Kellym
Posted: Sun Jan 24, 2016 6:04 pm Post subject: Numbers |
Couple questions
Has anyone reached a concensus on V speeds, or is there much variation
between individual aircraft? I'd like to have starting points for
Vs(vans gives Vso), Vx, Vy, Va and Vmmo.
Second question, for those that got a higher gross wt than Van's
recommended 2700, did you come up with a justification for your DAR?
Something like whether Van's figure is for utility category or normal
category? I know on 2 place RV's folks have calculated back from the
known requirements for aerobatic flight to show that for the stated
aerobatic wt and balance Gs that a certain wt would fall withing normal
or utility G limits. Of cpurse that doesn't work for the -10 that isn't
designed for aerobatic use. Not saying one needs justification, but
would be nice to have.
Kelly
finally finishing
KCHD |
Dave Saylor
Posted: Sun Jan 24, 2016 7:31 pm Post subject: Numbers |
Here's what I use. I'm sure there's debate about what constitutes "best glide" and other parameters.
I can't speak to GW increases.
--Dave
On Sun, Jan 24, 2016 at 5:55 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
| Quote: | --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Couple questions
Has anyone reached a concensus on V speeds, or is there much variation between individual aircraft? I'd like to have starting points for Vs(vans gives Vso), Vx, Vy, Va and Vmmo.
Second question, for those that got a higher gross wt than Van's recommended 2700, did you come up with a justification for your DAR?
Something like whether Van's figure is for utility category or normal category? I know on 2 place RV's folks have calculated back from the known requirements for aerobatic flight to show that for the stated aerobatic wt and balance Gs that a certain wt would fall withing normal or utility G limits. Of cpurse that doesn't work for the -10 that isn't designed for aerobatic use. Not saying one needs justification, but would be nice to have.
Kelly
finally finishing
br> fts!)
r> > href="http://www.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
N921AC_Speeds.pdf |
52.56 KB |
546 Time(s) |
_________________ --Dave
KWVI |
jdriggs49(at)msn.com Guest
Posted: Sun Jan 24, 2016 7:32 pm Post subject: Numbers |
My DAR never said anything about my using 2800 pounds.
| Quote: | On Jan 24, 2016, at 8:20 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
Couple questions
Kelly
finally finishing
kearney
Posted: Mon Jan 25, 2016 7:06 am Post subject: Re: Numbers |
Hi Dave
I was looking at your V speeds and noticed that the Vne is 200KIAS. The Vne for the -10 should be 200 KTAS according to Vans.
Cheers
Les
EdKranz
Joined: 29 Dec 2010 Posts: 132 Location: Hastings, MN
Posted: Mon Jan 25, 2016 7:06 am Post subject: Numbers |
My DAR didn't question it at all either. He just confirmed that I'd be testing the flight envelope at full gross, whatever I chose (2800#). I don't have the numbers with me, but I think stall only went up like 1 knot at 2800# vs me solo w/ full fuel.
On Sun, Jan 24, 2016 at 9:29 PM, Danny Riggs <jdriggs49(at)msn.com (jdriggs49(at)msn.com)> wrote:
| Quote: | --> RV10-List message posted by: Danny Riggs <jdriggs49(at)msn.com (jdriggs49(at)msn.com)>
_________________ Ed Kranz
RV10
Finishing
www.edandcolleen.com |
Dave Saylor
Posted: Mon Jan 25, 2016 5:32 pm Post subject: Numbers |
Les,
I'll add an asterisk:
*Standard day, Sea Level
On Mon, Jan 25, 2016 at 7:06 AM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
| Quote: | --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi Dave
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=452261#452261
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
KWVI |
Dave Saylor
Posted: Mon Jan 25, 2016 7:55 pm Post subject: Numbers |
OK, I really did add an asterisk to the AOM. The checklist (Appendix 1 to the AOM) will probably be inaccurate for a while. See attached.
Which makes me wonder: does anyone have an EFIS that presents VNE in terms of TAS? My AF3400 does not, but it displays TAS below the IAS tape.
--Dave
On Mon, Jan 25, 2016 at 5:25 PM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
| Quote: | Les,
Hi Dave
Cheers
Les
br> fts!)
