Lycoming O-360 Fuel Flow Rate
Goto page 1, 2  Next
Site Admin
PostPosted: Fri Dec 18, 2015 2:40 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
I'm still chasing down this weird problem with low fuel flow rates on the RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both of which were well over do for replacement/overhaul anyway. I haven't put the cowling back on yet, but I did a static run up to about 2350-2400 and am seeing about 9gph, which seems low to me?
I pulled the fuel line off the carburetor and turned the electric fuel pump on and saw about 21 GPH flow. Is that considered "normal" or too low?
Thanks for the feedback,
Matt
Status: 210+ Hours TTSN - Version 2.0 Now Flying!
Status: 300+ Hours - Full Flyer Mode!
Matt's Livermore Airport Live ATC Stream!
Check out the live ATC stream directly from my hangar at the Livermore
Airport. Includes both Tower and Ground transmissions. Archives too!
For entertainment purposes only. http://klvk.matronics.com
Site Admin
Matt
Site Admin
Matt
Site Admin
PostPosted: Fri Dec 18, 2015 2:43 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
Matt
ceengland7(at)gmail.com
PostPosted: Fri Dec 18, 2015 3:26 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
Matt
Never paid much attention to my flow when doing a static runup, but that
doesn't sound too unreasonable. If CS & flat pitch, it won't take much
power to get to 2400rpm. What's the MAP? You should be able to use Lyc's
power charts to see MAP/rpm/power. 75% on a 180 is around 10 GPH, if
leaned. Obviously lower fuel flow if you're under 24".
I think that the FAA recommends 125% of max power flow if running a pump
(150% for gravity feed). Max power flow would be (180 * .6)/6=18GPH.
That would assume a very rich mixture of .6 lbs per HP per hour. So your
electric pump flow sounds more than adequate.
It's really odd that you didn't see any degraded performance when your
flow went from 17 down to 9 gph in climbout, unless it's some sort of
instrumentation issue giving false readings. Hard to explain two
different flow monitors making the same error, but hard to explain the
performance, too. Smile
Having said that, if you were seeing 9gph in a full power (2700rpm, full
rich, 29"MAP) before, and you're now seeing the same flow on the ground,
with less than full throttle, flat pitch & 2400 rpm, then *something*
must be better now.
Kellym
PostPosted: Fri Dec 18, 2015 4:30 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
While fuel flow numbers are good general indicators, EGT will tell you
more. On takeoff at sea level you should see 1200-1300 EGT with 1250
optimal. If your fuel flow is too low EGT will go well above 1300.
Assuming 180 hp version, Fuel flow for takeoff should be around 16-18
gph. Cruise at 75% should be 9-9.5 gph.
> or too low?
> Matt
> Matt Dralle
that doesn't sound too unreasonable. If CS & flat pitch, it won't take
much power to get to 2400rpm. What's the MAP? You should be able to
use Lyc's power charts to see MAP/rpm/power. 75% on a 180 is around 10
GPH, if leaned. Obviously lower fuel flow if you're under 24".
pump (150% for gravity feed). Max power flow would be (180 *
.6)/6=18GPH. That would assume a very rich mixture of .6 lbs per HP
per hour. So your electric pump flow sounds more than adequate.
full rich, 29"MAP) before, and you're now seeing the same flow on the
ground, with less than full throttle, flat pitch & 2400 rpm, then
*something* must be better now.
Kelly McMullen
KCHD
PostPosted: Fri Dec 18, 2015 5:00 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
135 hp & 9 gph would be .4 lbs per hp per hour. That's pretty
impressive, for an air cooled gasoline engine with 8.5-1 compression.
What do the Lyc charts say?
>> or too low?
>> Matt
>> Matt Dralle
> take much power to get to 2400rpm. What's the MAP? You should be able
> to use Lyc's power charts to see MAP/rpm/power. 75% on a 180 is
> around 10 GPH, if leaned. Obviously lower fuel flow if you're under 24".
> your flow went from 17 down to 9 gph in climbout, unless it's some
> sort of instrumentation issue giving false readings. Hard to explain
> two different flow monitors making the same error, but hard to
> explain the performance, too. Smile
flying-nut(at)cfl.rr.com
PostPosted: Fri Dec 18, 2015 7:02 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
EGT varies significantly depending on where the probes are in relation
to the flange, and also radially. EGT is most valuable as a comparison
to the history ..... significant change in EGT will alert you to a
change in that cylinders operation, but the actual number (historically)
really doesn't tell you much. Properly calibrated FF and a MP gauge
will tell you far more about power.
Linn (IMHO)
>> or too low?
>> Matt
>> Matt Dralle
Kellym
PostPosted: Fri Dec 18, 2015 9:07 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
I don't disagree with your points in general, but they are not
particularly relevant for this situation.
1. His fuel flow has demonstrated to be unreliable, so is not properly
calibrated.
2. At full power installation variations are minimized due to the
velocity and volume of exhaust, compared to cruise settings.
3. 1200-1300 are very reliable numbers. Whether it varies 25 degrees one
way or the other is not important. It is important that it be within
that 100 degree range to indicate combustion approximately 150-200 ROP.
Given he does not know if his fuel flow is working, only the EGT will
confirm fuel flow.
The actual temp will vary from engine to engine and with OAT. That is
why it is a range, not a single number. He wants to know if his fuel
flow is in the ballpark to safely operate the engine, not if it is optimal.
comparison to the history ..... significant change in EGT will alert
you to a change in that cylinders operation, but the actual number
(historically) really doesn't tell you much. Properly calibrated FF
and a MP gauge will tell you far more about power.
Linn (IMHO)
> you more. On takeoff at sea level you should see 1200-1300 EGT with
> 1250 optimal. If your fuel flow is too low EGT will go well above 1300.
>>> Matt
>>> Matt Dralle
>> able to use Lyc's power charts to see MAP/rpm/power. 75% on a 180 is
>> 24".
>> the ground, with less than full throttle, flat pitch & 2400 rpm,
>> then *something* must be better now.
Kelly McMullen
KCHD
PostPosted: Sat Dec 19, 2015 4:52 am    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
We really do agree ..... for Matt's case. Too many listers (me included
Razz ) read posts and take the content as being applicable in a broad
sense. I didn't want a whole new thread to result because others aren't
getting EGTs in that specific range. I have friends that are completely
anal about their EGT readings ..... especially when they have a new (to
them) engine monitoring system.
Linn
calibrated.
one way or the other is not important. It is important that it be
within that 100 degree range to indicate combustion approximately
150-200 ROP. Given he does not know if his fuel flow is working, only
the EGT will confirm fuel flow.
optimal.
> relation to the flange, and also radially. EGT is most valuable as a
> Linn (IMHO)
>> 16-18 gph. Cruise at 75% should be 9-9.5 gph.
>>>> Matt
>>>> Matt Dralle
>>> is around 10 GPH, if leaned. Obviously lower fuel flow if you're
>>> under 24".
>>> explain two different flow monitors making the same error, but hard
>>> to explain the performance, too. Smile
Hopperdhh(at)aol.com
PostPosted: Sat Dec 19, 2015 10:47 am    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
Hi Matt,
It wouldn't be too hard to check the calibration of your fuel flow gauge including the sensor. Could you make a restricted fitting so that it flows about 10 to 14 GPH using the electric pump? See how long it takes to fill a 1 quart jar while observing the fuel flow meter. Divide 900 by the time in seconds for GPH. 60 seconds would be 15 GPH. Compare the calculated GPH with what your fuel flow gauge read during the test.
Be careful, obviously!
Just a wild idea, so take it for what its worth!
I know someone (can't name the person!) who put the sensor in backwards while being distracted by a visitor. The readings were low!
Dan
RV-7A 766DH -- flying since 2004
In a message dated 12/18/2015 5:42:20 P.M. Eastern Standard Time, dralle(at)matronics.com writes:
Matt
Site Admin
PostPosted: Sat Dec 19, 2015 12:47 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
Thank you to everyone that responded!! There were some great comments that got me going down the right path.
