dlm34077
Posted: Tue Jan 05, 2016 7:55 am Post subject: wing jacks |
Also don't forget the tail tie down of a couple of hundred pounds. My tie
down is on rollers. The tail tie down ring is steel. I thought of using a
hook but that was a little too much.
_____
Sent: Tuesday, January 5, 2016 7:48 AM
To: 'Patrick Pulis'
Subject: build them
Use 1" threaded rod from www.McMastercarr.com <http://www.mcmastercarr.com/>
and a threaded nut; weld to top of standard 3 ton jack.
David McNeill
480-626-4048
N46007 tt1000+
CFII A&P
