flysrv10(at)gmail.com Guest
Posted: Sun Dec 06, 2015 12:20 pm Post subject: Slick Mag 1100 hrs. |
On my last flight, I felt a miss on climb out so I decided to pull the mags and take a look.
As soon as I pulled the mags, I noticed that pieces of Mag Drive Cushions were missing on both mags and I could not find them in the mag hole.
So I drained the oil and pull the Oil Suction Screen out and to my pleasant surprise, both pieces were found in the strainer.
The part no. for the cushions is LW13641. I recommend that they are replaced every time the mags are pulled out. The new parts feel soft and the old parts were brittle, I assume due to heat.
The cushions are held in place temporarily with fuel lube during the mag installation so you want to be sure they do not fall out while you are inserting the mag into the drive.
The mag components all checked out and everything looked good. I cleaned all the parts and replaced one rotor and the engine runs very smooth now. Not sure if the cushions had anything to do with the engine miss or not.
DO NOT ARCHIVE.
[img]cid:5E5F43BF-481A-4149-B595-9C1EA22F89EF(at)flbb.net[/img] Rob Kermanj
[img]cid:FA72B4DA-6575-49EF-89BA-C679997922E0(at)flbb.net[/img]
70.25 KB |
9516 Time(s) |
62.78 KB |
9516 Time(s) |
jmjones2000(at)mindspring Guest
Posted: Sun Dec 06, 2015 2:22 pm Post subject: Slick Mag 1100 hrs. |
Sounds like the perfect excuse to switch to electronic ignition!
DO NOT ARCHIVE
On Dec 6, 2015, at 12:16, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
| Quote: | On my last flight, I felt a miss on climb out so I decided to pull the mags and take a look.
DO NOT ARCHIVE.
<IMG_1922.jpeg>
70.25 KB |
9512 Time(s) |
Posted: Sun Dec 06, 2015 2:40 pm Post subject: Slick Mag 1100 hrs. |
Sure does. Just talked to my neighbor that just installed dual electronic. Has not started the engine yet.
Do not archive.
On Dec 6, 2015, at 5:19 PM, Justin Jones <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)> wrote:
| Quote: | Sounds like the perfect excuse to switch to electronic ignition!
DO NOT ARCHIVE
DO NOT ARCHIVE.
<IMG_1922.jpeg>
70.25 KB |
9510 Time(s) |
jump2(at)sbcglobal.net Guest
Posted: Sun Dec 06, 2015 2:56 pm Post subject: Slick Mag 1100 hrs. |
Please don't start that again you already lost.
On Dec 6, 2015, at 4:19 PM, Justin Jones <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)> wrote:
DO NOT ARCHIVE
DO NOT ARCHIVE.
<IMG_1918.jpeg> Rob Kermanj
<IMG_1922.jpeg>
Posted: Sun Dec 06, 2015 3:00 pm Post subject: Slick Mag 1100 hrs. |
I have been running the EFII system and couldn’t be happier! Just cover the mag holes altogether. What a great system!
| Quote: | On Dec 6, 2015, at 1:37 PM, Flysrv10 <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
Do not archive. Sent from my iPhone
DO NOT ARCHIVE
DO NOT ARCHIVE.
<IMG_1922.jpeg>
Albert Gardner
Posted: Sun Dec 06, 2015 4:28 pm Post subject: Slick Mag 1100 hrs. |
Has anyone installed the 6 cylinder P Mags now that they are finally available?
Albert Gardner
N991RV
Yuma, AZ
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Justin Jones
Sent: Sunday, December 06, 2015 3:57 PM
Subject: Re: Slick Mag 1100 hrs.
Do not archive.
DO NOT ARCHIVE
DO NOT ARCHIVE.
<IMG_1918.jpeg>
Rob Kermanj
<IMG_1922.jpeg>
RV-10 N991RV |
Dave Saylor
Posted: Sun Dec 06, 2015 5:32 pm Post subject: Slick Mag 1100 hrs. |
I installed two Slicks on a newer Lycoming at work the other day. The drive pads were a different design with tabs that engaged slots in the drive gears. It was pretty easy to feel the pads snap into place, and once engaged they stayed in place really well.
I know in the past (my own plane in particular) I've battled trying to keep the pads in place while wresting the mags into the holes. The new design makes it pretty easy.
--Dave
On Sun, Dec 6, 2015 at 12:16 PM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
DO NOT ARCHIVE.
