Weak Starter
JohnInReno
PostPosted: Sun Dec 06, 2015 4:16 pm    Post subject: Weak Starter Reply with quote
My Skytec starter barely turns over an IO320.
I measured:
Battery 13.12 volts.
"On" side of master contactor to airframe ground 12.25 volts.
"On" side of starter contactor to airframe ground while cranking 8.6 to
9.0 volts.
Big wire on starter to airframe ground while cranking is 8.6 volts or less.
All this was done with a genuine Harbor Freight $4.00 digital meter. I
believe that this points to the starter contactor as the culprit. Correct?
john
John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale
jmjones2000(at)mindspring
PostPosted: Sun Dec 06, 2015 4:53 pm    Post subject: Weak Starter Reply with quote
Is say high resistance in the starter contactor
More than likely due to internal arcing. This causes corrosion and pitting.
Slap a new contactor on there and I bet it fixes the issue.
Afterwards, dissect the old contactor to see exactly what happens internally.
Justin.
I measured:
"On" side of starter contactor to airframe ground while cranking 8.6 to 9.0 volts.
All this was done with a genuine Harbor Freight $4.00 digital meter. I believe that this points to the starter contactor as the culprit. Correct?
john
ceengland7(at)gmail.com
PostPosted: Sun Dec 06, 2015 5:50 pm    Post subject: Weak Starter Reply with quote
I measured:
to 9.0 volts.
less.
Correct?
john
12.25 volts with minimal load (contactor coil only) *might* be a little
weak for a fully charged battery. The measurement doesn't really mean a
lot if there's no load on the other side of the contactor. You could put
a 100,000 ohm resistor in series & still measure full battery voltage on
the other side of the resistor, as long as there's no load to ground.
What's the measurement at the 'on' side of the master contactor while
cranking? (Don't change test conditions.)
Another method of measurement when looking for bad joints/high
resistance in a high current circuit:
1. Measure from the battery positive post (not the bolt or clamp) to the
starter positive post while cranking. A voltage drop of greater than
~1/2 volt means you have a high resistance somewhere between battery &
starter.
2. Measure from the frame (ground) of the starter to the actual negative
post on the battery (not the bolt or clamp) while cranking. That
measurement should again be less than 1/2 volt. If not, you have high
resistance in the ground circuit.
8.5-9 volts across the starter windings while under load really doesn't
sound bad, as long as the rest of the circuit is 'right' and the battery
is in good shape.
Charlie
PostPosted: Sun Dec 06, 2015 5:56 pm    Post subject: Weak Starter Reply with quote
> I measured:
> to 9.0 volts.
> less.
> Correct?
> john
Edit: I missed the 1st line, battery 13.2 & load side of contactor at
12.25. The contacts in the master contactor have really high resistance
to see that much drop.
little weak for a fully charged battery. The measurement doesn't
really mean a lot if there's no load on the other side of the
contactor. You could put a 100,000 ohm resistor in series & still
measure full battery voltage on the other side of the resistor, as
long as there's no load to ground. What's the measurement at the 'on'
side of the master contactor while cranking? (Don't change test
conditions.)
the starter positive post while cranking. A voltage drop of greater
than ~1/2 volt means you have a high resistance somewhere between
battery & starter.
negative post on the battery (not the bolt or clamp) while cranking.
That measurement should again be less than 1/2 volt. If not, you have
high resistance in the ground circuit.
doesn't sound bad, as long as the rest of the circuit is 'right' and
the battery is in good shape.
Charlie
Kellym
PostPosted: Sun Dec 06, 2015 6:42 pm    Post subject: Weak Starter Reply with quote
You probably need to replace both starter relay and master relay.
Download Skytec's troubleshooting chart and follow it carefully.
I measured:
to 9.0 volts.
less.
Correct?
john
Kelly McMullen
KCHD
wgreenley
PostPosted: Mon Dec 07, 2015 4:05 am    Post subject: Weak Starter Reply with quote
I agree, I had these same issues on my 172 and it was the master relay, the starter relay was fine. I replaced both as they were both of the same vintage. Starting problems gone.
Bill
JohnInReno
PostPosted: Mon Dec 07, 2015 6:07 am    Post subject: Weak Starter Reply with quote
Thanks for all of the replies.
Skytec's troubleshooting chart says that the starter needs to see 10+
volts. I will be replacing both relays.
john
On 12/6/2015 6:41 PM, Kelly McMullen wrote:
<kellym(at)aviating.com>
> I measured:
> to 9.0 volts.
> less.
> Correct?
> john
John Morgensen
RV4 - for sale
skywagon
PostPosted: Mon Dec 07, 2015 10:13 am    Post subject: Weak Starter Reply with quote
John,
A problem like you are seeing can also be caused by an "aged" main battery.
