sam.marlow
Posted: Sat Dec 19, 2015 6:49 am Post subject: Oscilloscope for Android Phone |
Has anyone heard of or have any experience with one? I have noise in my
system somewhere, that is throwing off my EFIS and A/P systems.
rlborger(at)mac.com Guest
Posted: Sat Dec 19, 2015 7:22 am Post subject: Oscilloscope for Android Phone |
Sam,
I’m not exactly sure what your question is.
Do you believe your phone is causing the offending noise?
If so, do you have a plug-in USB charger for your phone installed in your aircraft?
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Dec 19, 2015, at 8:35 AM, Sam Marlow <sam.marlow(at)roadrunner.com> wrote:
Has anyone heard of or have any experience with one? I have noise in my system somewhere, that is throwing off my EFIS and A/P systems.
ron228rj(at)gmail.com Guest
Posted: Sat Dec 19, 2015 7:38 am Post subject: Oscilloscope for Android Phone |
He is talking about an app to turn a phone into an oscilloscope. I believe that requires voltage probe to look at electrical signals.
Ron On Dec 19, 2015 10:28 AM, "Robert Borger" <rlborger(at)mac.com (rlborger(at)mac.com)> wrote: | Quote: | --> AeroElectric-List message posted by: Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)>
Sam,
Bob Borger
3705 Lynchburg Dr.
Cel: [url=tel:817-992-1117]817-992-1117[/url]
On Dec 19, 2015, at 8:35 AM, Sam Marlow <sam.marlow(at)roadrunner.com (sam.marlow(at)roadrunner.com)> wrote:
--> AeroElectric-List message posted by: Sam Marlow <sam.marlow(at)roadrunner.com (sam.marlow(at)roadrunner.com)>
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
-Matt Dralle, List Admin.
FORUMS -
b Site -
rampil
jetboy
Posted: Sun Dec 20, 2015 3:08 pm Post subject: Re: Oscilloscope for Android Phone |
I have 2 apps which work moderately well,
"audalyzer" and "simpleFFT"
you will need to cut a headset cord or buy a connector to get the signals in
there are 2 styles of connector pinout
mine is Sony Ericson, the plug is trrs:
tip - nc
ring 1 - a 1k ohm resistor connect to sleeve
ring 2 - a 1.8 k ohm resistor to sleeve plus a 10 k ohm resistor and then via a 0.1 uF capacitor to your probe
sleeve - ground/shield of probe
you dont really need the capacitor
the purpose of the smaller resistors is to tell the phone what type of 'headset' is connected
with these components, calibration is approximately reading in dBm on the audalyzer app for levels between 0 and -40 dBm
there is another app "TestTone" if you want to generate a signal
Ralph
_________________ Ralph - CH701 / 2200a |
rampil
Posted: Mon Dec 21, 2015 5:53 am Post subject: Re: Oscilloscope for Android Phone |
Hi All,
Im not sure what signals Sam is looking for with his desire for an
oscilloscope. There is no description of the interference with his EFIS
and autopilot. Without some detailed sort of characterization of the
symptoms you can't even guess what bandwidth you might need in a scope
to track down the noise. Is it audio range, power inverter range, RF, etc?
The android apps mentioned by Jetboy seen to be spectrum analyzers for
audio range only, so far as I can tell, not oscilloscope apps.
Sam: what wires are you planning to look at with a scope? Power?
Digital I/O lines, analog I/O? If you are thinking about splicing a headset
cord on to a avionics power line, remember that 12 V will smoke an Android.
Real scopes generally have voltage divider probes and and are usually
tolerant of much wider voltage ranges to start with.
sam.marlow
Posted: Wed Dec 23, 2015 7:48 am Post subject: Oscilloscope for Android Phone |
Thanks!
sam.marlow
Posted: Wed Dec 23, 2015 8:03 am Post subject: Oscilloscope for Android Phone |
I tracked it down to a bad alternator, by the old, switch parts until
you find it! Not ideal, but it worked......
Thanks!
rampil wrote:
Hi All,
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=451285#451285