Rob Kermanj
62.78 KB |
9505 Time(s) |
70.25 KB |
9505 Time(s) |
_________________ --Dave
KWVI |
Kellym
Posted: Sun Dec 06, 2015 6:40 pm Post subject: Slick Mag 1100 hrs. |
Think through your backup plan very carefully. A friend with one P mag
and one E mag had both damaged by a faulty VR, which allowed system
voltage around 20V. Both quit sparking at the same time. He had to make
the impossible turn, and luckily made it back to the runway.
On 12/6/2015 3:57 PM, Justin Jones wrote:
| Quote: | I have been running the EFII system and couldn’t be happier! Just
> Do not archive.
> Sent from my iPhone
>> DO NOT ARCHIVE
>>> mag hole.
>>> DO NOT ARCHIVE.
>>> <IMG_1918.jpeg>
>>> Rob Kermanj
>>> <IMG_1922.jpeg>
KCHD |
Tim Olson
You don't happen to have the info on the p/n or manufacturer and compatibility with our IO-540's do you?
I've had mine out a couple times but have not replaced them and they're almost 1200 hours old so I figured I'd order 2 or 3 pairs, since I'll have 2 airplanes to care for.
Tim
On Dec 6, 2015, at 7:29 PM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
| Quote: | I installed two Slicks on a newer Lycoming at work the other day. The drive pads were a different design with tabs that engaged slots in the drive gears. It was pretty easy to feel the pads snap into place, and once engaged they stayed in place really well.
--Dave
DO NOT ARCHIVE.
Rob Kermanj
<IMG_1922.jpeg>
70.25 KB |
9504 Time(s) |
Posted: Mon Dec 07, 2015 4:48 am Post subject: Slick Mag 1100 hrs. |
Tim,
Although having a fool-proof part is the way to go, the fuel lube solution works well but needs care to install.
If you can't fit the redesigned cushions in your installation, I would not hesitate to use fuel lube.
Do not archive.
On Dec 6, 2015, at 9:37 PM, Tim Olson <Tim(at)MyRV10.com (Tim(at)myrv10.com)> wrote:
| Quote: | You don't happen to have the info on the p/n or manufacturer and compatibility with our IO-540's do you?
Tim
--Dave
DO NOT ARCHIVE.
<IMG_1918.jpeg>
Rob Kermanj
<IMG_1922.jpeg>
70.25 KB |
9486 Time(s) |
Dave Saylor
Posted: Mon Dec 07, 2015 7:57 am Post subject: Slick Mag 1100 hrs. |
I poked around and found Lyc Service Instruction 1299B. It has p/ns, pictures, applicability, yada yada. I'm not sure if they work on all Lycomings but the SI gives SN ranges. --D
On Sunday, December 6, 2015, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
Tim
On Dec 6, 2015, at 7:29 PM, David Saylor <[url=javascript:_e(%7B%7D,'cvml','saylor.dave(at)gmail.com');]saylor.dave(at)gmail.com[/url]> wrote:
--Dave
On Sun, Dec 6, 2015 at 12:16 PM, Rob Kermanj <[url=javascript:_e(%7B%7D,'cvml','flysrv10(at)gmail.com');]flysrv10(at)gmail.com[/url]> wrote:
DO NOT ARCHIVE.
Rob Kermanj
<IMG_1922.jpeg>
70.25 KB |
9485 Time(s) |
KWVI |
Posted: Tue Dec 08, 2015 3:54 am Post subject: Slick Mag 1100 hrs. |
Just a clarification: The SB shows a new cushion design and a new mag drive as a matched set that prevents the cushions falling into the case during installation. The issue of the cushions getting brittle, breaking and falling into the case remains.
| Quote: | On Dec 7, 2015, at 10:52 AM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
I poked around and found Lyc Service Instruction 1299B. It has p/ns, pictures, applicability, yada yada. I'm not sure if they work on all Lycomings but the SI gives SN ranges. --DOn Sunday, December 6, 2015, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote: | Quote: | You don't happen to have the info on the p/n or manufacturer and compatibility with our IO-540's do you?
Tim
On Dec 6, 2015, at 7:29 PM, David Saylor <[url=javascript:_e(%7B%7D,\'cvml\',\'saylor.dave(at)gmail.com\');]saylor.dave(at)gmail.com[/url]> wrote:
--Dave
On Sun, Dec 6, 2015 at 12:16 PM, Rob Kermanj <[url=javascript:_e(%7B%7D,\'cvml\',\'flysrv10(at)gmail.com\');]flysrv10(at)gmail.com[/url]> wrote: | Quote: | On my last flight, I felt a miss on climb out so I decided to pull the mags and take a look.
DO NOT ARCHIVE.
<IMG_1922.jpeg>