The battery V measures fine with no load, may also measure fine with just a
buss current load, but, when it sees a "starter" type current load (200 -
300 amps), it slumps badly. Usually caused by a cell or two that are too
aged to produce the amps needed.
Only answer is to install a new battery and keep it fresh by keeping a low
current "maintainer" style charger on it during hangar periods.
David
JohnInReno
PostPosted: Mon Dec 07, 2015 11:22 am    Post subject: Weak Starter Reply with quote
David,
Be careful with "maintainer" style chargers and Odyssey PC680 batteries. Notice that the warranty can be voided:
C. The warranty does not cover a Battery that is damaged or destroyed as a result of one for more of the
following:
Willful abuse, misuse, physical damage, neglect or if the top decorative cover has been removed.
Natural forces such as wind, lightning, hail; damage due to fire, collision, explosion, vandalism, theft,
penetration or opening of the Battery case in any manner.
Overcharging, undercharging, charging or installing in reverse polarity, improper maintenance, allowing
the Battery to be deeply discharged via a parasitic load or mishandling of the Battery such as but not
limited to using the terminals for lifting or carrying the Battery. Trickle chargers that do not have a regulated
trickle charge voltage between 13.5V and 13.8V (no lower than 13.5V and no higher than 13.8V) will cause
early failure of the Battery. Use of such chargers with the Battery will also void the Battery’s warranty. For
applications where an alternator is present, the alternator must deliver between 14.0V and 14.7V when
measured at the Battery’s terminals. Alternators that do not have a regulated charge between 14.0V and
14.7V (no lower than 14.0V and no higher than 14.7V) will cause early failure of the Battery. Use of such
alternators with the Battery will also void the Battery’s warranty
I thought I was doing the right thing by religiously using a quality Battery Minder but it destroyed the battery. They use to publish a list of unacceptable chargers but I can't find it on their web site any more.
john
On 12/7/2015 10:11 AM, David Lloyd wrote:
[quote]--> AeroElectric-List message posted by: "David Lloyd" <skywagon(at)charter.net> (skywagon(at)charter.net)
John,
The battery V measures fine with no load, may also measure fine with just a buss current load, but, when it sees a "starter" type current load (200 - 300 amps), it slumps badly.  Usually caused by a cell or two that are too aged to produce the amps needed.
Only answer is to install a new battery and keep it fresh by keeping a low current "maintainer" style charger on it during hangar periods.
David
John Morgensen
RV4 - for sale
Mauledriver(at)nc.rr.com
PostPosted: Mon Dec 07, 2015 12:44 pm    Post subject: Weak Starter Reply with quote
I would second the points made below in John's post.
Over the past 9 years I've managed to abuse and slowly kill a number of PC680s in a variety of ways.  Simply reading and FOLLOWING the guidelines documented in their Owner's Manual, including the fine print of the Warranty, will avoid ALL of the problems I've experienced.
Why didn't I?  Well, since I grew up charging batteries from early 60s electric tooth brushes that could barely handle a full set of teeth, to gliders, boats, cars and 50 years of RC aircraft, I must know what I'm doing. So I've taken the time to rediscover and learn anew all that was already known about Odessy's AGM line of batteries.  I'm almost done with my studies...
Regarding trickle chargers, according to the Manual, "..there is no need to trickle or float charge during winter months."  It continues, "It can be stored for 2 years or more below 77F."  If you insist, see Warranty notes reproduced below.  If you do have some kind of parasitic load on the battery during storage (I had that), get it fully charged (you must start there) , apply a trickle charger that can produce the regulated voltage (I didn't), then for good measure, fully charge it before using it.  Better, just disconnect the load and save the cost of the trickle charger.... or $150 lets you start the learning process from the beginning again.
Just to repeat, I've found the information in Odyssey's Owner's Manual to be complete and accurate in every way.  The only thing that upsets me is that they cost $150 a copy, but at least it comes with a fresh battery.
Bill "content to remain ignorant about Lithium technologies and to simply enjoy their performance" Watson
On 12/7/2015 2:21 PM, John Morgensen wrote:
[quote] David,
following:
john
John,
David
speedy11
PostPosted: Tue Dec 08, 2015 5:02 pm    Post subject: Weak Starter Reply with quote
John,
I had the same issue on my IO-390. Skytec worked okay for five years then got slower and slower. I did all of the same checks you are talking about. Replaced the starter. Problem solved.
See if you can borrow a starter from someone and try it on your plane.
Stan
I measured:
9.0 volts.
john
PostPosted: Tue Dec 08, 2015 9:11 pm    Post subject: Weak Starter Reply with quote
Be advised, some if not all lycoming skytec starters have a contactor (solenoid) on the starter as well.
[quote] On Dec 8, 2015, at 16:59, speedy11(at)aol.com wrote:
John,
Stan
I measured:
9.0 volts.
