
Este e-mail foi enviado a partir de um computador sem vírus protegido pela Avast. www.avast.com
 Filesize:  452.51 KB
ashleysc(at)broadstripe.n
PostPosted: Tue Feb 02, 2016 6:39 am    Post subject: Collie Hat Switches Reply with quote
Hi Werner;
Beautiful stick grip! Questions:
1. Does your Dad do these commercially (i.e. for sale to others)?
2. Is it an ambidextrous design? (I fly with either hand on the grip.)
3. I would only want a coolie hat on top and a push to talk toggle in front.
4. I need two grips.
If yes to all these questions, perhaps we could take the conversation off-line.
Cheers! Stu.
ashleysc(at)broadstripe.net (ashleysc(at)broadstripe.net)
Sent: Tuesday, February 2, 2016 1:26:35 AM
Cheers Werner
 Filesize:  452.51 KB
rv8iator(at)gmail.com
PostPosted: Wed Feb 03, 2016 8:13 am    Post subject: Collie Hat Switches Reply with quote
Otto switch has many to chose from.  Aerospace quality... aerospace price too!
http://www.ottoexcellence.com/products/4-way-mini-trim/
-Chris Stone
RV-8 80802
On Tue, Feb 2, 2016 at 1:26 AM, Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)> wrote:
Cheers Werner
 Filesize:  452.51 KB
 Viewed:  2603 Time(s)