Section_2.pdf |
76.37 KB |
606 Time(s) |
KWVI |
Bob Turner
Posted: Mon Jan 25, 2016 8:10 pm Post subject: Re: Numbers |
| EdKranz wrote: | My DAR didn't question it at all either. He just confirmed that I'd be testing the flight envelope at full gross, whatever I chose (2800#). I don't have the numbers with me, but I think stall only went up like 1 knot at 2800# vs me solo w/ full fuel.
On Sun, Jan 24, 2016 at 9:29 PM, Danny Riggs <jdriggs49> wrote:
| Quote: | --> RV10-List message posted by: Danny Riggs <jdriggs49>
Stall speed goes up like the square root of the weight, so a 4% increase in gross raises Vs 2% which is about 1knot. But solo you may have been 20% under gross, so Vs should have dropped 10%, or about 6 knots, not 1.
To the OP: Va is usually a calculated speed and, unless there is some reason to make it smaller, is usually the square root of the design load limit times the stall speed. Load limit = 3.8, square root of 3.8 = 1.95, multiply that tiimes Vs1 to get Va.
_________________ Bob Turner
RV-10 QB |
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Mon Jan 25, 2016 8:23 pm Post subject: Re: Numbers |
Dave Saylor wrote: "Which makes me wonder: does anyone have an EFIS that presents VNE in terms of TAS? My AF3400 does not, but it displays TAS below the IAS tape."
I am not 100% sure, but I think my GRT Hxr allows me to set the VNE bug using IAS or TAS. I seem to remember that on the setup. I will check it out when I go to the airport tomorrow.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
kearney
Posted: Mon Jan 25, 2016 8:25 pm Post subject: Numbers |
Hi Dave
What I did was calculate at Vne kn KIAS and used that on my AFS 4500 screens. Not perfect but it seems to work for me.
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Saylor
Sent: Monday, January 25, 2016 8:45 PM
Subject: Re: Re: Numbers
--Dave
Les,
Hi Dave
Cheers
Les
br> fts!)
Kellym
Posted: Mon Jan 25, 2016 8:36 pm Post subject: Numbers |
Dynon Skyview allows setting Vne as KTAS
On 1/25/2016 9:23 PM, dmaib(at)me.com wrote:
David Maib
RV-10 #40559
http://forums.matronics.com/viewtopic.php?p=452279#452279
KCHD |
Dave Saylor
Posted: Mon Jan 25, 2016 8:55 pm Post subject: Numbers |
Nice.
On Mon, Jan 25, 2016 at 8:32 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
On 1/25/2016 9:23 PM, dmaib(at)me.com (dmaib(at)me.com) wrote:
| Quote: | --> RV10-List message posted by: "dmaib(at)me.com (dmaib(at)me.com)" <dmaib(at)me.com (dmaib(at)me.com)>
David Maib
RV-10 #40559
br> fts!)
KWVI |
Dave Saylor
Posted: Mon Jan 25, 2016 9:00 pm Post subject: Numbers |
Les,
I may make up a placard some day (I have one for a few VAs at various weights) but for now I'll try to remember to keep it under 200KTAS.
Thanks for the reminder,
--Dave
On Mon, Jan 25, 2016 at 8:22 PM, Les Kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
Hi Dave
Cheers
Les
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of David Saylor
--Dave
Les,
Hi Dave
Cheers
Les
br> fts!)
KWVI |
dmaib@me.com
Posted: Tue Jan 26, 2016 3:05 pm Post subject: Re: Numbers |
Checked today and GRT Hxr allows display of TAS VNE as IAS. So, today at 3500 feet msl and about 12 degrees C, my VNE was shown as about 191 KIAS. I haven't had a chance to check that on the whiz wheel, but the number seemed reasonable.
RV-10 #40559
Bob Turner
Posted: Tue Jan 26, 2016 5:18 pm Post subject: Re: Numbers |
I'm sure Vans' lawyers are telling him to never say anything, but I do wish the company was a little more forth-coming. Was the prototype dived to some speed? At what altitude (surely higher than sea level)? This whole business of specifying Vne as a TAS, when the FARs require specifying it (along with altitudes, if necessary) in IAS for normally certified aircraft, just bothers me.
