bbradburry(at)verizon.net Guest
Posted: Tue Jan 19, 2016 5:39 pm Post subject: Carling S700 2-3 switch failure. |
This manual switch is in a high (8 amps?) fast switching injector circuit. I use it to disable the primary or secondary injectors prior to flight to determine if the engine will run on only one set of injectors. It failed in flight and the engine went very lean running on only one set of injectors.
The switch initially had no continuity but made a high resistance contact after flipping it back and forth a few times.
Should I replace this switch with a more robust one and if so, where would I find a suitable switch?
Joined: 28 Mar 2008 Posts: 1974 Location: Riley TWP Michigan
Posted: Tue Jan 19, 2016 7:59 pm Post subject: Re: Carling S700 2-3 switch failure. |
Yes, the switch should be replaced. Choose a switch rated at 10 or more amps. There are some switches that have the terminals riveted to the plastic housing. Do NOT use that kind. They depend of the rivets to conduct the current. Bad idea because rivets in plastic loosen over time. Switches need to be exercised periodically to wear away corrosion. Switches in airplanes do not get much exercise and will fail from corrosion before mechanically wearing out. The S700 2-3 is B & C's part number for a generic DPDT ON-ON switch.
If the load is inductive, a diode connected between the load side of the switch and ground will protect the switch against arcing. The diode arrow should point towards positive.
_________________ Joe Gores |
Posted: Wed Jan 20, 2016 8:04 am Post subject: Carling S700 2-3 switch failure. |
At 07:38 PM 1/19/2016, you wrote:
| Quote: | This manual switch is in a high (8 amps?) fast switching injector circuit. I use it to disable the primary or secondary injectors prior to flight to determine if the engine will run on only one set of injectors. It failed in flight and the engine went very lean running on only one set of injectors.
The switch initially had no continuity but made a high resistance contact after flipping it back and forth a few times. |
First, I would REALLY like to have that switch
for failure analysis. How much time did you
have on the switch?
How is this switch wired? does the switch carry
injector currents in BOTH positions?
Should I replace this switch with a more robust one and if so, where would I find a suitable switch? |
There are many more robust switches suited to
the task not the least of which is this device
http://tinyurl.com/jhkg6ep
. . . but it's not clear to me that the S700-2-3
was not suited to the task either. It would be useful
for us to study the circumstance of the failure and
the in-flight situatin you encounted when it did.
