flysrv10(at)gmail.com Guest
Posted: Mon Dec 21, 2015 5:45 am Post subject: Oil cooler tube |
Anyone has a source for the oil cooler tube, prefabricated with finished ends?
Thanks.
Sent from my iPad
Kelly McMullen
Posted: Mon Dec 21, 2015 6:14 am Post subject: Oil cooler tube |
Are you talking about the 4" scat tube, or one of the oil hoses? I'm not aware of a prefab unit for the former. The hoses are available from Vans or most any hose shop can make to order. Bill Curtis used to have the hose numbers and specifications on his website, might still be there.
On Mon, Dec 21, 2015 at 6:40 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
| Quote: | --> RV10-List message posted by: Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)>
Thanks.
Sent from my iPad
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
-Matt Dralle, List Admin.
FORUMS -
b Site -
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Mon Dec 21, 2015 6:34 am Post subject: Oil cooler tube |
Talking about the 4" scat.
I will,look him up. Thanks for the info.
Rob Kermanj
Sent from my iPad
On Dec 21, 2015, at 7:10 AM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
| Quote: | Are you talking about the 4" scat tube, or one of the oil hoses? I'm not aware of a prefab unit for the former. The hoses are available from Vans or most any hose shop can make to order. Bill Curtis used to have the hose numbers and specifications on his website, might still be there.
civengpe
Posted: Mon Dec 21, 2015 7:44 am Post subject: Oil cooler tube |
Rob,I believe the scat tube is just the normal stuff you can order at Aircraft Spruce. http://www.aircraftspruce.com/catalog/appages/scat.php 05-29916.
Shannon Hicks
Waiting on Glo Custom!
On Mon, Dec 21, 2015 at 8:31 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
| Quote: | Talking about the 4" scat.
Rob Kermanj
Sent from my iPad
Posted: Tue Dec 22, 2015 5:03 am Post subject: Oil cooler tube |
Thanks Shannon,
I thought there was an outfit that fabricated finished ends so the wire would not fight and stab the installer. So far no luck in locating one.
Do not archive.
Rob Kermanj
Sent from my iPad
On Dec 21, 2015, at 8:41 AM, Shannon Hicks <civeng123(at)gmail.com (civeng123(at)gmail.com)> wrote:
| Quote: | Rob,I believe the scat tube is just the normal stuff you can order at Aircraft Spruce. http://www.aircraftspruce.com/catalog/appages/scat.php 05-29916.
Shannon Hicks
Rob Kermanj
Sent from my iPad
flying-nut(at)cfl.rr.com Guest
Posted: Tue Dec 22, 2015 5:14 am Post subject: Oil cooler tube |
This fix is easy .....
Once the scat tube is cut to length, pill out the wire so you have 1/2" or so of the duct without any wire. put a 'loop' in the end of the wire so the end is away from the tube and stuff the wire back inside the tube. You will end up with the wire down inside the tube and the loop keeps the end from poking through it. The wire does not go on the flange.
Linn
On 12/22/2015 7:59 AM, Rob Kermanj wrote:
| Quote: | Thanks Shannon,
Do not archive.
Rob Kermanj
Sent from my iPad
On Dec 21, 2015, at 8:41 AM, Shannon Hicks <[url=mailto:civeng123(at)gmail.com]civeng123(at)gmail.com (civeng123(at)gmail.com)[/url]> wrote:
| Quote: | Rob, I believe the scat tube is just the normal stuff you can order at Aircraft Spruce. http://www.aircraftspruce.com/catalog/appages/scat.php 05-29916.
Shannon Hicks
Rob Kermanj
Sent from my iPad
On Dec 21, 2015, at 7:10 AM, Kelly McMullen <[url=mailto:apilot2(at)gmail.com]apilot2(at)gmail.com (apilot2(at)gmail.com)[/url]> wrote:
civengpe
Posted: Tue Dec 22, 2015 5:23 am Post subject: Oil cooler tube |
Rob,I hear ya. I used to hate dealing with SCAT hose until someone showed me how. Here is an EAA video on one easy technique.
http://www.eaavideo.org/video.aspx?v=971229645001
Good luck!
Shannon Hicks
On Tue, Dec 22, 2015 at 6:59 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
Do not archive.
Rob Kermanj
Sent from my iPad
Shannon Hicks
Rob Kermanj
Sent from my iPad
Posted: Tue Dec 22, 2015 7:25 am Post subject: Oil cooler tube |
Thanks a bunch. Great video.
Rob Kermanj
Sent from my iPad
[quote] On Dec 22, 2015, at 6:19 AM, Shannon Hicks <civeng123(at)gmail.com> wrote:
Rob,
Good luck!
Shannon Hicks
> On Tue, Dec 22, 2015 at 6:59 AM, Rob Kermanj <flysrv10(at)gmail.com> wrote:
> Thanks Shannon,
> Do not archive.
> Rob Kermanj
> Sent from my iPad
>> On Dec 21, 2015, at 8:41 AM, Shannon Hicks <civeng123(at)gmail.com> wrote:
>> Rob,
Posted: Tue Dec 22, 2015 7:28 am Post subject: Oil cooler tube |
Thanks Lynn. Got it.
Rob Kermanj
Sent from my iPad
[quote] On Dec 22, 2015, at 6:10 AM, Linn Walters <flying-nut(at)cfl.rr.com> wrote:
Linn
> Thanks Shannon,
> Do not archive.
> Rob Kermanj
> Sent from my iPad
>> Rob,