PS Dave, your ias/tas conversion looks about right to me.
RV-10 QB |
Kellym
Posted: Tue Jan 26, 2016 7:34 pm Post subject: Numbers |
Van's has a white paper on the subject on their website. Thy physics say
the design flutter speed is a function of TAS. They make the case that
extra horsepower via turbo or other engine mods risks being able to
exceed the number in level cruise at altitude around 12K and up.
Type certified aircraft have to convert that to IAS with some empirical
evidence of margin of safety via dive testing. Doing the testing is
likely to be rather expensive by the time you instrument the airframe,
mount drag chutes, quick release doors and risk loss of the aircraft if
calculations are wrong. While loss of an aileron is relatively benign,
loss of elevator or rudder is considerably more serious.
On 1/26/2016 6:18 PM, Bob Turner wrote:
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=452329#452329
KCHD |
Bob Turner
Posted: Tue Jan 26, 2016 8:31 pm Post subject: Re: Numbers |
| Kellym wrote: | Van's has a white paper on the subject on their website. Thy physics say
| [/quote]
I've read the white paper. It contains a certain amount of nonsense. Flutter depends on TAS and air density. IAS depends on TAS and density. So between TAS, IAS, and density one can choose any two to express the equations. For example, with lift, we often choose IAS and density, because the density magically drops out of the equations. Does this mean lift doesn't depend on density? Of course not. It's included in just the right way in the definition of IAS. Now with flutter, there are many possible modes, and the relationship between density and TAS varies from one mode to the next. So it is not possible to define it away for all cases. You need, in general, two variables. It is not correct to say "flutter depends on (only) TAS".
This business of higher than standard power is a red herring. Any standard -10, when light, can climb well into the flight levels. Nose it over to come down, and you can easily get as high a speed as desired. I would like to know, whether thru analysis or testing, where certain airspeeds (IAS or TAS) AND densities need to be observed as limiting.
RV-10 QB |
Posted: Wed Jan 27, 2016 5:20 am Post subject: Numbers |
I thought there general requirement to specify Vne in IAS for certified
planes is because many planes did not have direct TAS instrumentation.
I assume that any inaccuracies resulting from density effects are
reflected in conservative Vne figures.
We all want the freedom to build the way we want them. I'd be very
hesitant to publish such numbers given my lack of control over the product.
Bill "just thinking out loud"
On 1/26/2016 11:31 PM, Bob Turner wrote:
| Quote: | I've read the white paper. It contains a certain amount of nonsense.
limiting. -------- Bob Turner RV-10 QB Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=452335#452335
Kellym
Posted: Wed Jan 27, 2016 7:07 am Post subject: Numbers |
Seems like a few facts are muddled in this discussion.
1. True airspeed is a direct function of density altitude, there is no
independent variable.
2. Flutter is a direct function of TAS, as the speed of air over the
control surface induces a certain harmonic frequency.
3. Most aircraft can exceed Vne or design flutter speed in a dive. Some
turbo charged aircraft and higher power normally aspirated aircraft can
exceed Vne in level flight. That is what Vans was concerned about.
4. Virtually all turbine aircraft have a "barber pole" speed that is
their limit for given density altitude. Above certain altitude it
becomes a mach number. Same exact concept, just at higher speeds. The do
not exceed speed varies substantially as they go higher.
There are ways to increase the design flutter speed by upgrading control
surfaces. I don't know much about that beyond weight and stiffness of
the surface, along with counter balancing are factors.
On 1/27/2016 6:15 AM, Bill Watson wrote:
> http://www.matronics.com/contribution
KCHD |
glastar(at)gmx.net Guest
Posted: Wed Jan 27, 2016 7:44 am Post subject: Numbers |
Bob,
you always could convert the TAS to a IAS/Altitude table if you want,
the beauty of having it in TAS (and maybe your EFIS can display this as
well), is that
wherever you fly your limit will be correct.
I myself prefer it that way instead of looking at a table buried on the
lower left panel like in a Cirrus.
my 2 cents Werner
On 27.01.2016 02:18, Bob Turner wrote:
