Skyview Checklists
N456TS
PostPosted: Sat Jan 30, 2016 6:56 pm    Post subject: Skyview Checklists Reply with quote
Hello.
Dynon Skyview now has the option to display checklists. This is the one I use. Naturally, it's a living document, so it might change over time. It does reflect the higher normal fuel pressure range with the newest Rotax engine side pumps.
Checklist below:
Code:
# ALLEGRO N456TS CHECKLIST REVISION A
CHKLST0.TITLE, PRE-FLIGHT
CHKLST0.LINE1,
CHKLST0.LINE2, PRE-FLIGHT COMPLETED
CHKLST0.LINE3, BOOT SKYVIEW ON INTERNAL BAT
CHKLST0.LINE4, SEATBELTS - FASTENED
CHKLST0.LINE5, DOORS CLOSED & LATCHED
CHKLST0.LINE6, PARKING BRAKE - ON
CHKLST0.LINE7, FUEL VALVE - ON
CHKLST0.LINE8, SKYVIEW SET TO EMS
CHKLST0.LINE9, MASTER - ON
CHKLST0.LINE10, FUEL PUMP - ON
CHKLST0.LINE11, PRESS - MIN 2.2PSI,MAX 7.26PSI
CHKLST0.LINE12, STROBES - ON
CHKLST0.LINE13, CHOKE - AS REQUIRED
CHKLST0.LINE14, THROTTLE - IDLE
CHKLST0.LINE15, PROP AREA - CLEAR PROP!
CHKLST0.LINE16, STARTER ENGAGE
CHKLST0.LINE17, WARMUP RPM - 2,000-2,500 RPM
CHKLST0.LINE18, CHOKE - OFF
CHKLST0.LINE19, OIL PRESSURE CHECK
CHKLST0.LINE20, MIN 12 PSI BELOW 3,500 RPM
CHKLST0.LINE21, 29 - 73 PSI ABOVE 3,500 RPM
CHKLST0.LINE22, FUEL PUMP - OFF
CHKLST0.LINE23, MIN 2.2 PSI, MAX 7.26 PSI
CHKLST0.LINE24, FUEL PUMP - ON!
CHKLST0.LINE25, AVIONICS POWER - ON
CHKLST0.LINE26, AUTO PILOT POWER - ON
CHKLST1.TITLE, BEFORE TAKEOFF
CHKLST1.LINE1,
CHKLST1.LINE2, SEAT BELTS - FASTENED
CHKLST1.LINE3, DOORS CLOSED & LATCHED
CHKLST1.LINE4, CHOKE - OFF
CHKLST1.LINE5, FLIGHT CONT - FREE & CORRECT
CHKLST1.LINE6, FLAPS - POSITION 1
CHKLST1.LINE7, VISUALLY CONFIRM FLAPS POS 1
CHKLST1.LINE8, TRIM - SET FOR TAKE OFF
CHKLST1.LINE9, ALTIMETER - SET
CHKLST1.LINE10, COM 1 FREQ - SET
CHKLST1.LINE11, GPS - PROGRAMMED
CHKLST1.LINE12, PARKING BRAKE - CHECK
CHKLST1.LINE13, FUEL QUANTITY - CHECK
CHKLST1.LINE14, FUEL PRESSURE - CHECK
CHKLST1.LINE15, FUEL PUMP - ON
CHKLST1.LINE16, OIL TEMPERATURES
CHKLST1.LINE17, OIL - 100F FOR RUNUP
CHKLST1.LINE18, OIL - 120F FOR TAKEOFF
CHKLST1.LINE19, OIL - MAX 285F
CHKLST1.LINE20, CHT - MAX 300F
CHKLST1.LINE21, IGN CHECK - 3,500-4,000 RPM
CHKLST1.LINE22, IGN MAX DROP - 300 RPM
CHKLST1.LINE23, TRANSPONDER TO ALT
CHKLST1.LINE24, CODE 1200 FOR VFR
CHKLST2.TITLE, CRUISE
CHKLST2.LINE1,
CHKLST2.LINE2, POWER - 4,500 - 5,500 RPM
CHKLST2.LINE3, MAX 5,800 RPM FOR TAKEOFF
CHKLST2.LINE4, 5,800 RPM MAX 5 MINUTES!!
