drc(at)wscare.com Guest
Posted: Sun Jan 03, 2016 12:15 pm Post subject: Describe the technique for a perfect Hammerhead in a Yak 5 |
Agree with Bill’s response. Most importantly the slight forward and left stick.
At the very slow airspeed at the top, if you apply any back stick or load, be prepared for a snap. The 55 is more sensitive to this than the 52 as the center of lift is closer to the CG. Also it will not pivot quite as fast as the 52 fore the same reason.
The slight forward stick unloads the wing and prevents the snap.
The left stick is to compensate for a roll tendency at the top as the left wing is moving faster than the right wing and creates a slight lift - and a slight roll tendency.
I would not be as concerned w entry speeds right away - the faster you go, the longer the vertical ride.
Start high !! Give plenty of room in case of error.
300 kph is about 160 knots. You can easily dive to 200knts / 230 mph / 370 kph for a nice hammerhead.
Believe it or not the 55 has a higher induced drag than the 52 and energy management is what you will work on the most, so heed what Bill says and pull to only about 4-5 G.
Have fun and fly safe. Once you get the hammerhead down, work on the humpty pull-pull-pull
When at the top just milk the elevator by back stick and unload, back stick and unload, repeat until the nose comes over the top and starts down. It will be very slow and graceful in the 55 !!
Herb
Dr. Herbert Coussons
main 920.338.6868
fax 888.876.4773
cell 920.639.8434
(at)DrC_WSC
[img]cid:0AEC9E78-9DFD-4F58-A5BE-DA155CD5EC8A[/img]
Green Bay • Appleton • Marinette
womens-specialtycare.com
This message is being sent by Dr Herbert Coussons, MD. It is intended exclusively for the individuals and entities to which it is addressed. This communication, including any attachments, may contain information that is proprietary, privileged, confidential, including information that is protected under the HIPAA privacy rules, or otherwise legally exempt from disclosure. If you are not the named addressee, you are not authorized to read, print, retain, copy or disseminate this message or any part of it. If you have received this message in error, please notify the sender immediately by email and delete all copies of this message. This message is protected by applicable legal privileges and is confidential.
25.01 KB |
1839 Time(s) |