Last night I got the cowling back on and took the RV-6 out on the runway and ran it up to full power with the intent of carefully watching the flow rate and aborting the take off if the flow wasn't sufficiently high enough. I'm happy to report that the flow rate climbed nicely up though the teens as my takeoff roll progressed. I lifted off around 15-16 gph and decided to take it around the pattern. As I climbed through the crosswind to downwind turn I noted that the flow was in the 18.5gph range, RPM was at 2700, and EGTs were low 1300's. After a few more loops around the pattern everything seemed to be working as expected. I took it out of the pattern and dialed it into my normal cruse configuration which is typically 75% power at 2250 RPM and leaned to about 1425 on the hottest EGT. Everything sounded and felt fine. Flow was right at 9.5 GPH per usual.
The only weird thing I noticed was at about 1700 RPM. When I turn from Downwind to Base and go from idle to about 2000 RPM like I usually do, right about 1700 RPM the engine kind of sags and then picks back up. It is very repeatable. Strangely there is no sag on the ground after a touch and go when I push the throttle in fast going from idle to full power anymore like there was with the old carb.
Does anyone have any idea what that sag at 1700 is? Is there a nurd knob on the carb for this specifically?
Thanks again for the great feedback!
Matt
Site Admin
Matt
Site Admin
PostPosted: Sat Dec 19, 2015 12:48 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
Matt
Site Admin
PostPosted: Sat Dec 19, 2015 12:50 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
Matt
kcflyrv(at)comcast.net
PostPosted: Sat Dec 19, 2015 1:31 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
For me, in the same situation,(in the pattern adding power from idle) this
sag at 1700 has been very common. I have 2100+ hours on my O-360 precision
carburetor RV-6. Always unsettling but never became a more serious issue.
Ken Cantrell
jhnstniii(at)aol.com
PostPosted: Sat Dec 19, 2015 8:46 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
Trying leaving the mixture a little lean in the pattern and I think you will find the issue stops happening.
LeRoy Johnston RV-6A Esperanza 1000 hours.
[quote] On Dec 19, 2015, at 4:30 PM, "Ken Cantrell" <kcflyrv(at)comcast.net> wrote:
Ken Cantrell
PostPosted: Sun Dec 20, 2015 9:17 am    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
I see your problem; you're powering up for landing. Smile
I know that many will disagree with this (having been taught by airline
pilot wannabe's instead of career flight instructors/freight dogs), but
my primary instructor wouldn't let me touch the throttle after going to
idle on downwind. His contention (which I agree with) was that if you
ever have an engine out, how will you land the plane? You'll have no
experience at the task. By staying at idle, it forces you to properly
plan the pattern turns and approach while compensating for wind, etc. It
will also make you adept at staying high (options) & slipping to your
'spot' on the runway. Yes, I know that a c/s prop has higher drag. I
learned to fly in a f/p Luscombe, and used the same technique when I
started flying a f/p T-18, and again in a 200hp, c/s, retract gear Swift
(an elevator on final, compared to an RV). And again when I started
flying RVs.
Just a thought...
Charlie
> Matt
Site Admin
PostPosted: Tue Dec 22, 2015 12:19 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
Well, it was probably the fuel pump. I think my flow rates right after replacing the fuel pump (but before I replaced the carb) were probably alright as they were similar to what I saw after the new carb. But, it was time for a new carb anyway, so I guess it worked out. Btw, as if all of this debacle wasn't frustrating enough, last weekend while trying to test all of this, the battery went dead. Checking the logs it was 36 months ago since I replaced it the last time. Guess that's about right. Sigh. Is it time to fly it yet? I've been working on it enough lately. Wink
At 10:24 AM 12/21/2015 Monday, you wrote:
So what did you do to fix the problem Matt?
Harry Crosby
To: "RV-List" <rv-list(at)matronics.com>, LycomingEngines-list(at)matronics.com, rv6-list(at)matronics.com, rv10-list(at)matronics.com
Sent: Saturday, December 19, 2015 12:44:41 PM
Subject: RV-List: Re: Lycoming O-360 Fuel Flow Rate
>Matt
Site Admin
PostPosted: Tue Dec 22, 2015 12:20 pm    Post subject: Lycoming O-360 Fuel Flow Rate Reply with quote
Harry Crosby
>Matt
Goto page 1, 2  Next
Page 1 of 2