CHKLST2.LINE5, TRIM AS REQUIRED
CHKLST2.LINE6, LIGHTS AS REQUIRED
CHKLST3.TITLE, BEFORE LANDING
CHKLST3.LINE1,
CHKLST3.LINE2, FUEL VALVE - ON - CONFIRM
CHKLST3.LINE3, FUEL QUANTITY - CHECK
CHKLST3.LINE4, FUEL PUMP - ON - CONFIRM
CHKLST3.LINE5, FUEL PRESSURE - CONFIRM
CHKLST3.LINE6, LIGHTS AS REQUIRED - CHECK
CHKLST3.LINE7, FLAPS (BELOW 70 MPH MAX)
CHKLST3.LINE8, APPROACH: 60 - 65 MPH
CHKLST3.LINE9, CLEAR RUNWAY
CHKLST4.TITLE, ENGINE SHUTDOWN
CHKLST4.LINE1,
CHKLST4.LINE2, FLAPS UP
CHKLST4.LINE3, AUTO PILOT SWITCH - OFF
CHKLST4.LINE4, AVIONICS SWITCH - OFF
CHKLST4.LINE5, STROBES - OFF
CHKLST4.LINE6, FUEL PUMP SWITCH - OFF
CHKLST4.LINE7, MASTER SWITCH - OFF
CHKLST4.LINE8, IGNITION SWITCH - OFF
CHKLST4.LINE9, PARKING BRAKE - CHECK
CHKLST5.TITLE, EMERGENCY: LIGHT SIGNALS
CHKLST5.LINE1,
CHKLST5.LINE2, TYPE/COLOR  ON GROUND IN-FLIGHT
CHKLST5.LINE3,
CHKLST5.LINE4, STDY GREEN  TAKEOFF   LAND
CHKLST5.LINE5, FLSH GREEN  TAXI      RETURN
CHKLST5.LINE6, STDY RED    STOP      YIELD
CHKLST5.LINE7, FLSH RED    OFF RNWY  UNSAFE
CHKLST5.LINE8, FLSH WHITE  STARTOVER ----
CHKLST5.LINE9, ALT RED/GN  EXTREME CAUTION
CHKLST6.TITLE, MISC: PHONETIC ALPHABET
CHKLST6.LINE1,
CHKLST6.LINE2, A - Alpha
CHKLST6.LINE3, B - Bravo
CHKLST6.LINE4, C - Charlie
CHKLST6.LINE5, D - Delta
CHKLST6.LINE6, E - Echo
CHKLST6.LINE7, F - Foxtrot
CHKLST6.LINE8, G - Golf
CHKLST6.LINE9, H - Hotel
CHKLST6.LINE10, I - India
CHKLST6.LINE11, J - Juliet
CHKLST6.LINE12, K - Kilo
CHKLST6.LINE13, L - Lima
CHKLST6.LINE14, M - Mike
CHKLST6.LINE15, N - November
CHKLST6.LINE16, O - Oscar
CHKLST6.LINE17, P - Papa
CHKLST6.LINE18, Q - Quebec
CHKLST6.LINE19, R - Romeo
CHKLST6.LINE20, S - Sierra
CHKLST6.LINE21, T - Tango
CHKLST6.LINE22, U - Uniform
CHKLST6.LINE23, V - Victor
CHKLST6.LINE24, W - Whiskey
CHKLST6.LINE25, X - X-Ray
CHKLST6.LINE26, Y - Yankee
CHKLST6.LINE27, Z - Zulu
CHKLST7.TITLE, TRANSPONDER CODES
CHKLST7.LINE1,
CHKLST7.LINE2, VFR - 1200
CHKLST7.LINE3, Hijack - 7500
CHKLST7.LINE4, Radio Fail - 7600
CHKLST7.LINE5, Emergency - 7700
checklist.txt
Allegro Checklist
 Filename:  checklist.txt
 Filesize:  4 KB
 Downloaded:  680 Time(s)
N456TS
