Low Voltage Annunciator
N38CW
PostPosted: Fri Dec 18, 2015 9:57 am    Post subject: Low Voltage Annunciator Reply with quote
I have an LED in my panel that I want to illuminate on Low Volts. I found Bob's AEC9005 module on his website and would like to buy/build one. Does anyone know if they are available and if not, how about the board. I believe I can probably find most of the parts but they won't do me any good without the printed board. Anyone know of any alternatives? Thanks.
Bill Settle
RV-8 Fuselage
pestar
PostPosted: Fri Dec 18, 2015 12:38 pm    Post subject: Re: Low Voltage Annunciator Reply with quote
Go here; http://periheliondesign.com/lvwaabm.htm.
Cheers Peter
Peter Armstrong
Auckland - New Zealand
Peter Armstrong
Auckland, New Zealand
DynAero MCR-4S (Do not shoot me Smile ).
N38CW
PostPosted: Fri Dec 18, 2015 2:17 pm    Post subject: Re: Low Voltage Annunciator Reply with quote
Awesome, Peter. Thank you very much! Exactly what I am looking for.
Bill Settle
RV-8 Fuselage
PostPosted: Fri Dec 18, 2015 5:56 pm    Post subject: Low Voltage Annunciator Reply with quote
At 11:57 AM 12/18/2015, you wrote:
--> AeroElectric-List message posted by: "N38CW" <billsettle(at)bellsouth.net>
Are you flying yet? If not, what is the anticipated
first light under the wheels?
I'm wrapping up about a half dozen AEC products for
addition to the B&C catalog . . . one of which is
a 4-function module that will manage an aux battery,
annunciate low voltage, manage an ov event on a pm
alternator or manage a battery contactor to minimize
power consumption.
http://tinyurl.com/peyfl8s
If you would like to be the beta-test aircraft for
this product, I'll offer you one free of charge
in exchange for your user-evaluation of the installation
instructions and product performance in the selected
application.
N38CW
PostPosted: Sat Dec 19, 2015 6:09 am    Post subject: Re: Low Voltage Annunciator Reply with quote
... If you would like to be the beta-test aircraft for
application.
Bob . . .[/quote]
Hi Bob.
I appreciate the offer and I would be happy to do if for you but I am not close to flying yet. I'm still looking a couple more years. I also am not using an aux battery so I am probably not your best option anyway. I went ahead and ordered one from Eric Jones yesterday afternoon.
Thanks for all you do for us here and I hope you have a Merry Christmas!
Bill Settle
Bill Settle
RV-8 Fuselage
Eric M. Jones
PostPosted: Sat Dec 19, 2015 7:19 am    Post subject: Re: Low Voltage Annunciator Reply with quote
For a simple indication of Low Voltage (<13.0 V) I recommend my 13V Idiot Light. Although I can make these to your specification, the standard is Red Blinking and aux connection to audio or other warning.
NASCAR buys scores of these from me each winter. I sell lots of these into the Rotoway Helicopter builder community.
The LVWAABM (invented by Bob N.) is useful for main and aux battery management to prevent a pilot from inadvertantly using up both main anx aux batteries accidentally.
PerihelionDesign.com
Eric M. Jones
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
PostPosted: Sat Dec 19, 2015 7:44 am    Post subject: Low Voltage Annunciator Reply with quote
application.
Hi Bob.
Thanks for all you do for us here and I hope you have a Merry Christmas![/quote]
Understand. Actually, the proposed AEC9024 is
FOUR products in one box. During installation,
the builder sets functionality by adding jumpers
between the programming pins.
This design philosophy allows us to produce four
products on one assembly line and inventory only
one device the four offerings and even lets
a builder inventory one spare part for any of the
four functions.
Builders may choose to use the device in any one
of the four tasks. Architecture figure Z9 illustrates
use of the 9024 in three of the four functions.
http://tinyurl.com/5wxzn7
It will be the first AEC product loaded on the B&C
product line early next year. There's about a half
dozen more that will follow on the heals of the 9024.
JOHN TIPTON
PostPosted: Sat Dec 19, 2015 4:20 pm    Post subject: Low Voltage Annunciator Reply with quote
For a simple indication of Low Voltage:
http://www.sparkbright.co.uk/sparkright-eclipse-battery-voltage-monitor.php
John
----x--O--x----
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=451056#451056
rlborger(at)mac.com
PostPosted: Sun Dec 20, 2015 8:18 am    Post subject: Low Voltage Annunciator Reply with quote
Gents,
FWIW, I have one of the SparkBright units in my Europa and it works great! Bought a second one to install in the Toot I’m building.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Dec 19, 2015, at 6:19 PM, John Tipton <jmtipton(at)btopenworld.com> wrote:
John
----x--O--x----
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
racerjerry
PostPosted: Wed Dec 23, 2015 5:52 am    Post subject: Re: Low Voltage Annunciator Reply with quote
I can tell you that the Eric Jones 13V Idiot Light has saved my bacon quite a few times - or at least has saved me from dangerous hand-propping by reminding me to turn the master switch OFF. For $50 you can't get a better low voltage warning indicator - no construction required. As long as you do not hardwire or permanently mount Eric's ingenious little device, it is even legal to install it on a certified aircraft. The light also has an extra wire to connect to an optional audio alarm or panel annunciator.
I fabricated a mount for the low voltage warning light module from a 3/4 x 1/16 x 2 inch long aluminum angle (aircraft aisle of home stores) and Velcro mounted it to the top of my glare shield; with the light aimed directly at me but offset to the co-pilot side. The warning light is installed in My Cessna 172K and powered from the cigarette lighter receptacle; providing me with a perfectly legal (nothing permanently attached to airframe) and very valuable low voltage warning as well as alerting me should I ever forget to turn the master switch off at shutdown – another warning indication that I had long desired. On later Cessnas’, I believe that this second function is indirectly achieved through their over-voltage warning light; however my 1969 (& earlier) does not have an over-voltage sensor.
http://periheliondesign.com/moreproductsfiles/LV_Annunciator%20Manual.pdf
Please note that I have no connection to Mr. Eric M. Jones or his company www.PerihelionDesign.com other than being a very satisfied customer.
Jerry King
