Posted: Mon Dec 28, 2015 8:31 am Post subject: stratux ads-b |
Changed the subject!!!
Thanks for the links! As I read it, the Pi GPS is only needed if your device does not have one. Not a problem for most folks.
I took the receiver cases off, used a piece of credit card as a separator and used one top half and one lower half .... and used metal tape to keep them together. Leave enough 'open area' for the heat to escape.
I've been in electronics all my working life and I wouldn't think of soldering wires to the 40 pin connector.
You can get a short cable at Amazon http://tinyurl.com/q4kqwn2 and cut off the male connector.
Linn
On 12/28/2015 10:27 AM, Justin Jones wrote:
| Quote: | It looks like you may not have gotten the correct software loaded onto your SD card that is in the Raspberry PI. Take a look at the following links to see if they can help.
https://github.com/ssokol/stratux/wiki/Stratux-Beginner's-Guide#options-and-enhancements
http://www.pilotsofamerica.com/forum/showthread.php?t=85058&page=1
| Quote: | On Dec 27, 2015, at 7:07 AM, P Reid <[url=mailto:rv10flyer(at)live.com]rv10flyer(at)live.com (rv10flyer(at)live.com)[/url]> wrote:
--> RV10-List message posted by: P Reid <rv10flyer(at)live.com (rv10flyer(at)live.com)> Albert I am using stratux on iflightplanner and fltplan.go In both cases the config was done via choosing ADS-B and picking "clarity" or port 4000 if I did it manually on fltplanGO. I've done 192.168.10.1 for configs. Never see the screen you attached. No traffic on fltplanGO but visible on iflightplanner. Stratux works very nicely for weather updates on both. | Quote: | | On Dec 27, 2015, at 7:34 AM, Albert <ibspud(at)roadrunner.com (ibspud(at)roadrunner.com)> wrote: Well, this whole Stratux thing get me going so I bought the Pi and the 2 radios plus cables on Amazon. Put them together, very easy-just plug together- and then downloaded the software. Got the disk image file for the micro SD card (stratux-v0.5b2-e6ad9aa830-12212015) from the zip file download. Used Win32DiskImager to copy it to the SD card then put the SD card in my Raspberry Pi computer and fired it up. I was expecting it to be configured as an ADS-B receiver already to receive broadcasts and connect to my ipad with Foreflight but the monitor connected to the Raspberry Pi shows a screen that asks for basic configuration information. Some of the item seem straightforward but don't know what to answer for others. (Screenshot attached) Has anyone already gone through the setup? Could use some help at this point. Albert Gardner RV-10 N991RV Yuma, AZ <Raspberry Pi Initial Setup.jpg> | http://www.matronics.com/Navigator?RV10-List http://www.matronics.com/contribution
Albert Gardner
Posted: Tue Dec 29, 2015 4:42 pm Post subject: stratux ads-b |
Well, here is the finished product except for a custom case to put it all in. So far I'm just using the plastic case the Pi came with. I'm trying it out using a splitter and 1 antenna. The big black rectangular object is a battery so it will be portable. The 4 USB hubs are very close together and the radios are too large to fit in them side-by-side so you will need the short M/F USB cables to get them away from the Pi. This was by far one of the simplest projects I've ever done and now I'm ordering a GPS to add since my ipad doesn't have one built in.
Thanks for all the help from the list. You are worth your weight in gold.
Albert Gardner
RV-10 N991RV
Yuma, AZ
PS: I also attached the shopping list that I was given to get me started.
11.66 KB |
5141 Time(s) |
13.47 KB |
5141 Time(s) |
Stratux_Shopping_List.docx |
17.87 KB |
343 Time(s) |
RV-10 N991RV |
deej(at)deej.net Guest
